Hello, I am using the dragonized version and I insalled wayland. I do want to run some gtk apps like evolution. However, gtk apps are not rendering the fonts with anti-aliasing when running under wayland. Any idea how to fix this?
The output of garuda-inxi -
Kernel: 6.4.2-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.1.1
root=UUID=09ce385c-a26f-41b0-905a-514abf34f353 rw rootflags=subvol=@
resume=UUID=25cf5e5f-b9f4-44b2-953c-31a6931dda48 loglevel=3 ibt=off
Type: Laptop System: Dell product: Latitude 7490 v: N/A
Mobo: Dell model: 0KP0FT v: A00 serial: <superuser required> UEFI: Dell
v: 1.25.0 date: 03/24/2022
ID-1: BAT0 charge: 8.4 Wh (100.0%) condition: 8.4/42.0 Wh (20.1%)
volts: 12.2 min: 11.4 model: BYD DELL 9W9MX87 type: Li-ion serial: <filter>
status: full
Info: model: Intel Core i7-8650U bits: 64 type: MT MCP arch: Coffee Lake
model-id: 0x8E (142) stepping: 0xA (10) microcode: 0xF2
L3: 8 MiB desc: 1x8 MiB
Speed (MHz): avg: 1348 high: 1513 min/max: 400/4200 scaling:
driver: intel_pstate governor: powersave cores: 1: 1300 2: 1300 3: 1300
4: 1340 5: 1513 6: 1432 7: 1300 8: 1300 bogomips: 33599
Device-1: Intel UHD Graphics 620 vendor: Dell driver: i915 v: kernel
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:5917
Device-2: Sunplus Innovation Integrated_Webcam_HD driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:3
chip-ID: 1bcf:2b96 class-ID: 0e02
s-diag: 414mm (16.31")
Monitor-1: eDP-1 model: BOE Display 0x078d built: 2017 res: 1366x768
ratio: 16:9 modes: 1366x768
API: OpenGL v: 4.6 Mesa 23.1.3 renderer: Mesa Intel UHD Graphics 620 (KBL
GT2) direct-render: Yes
Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell driver: snd_hda_intel
v: kernel alternate: snd_soc_skl,snd_soc_avs bus-ID: 00:1f.3
API: ALSA v: k6.4.2-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.73 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I219-LM vendor: Dell driver: e1000e v: kernel
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15d7 class-ID: 0200
vendor: Dell driver: ath10k_pci v: kernel pcie: gen: 1 speed: 2.5 GT/s
lanes: 1 bus-ID: 02:00.0 chip-ID: 168c:003e class-ID: 0280 temp: 42.0 C
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:4 chip-ID: 0cf3:e007
Local Storage: total: 238.47 GiB used: 39.18 GiB (16.4%)
ID-1: /dev/sda maj-min: 8:0 vendor: SK Hynix model: SC311 SATA 256GB
size: 238.47 GiB block-size: physical: 4096 B logical: 512 B speed: 6.0 Gb/s
tech: SSD serial: <filter> fw-rev: 0P10 scheme: GPT
ID-1: / raw-size: 221.14 GiB size: 221.14 GiB (100.00%)
used: 39.18 GiB (17.7%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-3: /home raw-size: 221.14 GiB size: 221.14 GiB (100.00%)
ID-4: /var/log raw-size: 221.14 GiB size: 221.14 GiB (100.00%)
ID-5: /var/tmp raw-size: 221.14 GiB size: 221.14 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.48 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.03 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 62.0 C pch: 54.0 C mobo: N/A
Processes: 307 Uptime: 2h 43m wakeups: 13 Memory: available: 15.48 GiB
used: 7.17 GiB (46.3%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 13.1.1 Packages: pm: pacman pkgs: 1526
libs: 401 tools: octopi,paru Shell: fish v: 3.6.1 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.27
System install date: 2023-07-06
Last full system update: 2023-07-09
