So I have updated my system recently , then I have rebooted. After reboot the fonts in my konsol e are displaying misplaced. Any idea why its happening ?? Also how to fix it ? There is a screenshot - https://i.imgur.com/nvHsX5q.png
Uhm, try to apply new configs from /etc/skel
ah, tell the cmd plox
You can use the Garuda Assistant button which says "apply new configs" (bottom)
This will overwrite your Latte pinned apps but you get the latest configs, pretty sure this will fix
This saved me !! Thanks , Problem solved
Thank you, this is an extremely useful piece of information, because I haven't even noticed this gray bar at the very bottom.
Applying these new configs from time to time is actually a good thing to do since these are evolving as well - cant apply dotfile changes via package upgrades so this is the only way Especially dr460nized is getting improved a lot
Ill probably add this information to the wiki soon.
