Hello Community. I installed MX Linux on my computer before and when I installed FreeFileSync it worked. In all arch Linux based distributions this app definitely didn't work. The console output is as follows:
[[email protected] freefilesync]$ ./FreeFileSync
(FreeFileSync_x86_64:29957): Gtk-WARNING **: 09:45:19.472: Unable to locate theme engine in module_path: "adwaita",
Error starting "/opt/freefilesync/Bin/FreeFileSync_x86_64".
Killed by signal 11
What can I do about it? can you help me?
Hello.
[[email protected] ~]$ garuda-inxi
Kernel: 5.15.25-1-lts x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=fb50af85-bcb9-4145-b5fd-348a0bc6ce55 rw [email protected]
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: INTEL model: H61 serial: <superuser required>
BIOS: American Megatrends v: 4.6.5 date: 12/30/2020
Info: model: Intel Core i5-3470 bits: 64 type: MCP arch: Ivy Bridge
family: 6 model-id: 0x3A (58) stepping: 9 microcode: 0x21
desc: 1x6 MiB
Speed (MHz): avg: 2758 high: 3594 min/max: 1600/3600 scaling:
driver: intel_cpufreq governor: performance cores: 1: 2283 2: 2833 3: 3594
4: 2324 bogomips: 25541
Type: l1tf
IBRS_FW, STIBP: disabled, RSB filling
Device-1: Intel Xeon E3-1200 v2/3rd Gen Core processor Graphics
driver: i915 v: kernel ports: active: HDMI-A-1 empty: DP-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0152 class-ID: 0300
loaded: intel unloaded: modesetting alternate: fbdev,vesa gpu: i915
s-diag: 582mm (22.9") monitors: <missing: xrandr>
Monitor-1: HDMI-A-1 model: LG (GoldStar) FULL HD built: 2016
res: 1920x1080 dpi: 102 gamma: 1.2 size: 480x270mm (18.9x10.6")
diag: 551mm (21.7") ratio: 16:9 modes: max: 1920x1080 min: 720x400
OpenGL: renderer: Mesa DRI Intel HD Graphics 2500 (IVB GT1)
v: 4.2 Mesa 21.3.7 compat-v: 3.0 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Sound Server-1: ALSA v: k5.15.25-1-lts running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.47 running: yes
Device-1: Realtek RTL810xE PCI Express Fast Ethernet driver: r8169
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: e000 bus-ID: 02:00.0
Local Storage: total: 252.8 GiB used: 11.91 GiB (4.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: TwinMOS model: SSD size: 238.47 GiB
block-size: physical: 512 B logical: 512 B speed: 3.0 Gb/s type: SSD
serial: <filter> rev: 0A0 scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 type: USB vendor: SanDisk
model: Cruzer Force size: 14.32 GiB block-size: physical: 512 B
logical: 512 B type: N/A serial: <filter> rev: 1.00 scheme: MBR
ID-1: / raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
used: 11.91 GiB (5.0%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-3: /var/log raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-4: /var/tmp raw-size: 238.47 GiB size: 238.47 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 29.8 C mobo: 27.8 C
Processes: 233 Uptime: 26m wakeups: 0 Memory: 7.65 GiB
used: 3.1 GiB (40.5%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1355 lib: 376 Shell: Bash
v: 5.1.16 running-in: alacritty inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-26
Last full system update: 2022-02-27
