Hello Garuda Linux Team,
I am experiencing an issue with the FN key handling in Garuda Linux while using the Sway window manager. The problem persists both in the live ISO environment and after installation. Here are the details:
Issue Description:
- The keyboard layout is set to “Hungarian/Hungarian standard,” but the FN key is not functioning as expected.
- The system behaves as if the FN key is constantly pressed, altering the expected character outputs.
- When I physically press and hold the FN key, the keyboard produces the correct standard characters.
- This issue is present from the moment the live ISO is booted and continues after the system is installed.
Troubleshooting Steps:
- Keyboard Settings:
- I have verified that the keyboard layout is set to “Hungarian/Hungarian standard” in Garuda Settings.
- The settings do not persist, and the layout reverts to “English US” after closing the settings window.
- Command-Line Attempts:
- I tried using
setxkbmap huboth as a regular user and withsudo, but received the error: “Authorization required, but no authorization protocol specified. Cannot open Display “:0”.” - I confirmed that the
/etc/default/keyboardfile has the correct settings:
Copy
XKBMODEL="pc105"
XKBLAYOUT="hu"
XKBVARIANT="standard"
BACKSPACE="guess"
- Sway Configuration:
- I added the following line to my Sway config file (
~/.config/sway/config):
Copy
input * xkb_layout hu
- I reloaded the Sway configuration using
swaymsg reload, but encountered the error: “Unable to retrieve socket path.”
- Environment Variables:
- I checked the
WAYLAND_DISPLAYenvironment variable, which seems to be set correctly. - I also checked the
DISPLAYvariable, but it is not set, which might be expected since I am using Wayland.
- System Updates:
- The system is fully updated, and there are no pending updates.
Additional Information:
- I am using the latest version of Garuda Linux with Sway.
- The issue occurs both in the live environment and after installation
System Information (garuda-inxi Output):
Kernel: 6.13.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1 clocksource: hpet
root=UUID=638838c4-14c6-4125-8724-c52a35ce4d62 rw rootflags=subvol=@ quiet
resume=UUID=a4df42f6-add7-4ba5-97e9-07b4a298a42e loglevel=3 ibt=off
Console: pty pts/1 LM: greetd Distro: Garuda base: Arch Linux
Type: Laptop System: ASUSTeK product: F80Q v: 1.0 serial: <filter>
Mobo: ASUSTeK model: F80Q v: 1.0 serial: <filter> uuid: 803788f8-0c08-de81-3373-00248c5567d7
BIOS: American Megatrends v: 219 date: 04/10/2009
ID-1: BAT0 charge: 45.9 Wh (99.6%) condition: 46.1/48.4 Wh (95.3%) power: 2.3 W volts: 12.6
min: 10.8 model: ASUSTEK F80--22 type: Li-ion serial: N/A status: charging
Info: model: Intel Core2 Duo T8100 socket: 478 bits: 64 type: MCP arch: Penryn level: v1
built: 2008 process: Intel 45nm family: 6 model-id: 0x17 (23) stepping: 6 microcode: 0x60F
Topology: cpus: 1x dies: 1 clusters: 1 cores: 2 smt: <unsupported> cache: L1: 128 KiB
desc: d-2x32 KiB; i-2x32 KiB L2: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 800 min/max: 800/2101 boost: enabled base/boost: 2100/2100 scaling:
driver: acpi-cpufreq governor: schedutil volts: 1.1 V ext-clock: 200 MHz cores: 1: 800 2: 800
bogomips: 8379
Flags: ht lm nx pae sse sse2 sse3 sse4_1 ssse3 vmx
Device-1: Intel Mobile 4 Series Integrated Graphics vendor: ASUSTeK driver: i915 v: kernel
arch: Gen-5 process: Intel 45nm built: 2008 ports: active: LVDS-1 empty: DP-1,VGA-1
bus-ID: 00:02.0 chip-ID: 8086:2a42 class-ID: 0300
Device-2: Chicony 2.0M UVC Webcam / CNF7129 driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 8-3:2 chip-ID: 04f2:b071 class-ID: 0e02
Display: unspecified server: Xwayland v: 24.1.6 compositor: Sway v: 0.5 driver: gpu: i915
tty: 103x31
Monitor-1: LVDS-1 model: AU Optronics 0x4444 built: 2006 res: 1280x800 dpi: 107 gamma: 1.2
size: 304x190mm (11.97x7.48") diag: 358mm (14.1") ratio: 16:10 modes: 1280x800
API: Vulkan v: 1.4.304 layers: 4 device: 0 type: cpu name: llvmpipe (LLVM 19.1.7 128 bits)
driver: N/A device-ID: 10005:0000 surfaces: N/A
API: EGL Message: EGL data unavailable in console, eglinfo missing.
Info: Tools: api: vulkaninfo wl: kanshi, swaymsg, wdisplays x11: xprop
Device-1: Intel 82801I HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:293e class-ID: 0403
API: ALSA v: k6.13.5-zen1-1-zen status: kernel-api tools: alsactl,alsamixer,amixer
Server-2: PipeWire v: 1.2.7 status: active with: 1: pipewire-pulse status: active
Device-1: Realtek RTL810xE PCI Express Fast Ethernet vendor: ASUSTeK driver: r8169 v: kernel
pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: d800 bus-ID: 01:00.0 chip-ID: 10ec:8136
IF: enp1s0 state: up speed: 100 Mbps duplex: full mac: <filter>
Device-2: Qualcomm Atheros AR928X Wireless Network Adapter vendor: AzureWave AW-NE771
802.11bgn driver: ath9k v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 02:00.0
chip-ID: 168c:002a class-ID: 0280
Info: services: NetworkManager, sshd, systemd-timesyncd
Local Storage: total: 119.24 GiB used: 10.64 GiB (8.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Apacer model: AS350 128GB size: 119.24 GiB block-size:
physical: 512 B logical: 512 B speed: 3.0 Gb/s tech: SSD serial: <filter> fw-rev: 117D
scheme: MBR
ID-1: / raw-size: 110.91 GiB size: 110.91 GiB (100.00%) used: 10.64 GiB (9.6%) fs: btrfs
block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 110.91 GiB size: 110.91 GiB (100.00%) used: 10.64 GiB (9.6%) fs: btrfs
ID-3: /var/log raw-size: 110.91 GiB size: 110.91 GiB (100.00%) used: 10.64 GiB (9.6%)
fs: btrfs block-size: 4096 B dev: /dev/sda1 maj-min: 8:1
ID-4: /var/tmp raw-size: 110.91 GiB size: 110.91 GiB (100.00%) used: 10.64 GiB (9.6%)
ID-1: swap-1 type: partition size: 8.33 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/sda2
maj-min: 8:2
ID-2: swap-2 type: zram size: 3.79 GiB used: 0 KiB (0.0%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 2 dev: /dev/zram0
System Temperatures: cpu: 36.0 C mobo: N/A
Memory: total: 4 GiB available: 3.79 GiB used: 785.6 MiB (20.3%) igpu: 32 MiB
Processes: 182 Power: uptime: 37m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 1.5 GiB
services: upowerd Init: systemd v: 257 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1157 libs: 370 tools: pacseek,paru Compilers: gcc: 14.2.1
Shell: garuda-inxi (sudo) default: Bash v: 5.2.37 running-in: pty pts/1 (SSH) inxi: 3.3.37
System install date: 2025-03-07
Last full system update: 2025-03-07 ↻
I would appreciate any guidance or suggestions on how to resolve this issue. Thank you for your help!
Best regards,
Gàbor
