Freezing a lot lately
Hi, I have been running Arch Linux since 2007 while maintaining my own little installation instructions but decided to give Garuda Linux a spin late December. So far so good. The overall experience is impressive. I used to run FDE on LVM+LUKS+XFS and my own snapshot command before upgrading but never matched the level of integration Garuda is offering with Btrfs and Grub integration.
Now I experienced a lot of lags and freezes (had to hard reboot once) over the past few days. Sometimes I can alt+tab but not click on anything. Other times I just can't do anything even switching virtual consoles via ctrl+alt+2,3,4...
I'm running the KDE Dr460nized edition in on a i7-8550U CPU @ 1.80GHz with 16GB RAM (Lenovo X1 Carbon).
Has the latest linux-tkg-bmq 5.10.4 shown any sign of instability?
So far I reverted back to 5.10.3 to see if it makes a difference.
There is one more thing I changed over the past few days is the compositor rendering backend. Since I kept loosing the fancy effects over time, I went from the default OpenGL 3.1 (?) to XRender. Could that be the problem as well?
I'm going to try to switch to OpenGL 2.0 to see if things improve.
Have other users experienced similar freezing issues lately?
Yes, there has been some freezing issues reported on the linux-tkg-bmq kernel recently. Most seem happy with that kernel, but depending on the hardware there has been some issues reported.
I would post your:
inxi -Fxxxza
I would also test at least three alternate kernels.
Some choices worth testing might be:
linux
linux-zen
linux-lts
linux-hardened
linux-mainline
The choice of specific kernels is sometimes very dependent upon your computers age and hardware components. So, do some research to figure out which kernel(s) might be the best choices for your specific hardware.
Always keep at least two kernels installed at all times as a fall back.
Thanks for the pointers.
Here is my configuration:
inxi -Fxxxza        jeu. 07 janv. 2021 09:12:27
System:    Kernel: 5.10.3-106-tkg-bmq x86_64 bits: 64 compiler: gcc v: 10.2.0
       root=UUID=f7329b2e-bd3b-4757-85aa-b18da88aadb1 rw rootflags=subvol=@ quiet
       cryptdevice=UUID=0d2bfdf1-3973-433f-b488-cf9adb545f63:luks-0d2bfdf1-3973-433f-b488-cf9adb545f63
       root=/dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 splash rd.udev.log_priority=3 vt.global_cursor_default=0
       Desktop: KDE Plasma 5.20.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 dm: SDDM Distro: Garuda Linux
Machine:   Type: Laptop System: LENOVO product: 20KHCTO1WW v: ThinkPad X1 Carbon 6th serial: <filter> Chassis: type: 10
       Mobo: LENOVO model: 20KHCTO1WW v: SDK0J40697 WIN serial: <filter> UEFI: LENOVO v: N23ET75W (1.50 ) date: 10/13/2020
Battery:   ID-1: BAT0 charge: 41.5 Wh condition: 53.0/57.0 Wh (93%) volts: 12.3/11.5 model: SMP 01AV430 type: Li-poly
       serial: <filter> status: Unknown cycles: 284
CPU:       Info: Quad Core model: Intel Core i7-8550U bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
       model-id: 8E (142) stepping: A (10) microcode: E0 L2 cache: 8 MiB
       flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 32026
       Speed: 3925 MHz min/max: 400/4000 MHz Core speeds (MHz): 1: 3925 2: 1204 3: 3939 4: 3987 5: 4001 6: 3905 7: 4003
       8: 3918
Graphics:  Device-1: Intel UHD Graphics 620 vendor: Lenovo driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5917
       Device-2: IMC Networks Integrated Camera type: USB driver: uvcvideo bus ID: 1-8:4 chip ID: 13d3:56b2
       Display: x11 server: X.Org 1.20.10 compositor: kwin_x11 driver: intel unloaded: modesetting alternate: fbdev,vesa
       display ID: :0 screens: 1
       Screen-1: 0 s-res: 3840x2160 s-dpi: 96 s-size: 1016x571mm (40.0x22.5") s-diag: 1165mm (45.9")
       Monitor-1: HDMI1 res: 3840x2160 hz: 30 dpi: 163 size: 600x340mm (23.6x13.4") diag: 690mm (27.2")
       OpenGL: renderer: Mesa Intel UHD Graphics 620 (KBL GT2) v: 4.6 Mesa 20.3.2 direct render: Yes
Audio:     Device-1: Intel Sunrise Point-LP HD Audio vendor: Lenovo driver: snd_hda_intel v: kernel alternate: snd_soc_skl
       bus ID: 00:1f.3 chip ID: 8086:9d71
       Sound Server: ALSA v: k5.10.3-106-tkg-bmq
Network:   Device-1: Intel Ethernet I219-V vendor: Lenovo driver: e1000e v: kernel port: efa0 bus ID: 00:1f.6
       chip ID: 8086:15d8
       Device-2: Intel Wireless 8265 / 8275 driver: iwlwifi v: kernel port: efa0 bus ID: 02:00.0 chip ID: 8086:24fd
       IF-ID-1: bluespace state: unknown speed: N/A duplex: N/A mac: N/A
Drives:    Local Storage: total: 931.51 GiB used: 1.12 TiB (122.9%)
       ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 970 EVO 1TB size: 931.51 GiB block size:
       physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 serial: <filter> rev: 2B2QEXE7 temp: 27.9 C
Partition: ID-1: / raw size: 931.21 GiB size: 931.21 GiB (100.00%) used: 572.27 GiB (61.5%) fs: btrfs dev: /dev/dm-0
       maj-min: 254:0 mapped: luks-0d2bfdf1-3973-433f-b488-cf9adb545f63
       ID-2: /boot/efi raw size: 300 MiB size: 299.4 MiB (99.80%) used: 696 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1
       maj-min: 259:1
       ID-3: /home raw size: 931.21 GiB size: 931.21 GiB (100.00%) used: 572.27 GiB (61.5%) fs: btrfs dev: /dev/dm-0
       ID-4: /var/log raw size: 931.21 GiB size: 931.21 GiB (100.00%) used: 572.27 GiB (61.5%) fs: btrfs dev: /dev/dm-0
       ID-5: /var/tmp raw size: 931.21 GiB size: 931.21 GiB (100.00%) used: 572.27 GiB (61.5%) fs: btrfs dev: /dev/dm-0
Swap:      Kernel: swappiness: 10 (default 60) cache pressure: 75 (default 100)
       ID-1: swap-1 type: zram size: 1.94 GiB used: 5.3 MiB (0.3%) priority: 32767 dev: /dev/zram0
       ID-2: swap-2 type: zram size: 1.94 GiB used: 5.4 MiB (0.3%) priority: 32767 dev: /dev/zram1
       ID-3: swap-3 type: zram size: 1.94 GiB used: 5.5 MiB (0.3%) priority: 32767 dev: /dev/zram2
       ID-4: swap-4 type: zram size: 1.94 GiB used: 5.5 MiB (0.3%) priority: 32767 dev: /dev/zram3
       ID-5: swap-5 type: zram size: 1.94 GiB used: 5.2 MiB (0.3%) priority: 32767 dev: /dev/zram4
       ID-6: swap-6 type: zram size: 1.94 GiB used: 5.1 MiB (0.3%) priority: 32767 dev: /dev/zram5
       ID-7: swap-7 type: zram size: 1.94 GiB used: 5.6 MiB (0.3%) priority: 32767 dev: /dev/zram6
       ID-8: swap-8 type: zram size: 1.94 GiB used: 5.6 MiB (0.3%) priority: 32767 dev: /dev/zram7
Sensors:   System Temperatures: cpu: 57.0 C mobo: N/A
       Fan Speeds (RPM): cpu: 0
Info:      Processes: 420 Uptime: 10h 08m wakeups: 6 Memory: 15.53 GiB used: 10.77 GiB (69.4%) Init: systemd v: 247 Compilers:
       gcc: 10.2.0 clang: 11.0.0 Packages: pacman: 1828 lib: 377 flatpak: 0 Shell: fish v: 3.1.2 running in: guake
       inxi: 3.2.01
:laughing: what about journal errors captain? :stuck_out_tongue_winking_eye:
I thought it was all good but loading the system with a couple of browsers at the same time triggered the slow down.
I see something related to swap in journalctl. I remember that I did select a swapfile during setup just to be on the safe side. Would that conflict with the zram implementation?
 journalctl -b -1 -xp3 --no-hostname --no-pager        jeu. 07 janv. 2021 14:52:23
 -- Journal begins at Mon 2020-12-28 14:05:01 CET, ends at Thu 2021-01-07 14:52:14 CET. --
 janv. 07 10:01:00 kernel: cgroup2: Unknown parameter 'memory_recursiveprot'
 janv. 07 10:01:00 systemd[1]: Failed to activate swap /swapfile.
 janv. 07 10:01:00 systemd-udevd[366]: nvme0: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/nvme/nvme0/queue/scheduler}, ignoring: No such file or directory
 janv. 07 10:01:00 systemd-udevd[373]: nvme0n1p2: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/nvme/nvme0/nvme0n1/nvme0n1p2/queue/scheduler}, ignoring: No such file or directory
 janv. 07 10:01:00 systemd-udevd[391]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/nvme/nvme0/nvme0n1/nvme0n1p1/queue/scheduler}, ignoring: No such file or directory
 janv. 07 10:01:01 systemd-tmpfiles[498]: Failed to write file "/sys/module/pcie_aspm/parameters/policy": Operation not permitted
 janv. 07 10:01:01 kernel: proc: Bad value for 'hidepid'
 janv. 07 10:01:01 systemd-udevd[391]: nvme0n1p1: /etc/udev/rules.d/60-ioschedulers.rules:2 Failed to write ATTR{/sys/devices/pci0000:00/0000:00:1c.4/0000:04:00.0/nvme/nvme0/nvme0n1/nvme0n1p1/queue/scheduler}, ignoring: No such file or directory
 janv. 07 10:01:01 systemd[1]: Failed to activate swap /swapfile.
 â–‘â–‘ Subject: A start job for unit swapfile.swap has failed
 â–‘â–‘ Defined-By: systemd
 â–‘â–‘ Support: https://lists.freedesktop.org/mailman/listinfo/systemd-devel
 â–‘â–‘
 â–‘â–‘ A start job for unit swapfile.swap has finished with a failure.
 â–‘â–‘
 â–‘â–‘ The job identifier is 217 and the job result is failed.
 janv. 07 10:01:02 systemd[1]: Failed to start WireGuard via wg-quick(8) for bluespace.
 â–‘â–‘ Subject: A start job for unit wg-quick@bluespace.service has failed
 â–‘â–‘
 â–‘â–‘ A start job for unit wg-quick@bluespace.service has finished with a failure.
 â–‘â–‘
 â–‘â–‘ The job identifier is 136 and the job result is failed.
 janv. 07 10:01:04 systemd[993]: pam_env(systemd-user:session): pam_putenv: delete non-existent entry; SSH_AGENT_PID
 janv. 07 10:01:04 sddm-helper[969]: pam_env(sddm-autologin:session): pam_putenv: delete non-existent entry; SSH_AGENT_PID
 janv. 07 10:01:07 kernel: ucsi_acpi USBC000:00: con1: failed to register alternate modes
 janv. 07 10:01:08 pulseaudio[1474]: Failed to register as a handsfree audio agent with ofono: org.freedesktop.DBus.Error.ServiceUnknown: The name org.ofono was not provided by any .service files
 janv. 07 10:01:12 sudo[2205]: pam_unix(sudo:auth): conversation failed
 janv. 07 10:01:12 sudo[2205]: pam_unix(sudo:auth): auth could not identify password for [alpha]
 janv. 07 10:01:12 kernel: ucsi_acpi USBC000:00: con2: failed to register alt modes
 janv. 07 10:01:14 bluetoothd[520]: profiles/input/hog-lib.c:report_value_cb() bt_uhid_send: Invalid argument (22)
 janv. 07 10:01:17 kernel: ucsi_acpi USBC000:00: con2: failed to register alternate modes
 janv. 07 10:01:18 sudo[2424]: pam_unix(sudo:auth): conversation failed
 janv. 07 10:01:18 sudo[2424]: pam_unix(sudo:auth): auth could not identify password for [alpha]
 janv. 07 10:02:10 systemd-coredump[4937]: Failed to connect to coredump service: Connection refused
 janv. 07 10:02:10 pulseaudio[4924]: Unable to contact D-Bus session bus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
 janv. 07 10:02:10 pulseaudio[4924]: Failed to load module "module-jackdbus-detect" (argument: "channels=2"): initialization failed.
second par of the journalctl
 journalctl -b -1 -rp4 -n 300 --no-hostname --no-pager        476ms  jeu. 07 janv. 2021 14:53:55
 -- Journal begins at Mon 2020-12-28 14:05:01 CET, ends at Thu 2021-01-07 14:54:04 CET. --
 janv. 07 10:02:14 kernel: kauditd_printk_skb: 26 callbacks suppressed
 janv. 07 10:02:14 systemd[1]: bluetooth-autoconnect.service: Failed with result 'exit-code'.
 janv. 07 10:02:12 sddm[614]: QProcess: Destroyed while process ("/usr/lib/sddm/sddm-helper") is still running.
 janv. 07 10:02:11 sddm[614]: Signal received: SIGTERM
 janv. 07 10:02:10 pulseaudio[4924]: Unable to contact D-Bus: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
 janv. 07 10:02:10 systemd[993]: obex.service: Failed with result 'exit-code'.
 janv. 07 10:02:09 pulseaudio[4924]: Stale PID file, overwriting.
 janv. 07 10:02:09 systemd[993]: pulseaudio.service: Failed with result 'exit-code'.
 janv. 07 10:02:09 systemd[1]: systemd-coredump.socket: Failed with result 'resources'.
 janv. 07 10:02:09 systemd[1]: systemd-coredump.socket: Failed to queue service startup job (Maybe the service file is missing or not a non-template unit?): Transaction for systemd-coredump@0-4802-0.service/start is destructive (shutdown.target has 'start' job queued, but 'stop' is included in transaction).
 janv. 07 10:02:09 kded5[1387]: The X11 connection broke: I/O error (code 1)
 janv. 07 10:02:09 kded5[1387]: QDBusAbstractAdaptor: Cannot relay signal KDEDModule::moduleDeleted(KDEDModule*): Pointers are not supported: KDEDModule*
 janv. 07 10:02:09 kscreen_backend_launcher[1453]: The X11 connection broke (error 1). Did the X11 server die?
 janv. 07 10:02:09 kglobalaccel5[1424]: The X11 connection broke (error 1). Did the X11 server die?
 janv. 07 10:02:09 kactivitymanagerd[1417]: The X11 connection broke (error 1). Did the X11 server die?
 janv. 07 10:02:09 kwin_x11[1395]: The X11 connection broke: I/O error (code 1)
 janv. 07 10:02:09 sddm[614]: Auth: sddm-helper exited with 15
 janv. 07 10:02:09 sddm[614]: Authentication error: "Process crashed"
 janv. 07 10:02:09 sddm[614]: Auth: sddm-helper crashed (exit code 15)
 janv. 07 10:01:44 org_kde_powerdevil[1476]: QObject::disconnect: Unexpected nullptr parameter
 janv. 07 10:01:23 gmenudbusmenuproxy[1468]: kde.dbusmenuproxy: Got an empty menu for 0 on ":1.32" at "/org/appmenu/gtk/window/0"
 janv. 07 10:01:21 plasmashell[1442]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
 janv. 07 10:01:21 plasmashell[1442]: trying to show an empty dialog
 janv. 07 10:01:20 plasmashell[1442]: kf.service.services: The desktop file "ServiceMenus/reimage-convert-rotate.desktop" references the action "agif" but doesn't define it
 janv. 07 10:01:19 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5601, resource id: 48234626, major code: 14 (GetGeometry), minor code: 0
 janv. 07 10:01:19 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 9 (BadDrawable), sequence: 5600, resource id: 48234624, major code: 14 (GetGeometry), minor code: 0
 janv. 07 10:01:17 kernel: ucsi_acpi USBC000:00: PPM NOT RESPONDING
 janv. 07 10:01:12 kernel: ucsi_acpi USBC000:00: PPM NOT RESPONDING
 janv. 07 10:01:12 kernel: kauditd_printk_skb: 5 callbacks suppressed
 janv. 07 10:01:12 plasmashell[1442]: Error: cannot change the containment to AppletsLayout
 janv. 07 10:01:12 plasmashell[1442]: file:///usr/share/plasma/wallpapers/com.github.zren.inactiveblur/contents/ui/WindowModel.qml:24:3: Unable to assign [undefined] to QRect
 janv. 07 10:01:12 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 3390, resource id: 4194361, major code: 18 (ChangeProperty), minor code: 0
 janv. 07 10:01:12 plasmashell[1442]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/garuda-wallpapers" is a directory. Use addDir!
 janv. 07 10:01:12 plasmashell[1442]: kf.coreaddons: KDirWatch: "/usr/share/wallpapers/Next" is a directory. Use addDir!
 janv. 07 10:01:12 plasmashell[1442]: trying to show an empty dialog
 janv. 07 10:01:12 plasmashell[1442]: Old primary output: QScreen(0x560ff673e770, name="eDP1") New primary output: QScreen(0x560ff673e7b0, name="HDMI1")
 janv. 07 10:01:12 plasmashell[1442]: file:///usr/share/plasma/shells/org.kde.plasma.desktop/contents/views/Desktop.qml:146:19: QML Loader: Binding loop detected for property "height"
 janv. 07 10:01:11 kded5[1387]: plasma-nm: Unhandled active connection state change:  1
 janv. 07 10:01:11 plasmashell[1442]: kf.service.services: The desktop file "ServiceMenus/reimage-convert-rotate.desktop" references the action "agif" but doesn't define it
 janv. 07 10:01:11 kwin_x11[1395]: QPainter::begin: Paint device returned engine == 0, type: 3
 janv. 07 10:01:11 kwin_x11[1395]: Module 'org.kde.kwin.decoration' does not contain a module identifier directive - it cannot be protected from external registrations.
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 510, resource id: 62914568, major code: 61 (ClearArea), minor code: 0
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 509, resource id: 62914568, major code: 8 (MapWindow), minor code: 0
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 508, resource id: 62914568, major code: 12 (ConfigureWindow), minor code: 0
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 506, resource id: 62914568, major code: 12 (ConfigureWindow), minor code: 0
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 505, resource id: 62914568, major code: 25 (SendEvent), minor code: 0
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 504, resource id: 62914568, major code: 6 (ChangeSaveSet), minor code: 0
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 503, resource id: 62914568, major code: 142 (Unknown), minor code: 1
 janv. 07 10:01:11 xembedsniproxy[1448]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 502, resource id: 62914568, major code: 7 (ReparentWindow), minor code: 0
 janv. 07 10:01:11 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 2043, resource id: 62914568, major code: 12 (ConfigureWindow), minor code: 0
 janv. 07 10:01:10 ktraderclient5[1832]: kf.service.services: The desktop file "ServiceMenus/reimage-convert-rotate.desktop" references the action "agif" but doesn't define it
 janv. 07 10:01:09 plasmashell[1442]: Cyclic dependency detected between "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml" and "file:///usr/lib/qt/qml/org/kde/kirigami.2/styles/org.kde.desktop.plasma/Units.qml"
 janv. 07 10:01:09 plasmashell[1442]: file:///usr/share/plasma/wallpapers/com.github.zren.inactiveblur/contents/ui/WindowModel.qml:24:3: Unable to assign [undefined] to QRect
 janv. 07 10:01:09 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1198, resource id: 4194322, major code: 20 (GetProperty), minor code: 0
 janv. 07 10:01:09 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1118, resource id: 4194322, major code: 20 (GetProperty), minor code: 0
 janv. 07 10:01:09 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 1117, resource id: 4194322, major code: 20 (GetProperty), minor code: 0
 janv. 07 10:01:09 org_kde_powerdevil[1476]: QDBusConnection: name 'org.freedesktop.UDisks2' had owner '' but we thought it was ':1.49'
 janv. 07 10:01:09 org_kde_powerdevil[1476]: org.kde.powerdevil: Handle button events action could not check for screen configuration
 janv. 07 10:01:09 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 981, resource id: 60817412, major code: 18 (ChangeProperty), minor code: 0
 janv. 07 10:01:09 kwin_x11[1395]: qt.qpa.xcb: QXcbConnection: XCB error: 3 (BadWindow), sequence: 965, resource id: 50331652, major code: 18 (ChangeProperty), minor code: 0
 janv. 07 10:01:08 kded5[1387]: kscreen.kded: PowerDevil SuspendSession action not available!
 janv. 07 10:01:08 kded5[1387]: kscreen.kded: UPower not available, lid detection won't work
 janv. 07 10:01:07 plasma_session[1349]: org.kde.plasma.session: failed to parse "/home/alpha/.config/autostart/variety.desktop" for autostart
 janv. 07 10:01:07 plasma_session[1349]: org.kde.plasma.session: failed to parse "/home/alpha/.config/autostart/org.ksnip.ksnip.desktop" for autostart
 janv. 07 10:01:07 plasma_session[1349]: org.kde.plasma.session: failed to parse "/home/alpha/.config/autostart/redshift-gtk.desktop" for autostart
 janv. 07 10:01:07 kernel: ucsi_acpi USBC000:00: PPM NOT RESPONDING
 janv. 07 10:01:07 ksmserver[1426]: Qt: Session management error: networkIdsList argument is NULL
 janv. 07 10:01:06 kded5[1387]: org.kde.libkbolt: Failed to connect to Bolt manager DBus interface:
 janv. 07 10:01:06 kcminit_startup[1379]: QDBusConnection: error: could not send signal to service "" path "//home/alpha/.kde4/share/config/kdeglobals" interface "org.kde.kconfig.notify" member "ConfigChanged": Invalid object path: //home/alpha/.kde4/share/config/kdeglobals
 janv. 07 10:01:05 klauncher[1375]: Connecting to deprecated signal QDBusConnectionInterface::serviceOwnerChanged(QString,QString,QString)
 janv. 07 10:01:05 NetworkManager[1357]: <warn>  [1610010065.6113] sup-iface[a3fc1a1934296979,0,wlp2s0]: call-p2p-cancel: failed with P2P cancel failed
 janv. 07 10:01:05 kernel: kauditd_printk_skb: 99 callbacks suppressed
 janv. 07 10:01:05 plasma_session[1349]: kf.config.core: "KConfigIni: In file /home/alpha/.config/autostart/setup-assistant.desktop, line 1: " Invalid entry (missing '=')
 janv. 07 10:01:05 systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
 janv. 07 10:01:04 systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Not generating service for XDG autostart app-redshift\x2dgtk-autostart.service, error parsing Exec= line: No such file or directory
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Not generating service for XDG autostart app-org.ksnip.ksnip-autostart.service, error parsing Exec= line: No such file or directory
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Not generating service for XDG autostart app-variety-autostart.service, error parsing Exec= line: No such file or directory
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /etc/xdg/autostart/klipper.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /etc/xdg/autostart/msm_kde_notifier.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/setup.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: /home/alpha/.config/autostart/org.kde.latte-dock.desktop:87: Unknown key name 'InitialPreference' in section 'Desktop Entry', ignoring.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/xdman.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/variety.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/setup-assistant.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/redshift-gtk.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/org.ksnip.ksnip.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 systemd-xdg-autostart-generator[1001]: Configuration file /home/alpha/.config/autostart/libinput-gestures.desktop is marked executable. Please remove executable permission bits. Proceeding anyway.
 janv. 07 10:01:04 sddm-helper[969]: gkr-pam: no password is available for user
 janv. 07 10:01:03 systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
 janv. 07 10:01:02 systemd[1]: wg-quick@bluespace.service: Failed with result 'exit-code'.
 janv. 07 10:01:02 systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
 janv. 07 10:01:01 systemd[1]: NetworkManager-wait-online.service: Failed with result 'signal'.
 janv. 07 10:01:01 systemd[1]: NetworkManager-wait-online.service: Main process exited, code=killed, status=15/TERM
 janv. 07 10:01:01 systemd-udevd[364]: controlC0: Process '/usr/bin/alsactl restore 0' failed with exit code 99.
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEAutoconnecttimeout” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionSupervisionTimeout” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEConnectionLatency” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEMaxConnectionInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEMinConnectionInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowConnect” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalConnect” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAdvMonitor” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAdvMonitor” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowDiscovery” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalDiscovery” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowSuspend” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalSuspend” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanWindowAutoConnect” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEScanIntervalAutoConnect” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEMultiAdvertisementRotationInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEMaxAdvertisementInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “LEMinAdvertisementInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRMaxSniffInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRMinSniffInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRPageTimeout” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRLinkSupervisionTimeout” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanWindow” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRInquiryScanType” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanWindow” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanInterval” in group “Controller”
 janv. 07 10:01:01 bluetoothd[520]: src/main.c:parse_controller_config() Key file does not have key “BRPageScanType” in group “Controller”
 janv. 07 10:01:01 systemd-udevd[358]: cfg80211: Process '/usr/bin/set-wireless-regdom' failed with exit code 1.
 janv. 07 10:01:01 systemd[1]: Dependency failed for Swap.
 janv. 07 10:01:01 systemd[1]: swapfile.swap: Failed with result 'exit-code'.
 janv. 07 10:01:01 kernel: thermal thermal_zone5: failed to read out thermal zone (-61)
 janv. 07 10:01:00 kernel: caller snb_uncore_imc_init_box+0x74/0xb0 [intel_uncore] mapping multiple BARs
 janv. 07 10:01:00 kernel: resource sanity check: requesting [mem 0xfed10000-0xfed15fff], which spans more than pnp 00:08 [mem 0xfed10000-0xfed13fff]
 janv. 07 10:01:00 systemd-vconsole-setup[334]: Fonts will not be copied to remaining consoles
 janv. 07 10:01:00 systemd-vconsole-setup[334]: KD_FONT_OP_GET failed while trying to get the font metadata: Argument invalide
 janv. 07 10:01:00 kernel: VBoxNetFlt: Successfully started.
 janv. 07 10:01:00 kernel: VBoxNetAdp: Successfully started.
 janv. 07 10:01:00 systemd[1]: Dependency failed for Swap.
 janv. 07 10:01:00 kernel: vboxdrv: loading out-of-tree module taints kernel.
 janv. 07 10:01:00 systemd[1]: swapfile.swap: Failed with result 'exit-code'.
 janv. 07 10:01:00 systemd[1]: /usr/lib/systemd/system/plymouth-start.service:15: Unit configured to use KillMode=none. This is unsafe, as it disables systemd's process lifecycle management for the service. Please update your service to use a safer KillMode=, such as 'mixed' or 'control-group'. Support for KillMode=none is deprecated and will eventually be removed.
 janv. 07 10:01:00 kernel: mce: CPU0: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU4: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU3: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU7: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU2: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU6: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU5: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU1: Package temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU4: Core temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: mce: CPU0: Core temperature above threshold, cpu clock throttled (total events = 1)
 janv. 07 10:01:00 kernel: usb: port power management may be unreliable
 janv. 07 10:01:00 kernel: ACPI Warning: \_SB.PCI0.GFX0._DSM: Argument #4 type mismatch - Found [Buffer], ACPI requires [Package] (20190816/nsarguments-59)
 janv. 07 10:01:00 kernel: acpi PNP0C14:04: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
 janv. 07 10:01:00 kernel: acpi PNP0C14:03: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
 janv. 07 10:01:00 kernel: acpi PNP0C14:02: duplicate WMI GUID 05901221-D566-11D1-B2F0-00A0C9062910 (first instance was on PNP0C14:01)
 janv. 07 10:01:00 kernel: CRAT table not found
 janv. 07 10:01:00 kernel: nvme nvme0: missing or invalid SUBNQN field.
 janv. 07 10:01:00 kernel: ENERGY_PERF_BIAS: Set to 'normal', was 'performance'
 janv. 07 10:01:00 kernel:  #5 #6 #7
 janv. 07 10:01:00 kernel: MDS CPU bug present and SMT on, data leak possible. See https://www.kernel.org/doc/html/latest/admin-guide/hw-vuln/mds.html for more details.
 UUID=BAE9-E466                            /boot/efi      vfat    umask=0077 0 2
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /              btrfs   subvol=@,defaults,noatime,space_cache,autodefrag,compress=zstd 0 1
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /home          btrfs   subvol=@home,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /root          btrfs   subvol=@root,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /srv           btrfs   subvol=@srv,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /var/cache     btrfs   subvol=@cache,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /var/log       btrfs   subvol=@log,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
 /dev/mapper/luks-0d2bfdf1-3973-433f-b488-cf9adb545f63 /var/tmp       btrfs   subvol=@tmp,defaults,noatime,space_cache,autodefrag,compress=zstd 0 2
 /swapfile                                 swap           swap    defaults,noatime 0 0
AFAIK it should not. But it seems swapfile could not be created. IIRC systemd-swap or systemd-zram is used to auto-create swapfile at start. Can you check which service is failing to do this? And relevant conf settings?
LVM setup is not a usual scheme and I guess not heavily tested on Garuda ISO profiles. You have to investigate this a bit and give feedback, so we can fix any wrong default setting/script.
Have you chosen auto-login during install?
Have you migrated any of your Arch install settings/config etc. that might conflict?
You may disable one or more of udev rules or tmpfiles auto settings, to start eliminating one by one the possible issues.
In this flood of messages, some would be triggered from a previous issue, but we can't say for sure.
Check what timestamp was boot start, so we know if and which connect to your later freezing and not just boot issues.
I forgot... Test another kernel!!!!
There is a section in Arch wiki dedicated to swap file on Btrfs
https://wiki.archlinux.org/index.php/Btrfs#Swap_file
Does the ISO setup follow this process?
It also says
The swap file cannot be on a snapshotted subvolume. The proper procedure is to create a new subvolume to place the swap file in.
I tried the subvolume way but it wouldn't work because the sub-volume of a sub-volume cannot have different attributes (compression/noCoW).
I then found this nice post that gave me the solution: [SOLVED] Swapfile on BTRFS filesystem with compression enabled / Kernel & Hardware / Arch Linux Forums
# sudo su
# truncate -s 0 /mnt/swapfile
# chattr +C /mnt/swapfile
# btrfs property set /mnt/swapfile compression none
# fallocate -l 4G /mnt/swapfile
# chmod 600 /mnt/swapfile
# lsattr /mnt/swapfile
# mkswap /mnt/swapfile
# swapon /mnt/swapfile
I then modified /etc/fstab with the right path:
/mnt/swapfile swap swap defaults,noatime 0 0
Swap using the swapfile is now active.
 # swapon --show
 NAME          TYPE      SIZE USED  PRIO
 /mnt/swapfile file        4G   0B    -2
 /dev/zram0    partition 1,9G   0B 32767
 /dev/zram1    partition 1,9G   0B 32767
 /dev/zram2    partition 1,9G   0B 32767
 /dev/zram3    partition 1,9G   0B 32767
 /dev/zram4    partition 1,9G   0B 32767
 /dev/zram5    partition 1,9G   0B 32767
 /dev/zram6    partition 1,9G   0B 32767
 /dev/zram7    partition 1,9G   0B 32767
So now does it make any sense to have 15GB swap in zram and 4GB swap in a swap file?
Yes we create the swapfile in @cache subvoulume which is /var/cache directory
Do you mean in Calamares?
But as mentioned, Calamares (auto)uses /var/cache for swapfile.
Have you changed fstab manually and when?
Is there a swapfile at /@/cache/?
I checked a box in the installer from the installer indicating that I wanted to use a swap file in addition to encrypted Btrfs filesystem.
I didn't change /etc/fstab after installation so it contained the following from day 1:
I do confirm that there is swapfile (536MB) found in /var/cache/swapfile. I think the installer indicated that the swapfile was going to be 2GB large.
I went ahead and reverted my changes except the /etc/fstab so it points to /var/cache/swapfile instead of /swapfile and it worked.
Looking at the source it looks like that a 512MB swapfile is hardcoded
 desired_size = 512 * 1024 * 1024  # 512MiB
Is there any benefit on increasing the size of that swapfile from 512MB to 2-4GB and thus considering my setup (16GB RAM)?
Regarding the default location of the swapfile in fstab defined in Calamares, it looks like that it is fixed to /swapfile:
 if swap_choice:
    swap_choice = swap_choice.get( "swap", None )
    if swap_choice and swap_choice == "file":
        # There's no formatted partition for it, so we'll sneak in an entry
        partitions.append( dict(fs="swap", mountPoint=None, claimed=True, device="/swapfile", uuid=None) )
    else:
        swap_choice = None
The usual benefit of possible hibernation, but I haven't doublechecked this for btrfs setup.
@librewish Can you check this, please? Has it been tested?
Hmm well i have not tested as i dont use any swap file/partition
As zram s enough for me.
Fallocate has been deprecated, using that method can itself cause problems. Using dd is now the recommended method.
Seem a bit on the high side?
Not for a laptop
Is this issue in all kernels or only tkg kernel?
I also tried lts and zen kernels and experienced the same issues. KDE will hang for few seconds without being able to click on anything.
I also went back xrender as back-end for the compositor and even disabled ananicy but that didn't help.
I'm at a point where I'm considering going back to a vanilla Archlinux because my machine is not predictable anymore. Maybe the btrfs+snapshot every hour is too much for my configuration.
