So essentially because I can’t upload image I will describe it in short. On regular dekstop everything is fine and font is being displayed correctly, when launching any application everything on top bar becomes black and unreadable, no settings or anything. I’m new to garuda linux (very happy with it btw) dragonized, Ive used to have it in the past for short period and I remember things are suppoused to be displayed in the top bar. How do I fix it? I tried to search for similar issues but didnt find anything, also sorry if it’s a common issue and I’m noob.
root=UUID=85224345-b847-4806-8bca-8934aaae6d95 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.4 tk: Qt v: N/A info: frameworks v: 6.12.0
Type: Laptop System: HP product: HP Pavilion Gaming Laptop 15-dk0xxx
Mobo: HP model: 85FC v: 42.47 serial: <superuser required>
part-nu: 8RQ33EA#ACB uuid: <superuser required> UEFI: Insyde v: F.68
date: 10/09/2024
ID-1: BAT1 charge: 44.5 Wh (100.0%) condition: 44.5/52.5 Wh (84.7%)
volts: 12.7 min: 11.6 model: Hewlett-Packard PABAS0241231 type: Li-ion
serial: <filter> status: full
Info: model: Intel Core i5-9300H bits: 64 type: MT MCP arch: Coffee Lake
Speed (MHz): avg: 4000 min/max: 800/4100 scaling: driver: intel_pstate
governor: performance cores: 1: 4000 2: 4000 3: 4000 4: 4000 5: 4000 6: 4000
7: 4000 8: 4000 bogomips: 38400
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Hewlett-Packard
ports: active: eDP-1 empty: DP-2,HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 570.133.07
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 3
speed: 8 GT/s lanes: 16 ports: active: none empty: DP-1,HDMI-A-1
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Device-3: Lite-On HP Wide Vision HD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3 chip-ID: 04ca:707f
display-ID: 0
Monitor-1: eDP-1 model: AU Optronics 0x20ed built: 2018 res:
modes: 1920x1080
drv: iris x11: drv: iris
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 25.0.3-arch1.1
GT2) device-ID: 8086:3e9b memory: 3.65 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.4.309 layers: 14 device: 0 type: integrated-gpu
name: Intel UHD Graphics 630 (CFL GT2) driver: N/A device-ID: 8086:3e9b
surfaces: xcb,xlib,wayland device: 1 type: discrete-gpu
name: NVIDIA GeForce GTX 1650 driver: N/A device-ID: 10de:1f91
Device-2: NVIDIA vendor: Hewlett-Packard driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: lanes: 16 bus-ID: 01:00.1
chip-ID: 10de:10fa class-ID: 0403
API: ALSA v: k6.13.8-zen1-1-zen status: kernel-api with: aoss
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822BE 802.11a/b/g/n/ac WiFi adapter
vendor: Hewlett-Packard driver: rtw_8822be v: N/A modules: rtw88_8822be
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 05:00.0
chip-ID: 10ec:b822 class-ID: 0280
Device-1: Realtek Bluetooth 4.2 Adapter driver: btusb v: 0.8 type: USB
rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:4 chip-ID: 0bda:b00b
v: 3.0 port: 6060 bus-ID: 00:17.0 chip-ID: 8086:282a rev: N/A class-ID: 0104
Local Storage: total: 704.24 GiB used: 339.73 GiB (48.2%)
model: MZVLB256HAHQ-000H1 size: 238.47 GiB block-size: physical: 512 B
fw-rev: EXD70H1Q temp: 29.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
size: 465.76 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.2 spd: 10 Gb/s lanes: 1 mode: 3.2 gen-2x1 tech: SSD
serial: <filter> scheme: MBR
ID-1: / raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
used: 49.38 GiB (20.7%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
ID-4: /var/log raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
ID-5: /var/tmp raw-size: 238.18 GiB size: 238.18 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.47 GiB used: 160.8 MiB (2.1%)
max-streams: 8 dev: /dev/zram0
System Temperatures: cpu: 63.0 C pch: 59.0 C mobo: N/A
Memory: total: 8 GiB note: est. available: 7.47 GiB used: 5.14 GiB (68.8%)
Processes: 307 Power: uptime: 2h 32m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 2.92 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1767 libs: 533 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 Shell: garuda-inxi default: fish v: 4.0.1
System install date: 2025-04-02
Last full system update: 2025-04-06 ↻
