Follow-up to systemd services questions a little while ago
Hi all,
I had a conversation here recently with another user about difficulties I was having running a drive-sync service on Garuda.
Before we start, I’ll say that I have RTFM, so snarky push-backs not appreciated. I’m trying to learn here, as an old bloke.
Anyway, here’s the mandatory thingy:
    root=UUID=a647ace3-ddca-4e7d-9dc2-e18c06df28dd rw rootflags=subvol=@
    loglevel=3 ibt=off
  Desktop: KDE Plasma v: 6.1.2 tk: Qt v: N/A info: frameworks v: 6.3.0
  Type: Laptop System: TUXEDO product: TUXEDO InfinityBook S Gen8 v: N/A
  Mobo: NB01 model: NS5X_NS7XAU serial: <superuser required>
    part-nu: IBSGEN8 uuid: <superuser required> UEFI: INSYDE v: 1.07.10RTR1
    date: 03/08/2024
  ID-1: BAT0 charge: 73.9 Wh (100.0%) condition: 73.9/73.9 Wh (100.0%)
    volts: 8.7 min: 7.7 model: Notebook BAT type: Li-ion serial: <filter>
    status: full
  Info: model: 13th Gen Intel Core i7-1360P bits: 64 type: MST AMCP
    arch: Raptor Lake level: v3 note: check built: 2022+ process: Intel 7 (10nm)
    family: 6 model-id: 0xBA (186) stepping: 2 microcode: 0x4121
  Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
    cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
    L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
  Speed (MHz): avg: 536 high: 809 min/max: 400/5000:3700 scaling:
    driver: intel_pstate governor: powersave cores: 1: 400 2: 724 3: 400 4: 783
    5: 747 6: 400 7: 809 8: 400 9: 400 10: 733 11: 400 12: 400 13: 795 14: 400
    15: 400 16: 400 bogomips: 83558
  Device-1: Intel Raptor Lake-P [Iris Xe Graphics] vendor: CLEVO/KAPOK
    driver: i915 v: kernel alternate: xe arch: Gen-13 process: Intel 7 (10nm)
    built: 2022+ ports: active: DP-5 off: eDP-1 empty: DP-1, DP-2, DP-3,
    DP-4, DP-6, DP-7, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:a7a0
  Monitor-1: DP-5 res: 1920x1080 size: N/A modes: N/A
    drv: iris inactive: gbm
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.3-arch1.1
    glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (RPL-P)
    device-ID: 8086:a7a0 memory: 15.16 GiB unified: yes display-ID: :1.0
  API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu
    name: Intel Graphics (RPL-P) driver: mesa intel v: 24.1.3-arch1.1
    device-ID: 8086:a7a0 surfaces: xcb,xlib,wayland device: 1 type: cpu
    v: 24.1.3-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
  Device-1: Intel Raptor Lake-P/U/H cAVS vendor: CLEVO/KAPOK
    bus-ID: 00:1f.3 chip-ID: 8086:51ca class-ID: 0403
  Device-2: HP USB Audio driver: hid-generic,snd-usb-audio,usbhid type: USB
    rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-6.2:5
    chip-ID: 03f0:056b class-ID: 0300 serial: <filter>
  API: ALSA v: k6.9.7-zen1-1-zen status: kernel-api tools: N/A
  Server-1: PipeWire v: 1.2.0 status: active with: 1: pipewire-pulse
  Device-1: Intel Raptor Lake PCH CNVi WiFi driver: iwlwifi v: kernel
    bus-ID: 00:14.3 chip-ID: 8086:51f1 class-ID: 0280
  IF: wlp0s20f3 state: down mac: <filter>
    vendor: CLEVO/KAPOK driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s
    lanes: 1 port: 3000 bus-ID: 2d:00.0 chip-ID: 10ec:8168 class-ID: 0200
  IF: enp45s0 state: down mac: <filter>
    rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 2-1.4:5
  IF: enp0s13f0u1u4 state: up speed: 1000 Mbps duplex: full mac: <filter>
  IF-ID-1: tun0 state: unknown speed: 10000 Mbps duplex: full mac: N/A
    speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:3 chip-ID: 8087:0033
    rfk-block: hardware: no software: no address: <filter> bt-v: 5.3 lmp-v: 12
  Local Storage: total: 2.73 TiB used: 1.29 TiB (47.4%)
    lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 30.9 C
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: PSSD T7
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B type: USB
    rev: 3.2 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: SSD serial: <filter>
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: PSSD T7
    scheme: MBR
    used: 24.17 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
  ID-1: swap-1 type: zram size: 31.05 GiB used: 0 KiB (0.0%) priority: 100
  System Temperatures: cpu: 39.0 C mobo: N/A
  Memory: total: 32 GiB note: est. available: 31.05 GiB used: 3.64 GiB (11.7%)
  Processes: 350 Power: uptime: 10m states: freeze,mem,disk suspend: s2idle
    suspend, test_resume image: 12.41 GiB services: org_kde_powerdevil,
  Packages: 1513 pm: pacman pkgs: 1507 libs: 432 tools: octopi,pamac,paru
    pm: flatpak pkgs: 6 Compilers: gcc: 14.1.1 Shell: garuda-inxi default: fish
    v: 3.7.1 running-in: konsole inxi: 3.3.35
  System install date:     2024-06-24
  Last full system update: 2024-07-21
  Is partially upgraded:   Yes
I’ve been trying to set up a systemd service to clone SSD1 (/dev/sda) to SSD2 (/dev/sda2) which are mounted respectively as “/run/media/keith/BACKUP” and “/run/media/keith/EXTRA”.
A lovely person here suggested a little while back that I add this to my
/etc/systemd/system/drive-mirroring.service
RequiresMountsFor=/run/media/keith/BACKUP
RequiresMountsFor=/run/media/keith/EXTRA
That works perfectly on the second run, but the initial run on start-up still complains about this:
Aug 02 19:36:27 Tuxedo drive-mirroring[1270]: rsync: [sender] change_dir "/run/media/keith/BACKUP" failed: No
such file or directory (2)
Aug 02 19:36:27 Tuxedo drive-mirroring[1274]: rsync: [Receiver] change_dir#3 "/run/media/keith" failed: No suc
I’d love to learn how to start this service seamlessly each time I kick the machine into life. Is there a command I could add which would ‘stall’ the service until those drives are available and read/writable? Or a better solution?
If I need to provide further info which might help, please let me know. Snarky RTFM comments will be ignored. Thx!
For the purposes of completeness, here is all of the three files involved in this service:
First, /etc/systemd/system/drive-mirroring.service:
[Unit]
Description=Drive sync
[Service]
Type=simple
ExecStart=/usr/local/bin/drive-mirroring
Then we have the timer at
/etc/systemd/system/drive-mirroring.timer:
[Unit]
[Timer]
#OnCalendar=hourly
OnCalendar=*:0/10
Persistent=trueRequiresMountsFor
[Install]
WantedBy=timers.target
Finally, we have the actual service itself here:
Which has this
echo "########### Drive mirroring starting at `date` ###########"
SOURCE=/run/media/keith/BACKUP/
DEST=/run/media/keith/EXTRA
rsync -ahvAE --delete --stats $SOURCE $DEST 2>&1
echo "########### Drive mirroring completed at `date` ###########"
I had hoped, or assumed, that adding the “RequiresMountsFor” things might have resolved that, but apparently not.
Any suggestions or ideas are always welcome!
I think the issue is that RequiresMountsFor only ensures that the service doesn’t start until the mount points are available, but it doesn’t guarantee that the filesystems are fully mounted and ready for use. Let’s try adding Wants= and After= dependencies for the local-fs.target, which should hold off until all local filesystems are actually mounted.
[Unit]
Wants=local-fs.target
After=local-fs.target
[Service]
Type=simple
