Wow..how embarrassing...no wonder none of the girls around here will talk to me....
╭─user@garudabox in ~ took 1h38m49s
╰─λ sudo inxi -Fmxxxza
[sudo] password for user:
System: Kernel: 5.12.1-zen2-1-zen x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=de1f82b3-7c78-4cea-8f6f-f5aab801ec50
Console: tty pts/0 wm: kwin_x11 DM: SDDM Distro: Garuda Linux base: Arch Linux
Machine: Type: Laptop System: LENOVO product: 20AN009CUS v: ThinkPad T440p serial: <filter> Chassis:
type: 10 serial: <filter>
Mobo: LENOVO model: 20AN009CUS v: 0B98401 PRO serial: <filter> UEFI: LENOVO v: GLETA1WW (2.55 )
date: 04/20/2020
Battery: ID-1: BAT0 charge: 18.7 Wh (38.4%) condition: 48.7/56.2 Wh (86.6%) volts: 11.4 min: 10.8
model: LGC 45N1147 type: Li-ion serial: <filter> status: Charging
Memory: RAM: total: 15.51 GiB used: 4.74 GiB (30.6%)
Array-1: capacity: 16 GiB slots: 2 EC: None max-module-size: 8 GiB note: est.
Device-1: ChannelA-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous
bus-width: 64 bits total: 64 bits manufacturer: 1324 part-no: N/A serial: N/A
Device-2: ChannelB-DIMM0 size: 8 GiB speed: 1600 MT/s type: DDR3 detail: synchronous
bus-width: 64 bits total: 64 bits manufacturer: 0000 part-no: N/A serial: N/A
CPU: Info: Quad Core model: Intel Core i7-4700MQ socket: rPGA988B (U3E1) note: check bits: 64
type: MT MCP arch: Haswell family: 6 model-id: 3C (60) stepping: 3 microcode: 28 cache:
L1: 64 KiB L2: 6 MiB L3: 6 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 38314
Speed: 2391 MHz min/max: 800/3400 MHz base/boost: 2400/2400 volts: 0.8 V ext-clock: 100 MHz
Core speeds (MHz): 1: 2391 2: 2393 3: 2395 4: 2395 5: 2395 6: 2389 7: 2395 8: 2395
Graphics: Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo driver: i915
v: kernel bus-ID: 00:02.0 chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK208M [GeForce GT 730M] vendor: Lenovo driver: nouveau v: kernel
bus-ID: 02:00.0 chip-ID: 10de:1290 class-ID: 0300
Device-3: Acer SunplusIT Integrated Camera type: USB driver: uvcvideo bus-ID: 2-12:5
chip-ID: 5986:0268 class-ID: 0e02
Display: server: X.Org 1.20.11 compositor: kwin_x11 driver: loaded: intel,nouveau
unloaded: modesetting alternate: fbdev,nv,vesa display-ID: :0 screens: 1
Monitor-1: eDP1 res: 1920x1080 hz: 60 dpi: 157 size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
OpenGL: renderer: Mesa DRI Intel HD Graphics 4600 (HSW GT2) v: 4.5 Mesa 21.0.3 compat-v: 3.0
direct render: Yes
Audio: Device-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio vendor: Lenovo ThinkPad T440p
driver: snd_hda_intel v: kernel bus-ID: 00:03.0 chip-ID: 8086:0c0c class-ID: 0403
Device-2: Intel 8 Series/C220 Series High Definition Audio vendor: Lenovo ThinkPad T440p
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8c20 class-ID: 0403
Sound Server-1: ALSA v: k5.12.1-zen2-1-zen running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Intel Ethernet I217-LM vendor: Lenovo ThinkPad T440p driver: e1000e v: kernel
port: 4080 bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel port: 3000 bus-ID: 04:00.0
chip-ID: 8086:08b2 class-ID: 0280
Device-3: Ralink MT7601U Wireless Adapter type: USB driver: mt7601u bus-ID: 2-6:2
chip-ID: 148f:7601 class-ID: 0000 serial: <filter>
IF: wlp0s20u6 state: up mac: <filter>
Bluetooth: Device-1: Intel Bluetooth wireless interface type: USB driver: btusb v: 0.8 bus-ID: 2-11:4
chip-ID: 8087:07dc class-ID: e001
Report: bt-adapter ID: hci0 rfk-id: 8 state: up address: <filter>
Drives: Local Storage: total: 931.51 GiB used: 527.89 GiB (56.7%)
ID-1: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
family: Travelstar 7K1000 size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
sata: 3.0 speed: 6.0 Gb/s rotation: 7200 rpm serial: <filter> rev: A3U0 temp: 39 C scheme: GPT
SMART: yes state: enabled health: PASSED on: 347d 8h cycles: 3037
Partition: ID-1: / raw-size: 24 GiB size: 24 GiB (100.00%) used: 19.95 GiB (83.1%) fs: btrfs
block-size: 4096 B dev: /dev/sda5 maj-min: 8:5
ID-2: /boot/efi raw-size: 100 MiB size: 98.4 MiB (98.42%) used: 546 KiB (0.5%) fs: vfat
block-size: 512 B dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 40 GiB size: 40 GiB (100.00%) used: 462.2 MiB (1.1%) fs: btrfs
block-size: 4096 B dev: /dev/sda6 maj-min: 8:6
ID-4: /var/log raw-size: 24 GiB size: 24 GiB (100.00%) used: 19.95 GiB (83.1%) fs: btrfs
ID-5: /var/tmp raw-size: 24 GiB size: 24 GiB (100.00%) used: 19.95 GiB (83.1%) fs: btrfs
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda3
maj-min: 8:3
ID-2: swap-2 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.94 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
Sensors: System Temperatures: cpu: 54.0 C mobo: 0.0 C gpu: nouveau temp: 49.0 C
Fan Speeds (RPM): cpu: 2734
Info: Processes: 273 Uptime: 1d 45m wakeups: 12 Init: systemd v: 248 tool: systemctl Compilers:
gcc: 11.1.0 clang: 11.1.0 Packages: pacman: 1766 lib: 335 Shell: fish (sudo) v: 3.2.1
default: Bash v: 5.1.4 running-in: konsole inxi: 3.3.04
