Hello
I just get an issue with my terminal and my fonts. I don’t know why this is not working anymore.
I’ve also an issue with the «éèà»
For exemple
echo -e "\xee\x82\xa0"
: Synchronisation des bases de donn��es de paquets���
garuda est �� jour
core est �� jour
extra est �� jour
multilib est �� jour
chaotic-aur 758,8 KiB 716 KiB/s 00:01 [----------------------------------------------------------------------------------------] 100%
:: D��but de la mise �� jour compl��te du syst��me���
il n���y a rien �� faire
My garuda-inxi
Kernel: 6.6.42-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=ece8ff72-3221-4048-b7f2-fb09c55ff932 rw rootflags=subvol=@
Desktop: Xfce v: 4.18.1 tk: Gtk v: 3.24.43 wm: xfwm4 v: 4.18.0
with: plank,xfce4-panel tools: xfce4-screensaver avail: xautolock vt: 7
Mobo: ASUSTeK model: PRIME H510M-A v: Rev 1.xx
UEFI: American Megatrends v: 1017 date: 07/12/2021
Info: model: Intel Core i5-10400F bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 3 microcode: 0xFA
L3: 12 MiB desc: 1x12 MiB
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 69629
Device-1: NVIDIA GA106 [Geforce RTX 3050] vendor: Gigabyte driver: nvidia
v: 555.58.02 alternate: nouveau,nvidia_drm non-free: 550.xx+ status: current
(as of 2024-06; EOL~2026-12-xx) arch: Ampere code: GAxxx
process: TSMC n7 (7nm) built: 2020-2023 pcie: gen: 1 speed: 2.5 GT/s
lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-2 empty: DP-1,DP-2,HDMI-A-1 bus-ID: 01:00.0 chip-ID: 10de:2507
Display: x11 server: X.Org v: 21.1.13 compositor: xfwm4 v: 4.18.0 driver:
X: loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
gpu: nvidia,nvidia-nvswitch display-ID: :0.0 screens: 1
s-diag: 583mm (22.95")
Monitor-1: HDMI-A-2 mapped: HDMI-1 note: disabled
model: Philips PHL 243S5L serial: <filter> built: 2018 res: 1920x1080 hz: 60
dpi: 94 gamma: 1.2 size: 521x293mm (20.51x11.54") diag: 598mm (23.5")
inactive: wayland,device-1
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 3050/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.279 layers: 5 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 3050 driver: nvidia v: 555.58.02
device-ID: 10de:2507 surfaces: xcb,xlib
Device-1: Intel vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 00:1f.3 chip-ID: 8086:f0c8 class-ID: 0403
Device-2: NVIDIA GA106 High Definition Audio vendor: Gigabyte
API: ALSA v: k6.6.42-1-lts status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15fa class-ID: 0200
Local Storage: total: 2.37 TiB used: 2.01 TiB (84.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX6000NP
size: 119.24 GiB block-size: physical: 512 B logical: 512 B speed: 15.8 Gb/s
lanes: 2 tech: SSD serial: <filter> fw-rev: V6005-af temp: 52.9 C
ID-2: /dev/sda maj-min: 8:0 vendor: Crucial model: CT480BX500SSD1
tech: SSD serial: <filter> fw-rev: 054 scheme: GPT
ID-3: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST2000DM008-2FR102
tech: HDD rpm: 7200 serial: <filter> fw-rev: 0001 scheme: MBR
ID-1: / raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
used: 110.64 GiB (93.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 580 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-4: /var/log raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-5: /var/tmp raw-size: 118.95 GiB size: 118.95 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.47 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A gpu: nvidia temp: 47 C
Memory: total: 16 GiB available: 15.47 GiB used: 3.63 GiB (23.5%)
Processes: 356 Power: uptime: 1h 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.15 GiB services: upowerd,xfce4-power-manager
Packages: pm: pacman pkgs: 1827 libs: 583 tools: paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: Zsh v: 5.9
running-in: xfce4-terminal inxi: 3.3.35
System install date: 2022-03-18
Last full system update: 2024-07-29 ���
I try to
- regenerate the fonts with fc-cache -f -v
- Checked the fonts
- regenerate fr_FR local
If some one have any idea
Thanks
