Hello Forza Horizon 4 game does not open in Garuda Dragonized version. It stays on the running screen.
Hello. I’ve moved your topic from Garuda Community to the appropriate category.
Since you might of not read the template when posting in the wrong category, I’ll post it here again for you to read and follow:
Missing information requested in the template may result in not receiving assistance
- Search the web and forums
- Read How to search for solutions the right way | Garuda Linux wiki
- Read FAQ and Tutorials Table of Contents
Issue still unresolved? Then:
- ONE issue per topic.
- Describe your issue in detail. The more we know, the better we can help
- Show us the results of your searches, and what you’ve tried
in the body of the post (not linked externally, or collapsed with the “hide details” feature) - Format terminal output (including your
) as a code block by clicking the preformatted text button (</>) , or put three tildes (~) above and below the text
If you are trying to run the game on Steam using Proton, be sure to check the reports at https://www.protondb.com/app/1293830
