Hello.
As the title says sometimes when I open an app or minimize/maximize something my whole system freezes. I can't put it to sleep or anything, all I can do is force shut it down by holding the power button. My friend said that maybe it's an issue with SWAP but I don't know what to do with that information.
Kernel: 5.16.2-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d454fcf1-f3b8-4e97-b018-0fbe02a026de rw rootflags=subvol=@
resume=UUID=f793db8a-e31a-4f81-8b69-7ba9b796aea6 loglevel=3 splash quiet
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk1xxx
Mobo: HP model: 8741 v: 02.34 serial: <superuser required> UEFI: Insyde
v: F.21 date: 01/08/2021
ID-1: BAT1 charge: 42.1 Wh (100.0%) condition: 42.1/52.5 Wh (80.2%)
volts: 12.9 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: Full
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
family: 6 model-id: 0xA5 (165) stepping: 2 microcode: 0xEA
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 899 high: 900 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 899 6: 900 7: 900 8: 900 9: 900 10: 900 11: 900 12: 900
bogomips: 62399
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Hewlett-Packard
driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU116M [GeForce GTX 1660 Ti Mobile]
vendor: Hewlett-Packard driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2191
Device-3: Chicony HP Wide Vision HD Camera type: USB driver: uvcvideo
bus-ID: 1-5:3 chip-ID: 04f2:b627 class-ID: 0e02
loaded: modesetting,nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 3600x1080 s-dpi: 96 s-size: 950x285mm (37.4x11.2")
s-diag: 992mm (39")
Monitor-1: eDP-1 res: 1920x1080 hz: 144 dpi: 142
Monitor-2: HDMI-1-0 res: 1680x1050 hz: 60 dpi: 89
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: Mesa Intel UHD Graphics (CML GT2) v: 4.6 Mesa 21.3.4
direct render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Hewlett-Packard
Device-2: NVIDIA TU116 High Definition Audio vendor: Hewlett-Packard
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:1aeb
Sound Server-1: ALSA v: k5.16.2-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
vendor: Hewlett-Packard driver: r8169 v: kernel port: 3000 bus-ID: 07:00.0
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
v: 3.0 port: 5060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: class-ID: 0104
Local Storage: total: 1.14 TiB used: 760.38 GiB (65.0%)
model: MZVLB256HBHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
rev: HPS0NEXH temp: 39.9 C scheme: GPT
model: WD10SPSX-60A6WT0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-1: / raw-size: 221.2 GiB size: 221.2 GiB (100.00%)
used: 188.33 GiB (85.1%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 221.2 GiB size: 221.2 GiB (100.00%)
ID-4: /var/log raw-size: 221.2 GiB size: 221.2 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.2 GiB size: 221.2 GiB (100.00%)
ID-1: swap-1 type: partition size: 16.97 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.43 GiB used: 2.5 MiB (0.0%)
System Temperatures: cpu: 56.0 C pch: 53.0 C mobo: 10.0 C
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 366 Uptime: 6m wakeups: 1 Memory: 15.43 GiB
used: 4.51 GiB (29.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: 1951 pacman: 1942 lib: 505 flatpak: 9
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: yakuake
inxi: 3.3.12
Garuda:
System install date: 2021-11-27
Last full system update: 2022-02-06
Using TLP: No
