Hello.
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=f8db34a7-2ded-4c56-a778-9d9440007d33 rw rootflags=subvol=@
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Desktop Mobo: ASUSTeK model: P7H55-M v: Rev X.0x
serial: <superuser required> BIOS: American Megatrends v: 1302
date: 04/25/2011
Info: model: Intel Core i3 540 bits: 64 type: MT MCP arch: Westmere
family: 6 model-id: 0x25 (37) stepping: 5 microcode: 0x7
L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 3044 high: 3077 min/max: N/A cores: 1: 2947 2: 3077
3: 3077 4: 3077 bogomips: 24619
Type: l1tf
Type: mds status: Vulnerable: Clear CPU buffers attempted, no microcode;
SMT vulnerable
Device-1: NVIDIA GM206 [GeForce GTX 950] vendor: Micro-Star MSI
driver: nvidia v: 510.54 alternate: nouveau,nvidia_drm bus-ID: 01:00.0
chip-ID: 10de:1402 class-ID: 0300
loaded: nvidia unloaded: modesetting,nouveau alternate: fbdev,nv,vesa
Screen-1: 0 s-res: 2390x1280 s-dpi: 84 s-size: 723x387mm (28.5x15.2")
s-diag: 820mm (32.3")
Monitor-1: HDMI-0 res: 1366x768 hz: 60 dpi: 85
size: 409x230mm (16.1x9.1") diag: 469mm (18.5")
Monitor-2: DVI-D-0 res: 1024x1280
OpenGL: renderer: NVIDIA GeForce GTX 950/PCIe/SSE2 v: 4.6.0 NVIDIA 510.54
direct render: Yes
Device-1: Intel 5 Series/3400 Series High Definition Audio vendor: ASUSTeK
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:3b56
Device-2: NVIDIA GM206 High Definition Audio vendor: Micro-Star MSI
driver: snd_hda_intel v: kernel bus-ID: 01:00.1 chip-ID: 10de:0fba
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
vendor: ASUSTeK P8P67 and other motherboards driver: r8169 v: kernel
port: d800 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
driver: btusb v: 0.8 bus-ID: 2-1.4.1.2:6 chip-ID: 0a12:0001 class-ID: fe01
Local Storage: total: 763.85 GiB used: 109.05 GiB (14.3%)
ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST500LT012-9WS142
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM1
scheme: MBR
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST320LT012-1DG14C
size: 298.09 GiB block-size: physical: 4096 B logical: 512 B
speed: 3.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: LVM1
scheme: MBR
ID-1: / raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
used: 109.05 GiB (36.6%) fs: btrfs dev: /dev/sdb1 maj-min: 8:17
ID-2: /home raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
ID-3: /var/log raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
ID-4: /var/tmp raw-size: 298.09 GiB size: 298.09 GiB (100.00%)
ID-1: swap-1 type: zram size: 3.39 GiB used: 1.21 GiB (35.6%)
System Temperatures: cpu: 44.0 C mobo: 30.0 C gpu: nvidia temp: 31 C
Fan Speeds (RPM): cpu: 2163 case-1: 0 gpu: nvidia fan: 42%
Power: 12v: 12.32 5v: N/A 3.3v: 3.33 vbat: N/A
Processes: 233 Uptime: 3h 38m wakeups: 0 Memory: 3.39 GiB
used: 2.43 GiB (71.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1786 lib: 518 Shell: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.12
Garuda (2.5.5-1):
System install date: 2022-02-22
Last full system update: 2022-02-25
Failed units: garuda-system-maintenance@keyring.service
I had a problem with forced closing of programs (presumably as a measure of protection against OOM). I wanted to get rid of this by removing nohang, but even after I removed nohang, I cleared all directories that mentioned nohang (by removing the package with " paru -Rss nohang "
,after deleted all directories with the name of the package
" find. -name 'nohang' ")
, and this did not lead to any result, except that the notification about the lack of memory was gone, but the programs still closed.
