Hi, I dont exactly know what Fn + F2 does, it just reloads everything. But id like to unbind it but can find the option to remove it. Any tips would be nice
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-zen root=UUID=f181ffc3-cea3-4242-9c63-210fcfa3609e
Desktop: KDE Plasma 5.23.5 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: ASUSTeK product: TUF Gaming FX505DV_FX505DV v: 1.0
Mobo: ASUSTeK model: FX505DV v: 1.0 serial: <superuser required>
UEFI-[Legacy]: American Megatrends v: FX505DV.312 date: 01/28/2021
ID-1: BAT0 charge: 40.4 Wh (99.5%) condition: 40.6/48.1 Wh (84.5%) volts: 12.5 min: 11.7
model: FX50442 type: Li-ion serial: N/A status: N/A
Info: model: AMD Ryzen 5 3550H with Radeon Vega Mobile Gfx bits: 64 type: MT MCP arch: Zen/Zen+
note: check family: 0x17 (23) model-id: 0x18 (24) stepping: 1 microcode: 0x8108102
Topology: cpus: 1x cores: 4 tpc: 2 threads: 8 smt: enabled cache: L1: 384 KiB
desc: d-4x32 KiB; i-4x64 KiB L2: 2 MiB desc: 4x512 KiB L3: 4 MiB desc: 1x4 MiB
Speed (MHz): avg: 2887 high: 3693 min/max: 1400/2100 boost: enabled scaling:
driver: acpi-cpufreq governor: performance cores: 1: 2716 2: 3693 3: 3238 4: 3691 5: 2462
6: 2416 7: 2442 8: 2440 bogomips: 33537
Device-1: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: ASUSTeK driver: nvidia v: 495.46
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f11 class-ID: 0300
Device-2: AMD Picasso/Raven 2 [Radeon Vega Series / Radeon Vega Mobile Series] vendor: ASUSTeK
driver: amdgpu v: kernel bus-ID: 05:00.0 chip-ID: 1002:15d8 class-ID: 0300
Device-3: IMC Networks USB2.0 HD UVC WebCam type: USB driver: uvcvideo bus-ID: 5-1:2
chip-ID: 13d3:56a2 class-ID: 0e02 serial: <filter>
Display: x11 server: X.Org 1.21.1.3 compositor: kwin_x11 driver: loaded: modesetting,nvidia
Monitor-1: eDP-1-1 res: 1920x1080 hz: 60 dpi: 142 size: 344x194mm (13.5x7.6")
diag: 395mm (15.5")
OpenGL: renderer: NVIDIA GeForce RTX 2060/PCIe/SSE2 v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: NVIDIA TU106 High Definition Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-2: AMD Family 17h HD Audio vendor: ASUSTeK driver: snd_hda_intel v: kernel
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
Device-1: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169
v: kernel port: e000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8822CE 802.11ac PCIe Wireless Network Adapter vendor: AzureWave
driver: rtw_8822ce v: N/A modules: rtw88_8822ce port: d000 bus-ID: 04:00.0 chip-ID: 10ec:c822
Device-1: IMC Networks Bluetooth Radio type: USB driver: btusb v: 0.8 bus-ID: 3-4:3
chip-ID: 13d3:3548 class-ID: e001 serial: <filter>
Report: bt-adapter ID: hci0 rfk-id: 1 state: down bt-service: enabled,running rfk-block:
Local Storage: total: 476.94 GiB used: 213.76 GiB (44.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK size: 476.94 GiB
rev: P1MA0V4 temp: 47.9 C scheme: MBR
ID-1: / raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 213.76 GiB (44.8%) fs: btrfs
ID-2: /home raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 213.76 GiB (44.8%) fs: btrfs
ID-3: /var/log raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 213.76 GiB (44.8%)
fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-4: /var/tmp raw-size: 476.93 GiB size: 476.93 GiB (100.00%) used: 213.76 GiB (44.8%)
ID-1: swap-1 type: zram size: 7.26 GiB used: 1.76 GiB (24.2%) priority: 100 dev: /dev/zram0
System Temperatures: cpu: 70.0 C mobo: N/A
Fan Speeds (RPM): cpu: 3000
GPU: device: nvidia screen: :0.0 temp: 50 C device: amdgpu temp: 80.0 C
Processes: 322 Uptime: 1h 36m wakeups: 1 Memory: 7.26 GiB used: 5.67 GiB (78.1%) Init: systemd
v: 250 tool: systemctl Compilers: gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1573 lib: 459
Client: Unknown Client: garuda-assistant inxi: 3.3.12
