Seems about 2-3 weeks ago a new issue started and I wanted to share my workaround.
The Issue: When waking up the computer with the HDMI display plugged in but turned off, the desktop is drawn on screen and machine OS freezes (mouse cursor won't move for example) after turning on the display.
The Workaround: Make sure the display is turned on first and fully ready (mine says "no signal" once it's ready) and then wake the computer.
Kernel: 6.1.43-1-lts arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=e0430201-0931-4d49-a5a8-f8a1445e4ab0 rw rootflags=subvol=@
resume=UUID=ae0cdb3c-2994-4db6-8822-7960e6e25fe8 loglevel=3 ibt=off
Type: Laptop System: Apple product: MacBookAir7,2 v: 1.0
serial: <superuser required> Chassis: type: 9 v: Mac-937CB26E2E02BB01
Mobo: Apple model: Mac-937CB26E2E02BB01 v: MacBookAir7,2
serial: <superuser required> UEFI: Apple v: 476.0.0.0.0 date: 09/06/2022
ID-1: BAT0 charge: 50.7 Wh (97.9%) condition: 51.8/54.3 Wh (95.3%)
volts: 8.5 min: 7.6 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 692
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
Info: model: Intel Core i5-5350U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 2300 high: 2900 min/max: 500/2900 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2900 2: 1700 3: 2900
4: 1700 bogomips: 14407
Device-1: Intel HD Graphics 6000 vendor: Apple driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: HDMI-A-1
off: eDP-1 empty: DP-1,DP-2,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1626
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (19.96x11.22")
s-diag: 582mm (22.9")
Monitor-1: HDMI-A-1 mapped: HDMI-1 pos: primary model: LG (GoldStar) TV
serial: <filter> built: 2019 res: 1920x1080 hz: 120 dpi: 30 gamma: 1.2
size: 1600x900mm (62.99x35.43") diag: 1836mm (72.3") ratio: 16:9 modes:
max: 4096x2160 min: 720x400
Monitor-2: eDP-1 note: disabled model: Apple Color LCD built: 2015
res: 1920x1080 dpi: 128 gamma: 1.2 size: 286x179mm (11.26x7.05")
diag: 337mm (13.3") ratio: 16:10 modes: 1440x900
API: OpenGL v: 4.6 Mesa 23.1.5 renderer: Mesa Intel HD Graphics 6000 (BDW
GT3) direct-render: Yes
Device-1: Intel Broadwell-U Audio vendor: Apple driver: snd_hda_intel
Device-3: Broadcom 720p FaceTime HD Camera driver: facetimehd v: kernel
pcie: gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 02:00.0 chip-ID: 14e4:1570
class-ID: 0480
API: ALSA v: k6.1.43-1-lts status: kernel-api with: aoss
Server-2: PipeWire v: 0.3.77 status: active with: 1: pipewire-pulse
Device-1: Broadcom BCM4360 802.11ac Wireless Network Adapter vendor: Apple
bus-ID: 03:00.0 chip-ID: 14e4:43a0 class-ID: 0280
Device-1: Apple Bluetooth USB Host Controller driver: btusb v: 0.8 type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3:10
chip-ID: 05ac:828f class-ID: fe01
Local Storage: total: 233.76 GiB used: 164.64 GiB (70.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apple model: SSD SM0256G
size: 233.76 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 3A0Q scheme: GPT
ID-1: / raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
used: 164.64 GiB (73.3%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-4: /var/log raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 224.66 GiB size: 224.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.66 GiB used: 938.9 MiB (12.0%)
dev: /dev/sda3 maj-min: 8:3
System Temperatures: cpu: 61.0 C pch: 69.0 C mobo: N/A
Processes: 248 Uptime: 18h 0m wakeups: 31 Memory: total: 8 GiB
available: 7.66 GiB used: 3.83 GiB (49.9%) Init: systemd v: 254
default: graphical tool: systemctl Compilers: gcc: 13.2.1 clang: 15.0.7
Packages: pm: pacman pkgs: 2237 libs: 603 tools: octopi,pamac,paru,pikaur
Shell: fish v: 3.6.1 running-in: konsole inxi: 3.3.28
System install date: 2022-12-02
Last full system update: 2023-08-08
Relevant software: snapper NetworkManager dracut(custom) mkinitcpio
My display is an LG C9.
