Flydigi Vader 3 Pro - can't connect via dedicated 2.4G dongle nor Bluetooth
I’m currently trying to make my controller work, a Flydigi Vader 3 Pro. Generally it connects as an Xbox 360 controller, but for some reason Garuda refuses to recognize it as such. Connecting the dedicated dongle has no result, so much so that it doesn’t seem to be listed on lsusb. Connecting via Bluetooth does show my controller as an “Xbox Wireless Controller”, but every single time I attempt it, the connection fails immediately and disconnects instead. The only way I’ve found to have the computer detect the controller at all is via wired USB-C, which is less than ideal. Even installing the xbox-generic-controller package (which allegedly deals with the problem of generic Xbox-like controllers not being properly detected) gave me no results. Am I missing any drivers in particular?
Specs:
Kernel: 6.5.6-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=b8c6c1c0-e348-4635-a8e6-1619bf9f7d65 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.8 tk: Qt v: 5.15.11 wm: kwin_wayland dm: SDDM
Type: Desktop Mobo: ASRock model: A520M-HDV serial: <filter> UEFI: American
Megatrends LLC. v: L2.11 date: 04/22/2022
Info: model: AMD Ryzen 5 5600X socket: AM4 bits: 64 type: MT MCP
family: 0x19 (25) model-id: 0x21 (33) stepping: 0 microcode: 0xA201016
L3: 32 MiB desc: 1x32 MiB
Speed (MHz): avg: 3700 min/max: 2200/4650 boost: enabled
base/boost: 3700/4650 scaling: driver: acpi-cpufreq governor: performance
volts: 1.1 V ext-clock: 100 MHz cores: 1: 3700 2: 3700 3: 3700 4: 3700
5: 3700 6: 3700 7: 3700 8: 3700 9: 3700 10: 3700 11: 3700 12: 3700
bogomips: 88637
Device-1: AMD Navi 23 [Radeon RX 6600/6600 XT/6600M] driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3,HDMI-A-1
empty: DP-1,DP-2 bus-ID: 07:00.0 chip-ID: 1002:73ff class-ID: 0300
Device-2: Cubeternet USB AV Capture driver: snd-usb-audio,uvcvideo
type: USB rev: 3.0 speed: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 bus-ID: 4-1:2
chip-ID: 1e4e:7016 class-ID: 0102 serial: <filter>
Display: server: X.Org v: 23.2.1 with: Xwayland v: 23.2.1
gpu: amdgpu display-ID: :1 screens: 1
s-diag: 583mm (22.95")
Monitor-1: DP-3 pos: primary model: LG (GoldStar) ULTRAGEAR
serial: <filter> built: 2021 res: 1920x1080 hz: 144 dpi: 92 gamma: 1.2
size: 530x300mm (20.87x11.81") diag: 604mm (23.8") ratio: 16:9 modes:
max: 1920x1080 min: 640x480
Monitor-2: HDMI-A-1 model: AOC 28E850 built: 2017 res: 1920x1080 hz: 120
dpi: 79 gamma: 1.2 size: 620x340mm (24.41x13.39") diag: 707mm (27.8")
inactive: gbm,wayland
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 6600 (navi23 LLVM
16.0.6 DRM 3.54 6.5.6-zen2-1-zen) device-ID: 1002:73ff memory: 7.81 GiB
unified: no
API: Vulkan v: 1.3.264 layers: 4 device: 0 type: discrete-gpu name: AMD
Radeon RX 6600 (RADV NAVI23) driver: mesa radv v: 23.2.1-arch1.2
device-ID: 1002:73ff surfaces: xcb,xlib device: 1 type: cpu name: llvmpipe
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 07:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 09:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Cubeternet USB AV Capture driver: snd-usb-audio,uvcvideo
API: ALSA v: k6.5.6-zen2-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 0.3.81 status: n/a (root, process) with:
vendor: ASRock driver: r8169 v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1
port: f000 bus-ID: 04:00.0 chip-ID: 10ec:8168 class-ID: 0200
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-2.4:3
lmp-v: 6 status: discoverable: no pairing: no class-ID: 7c0104
Local Storage: total: 1.94 TiB used: 932.68 GiB (47.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: LEGEND 850 LITE
lanes: 4 tech: SSD serial: <filter> fw-rev: V0922A0 temp: 34.9 C
SMART: yes health: PASSED on: 44 hrs cycles: 37
read-units: 12,218,475 [6.25 TB] written-units: 9,958,122 [5.09 TB]
ID-2: /dev/sda maj-min: 8:0 vendor: SanDisk model: SDDR-B531
size: 119.08 GiB block-size: physical: 512 B logical: 512 B type: USB
rev: 3.1 spd: 5 Gb/s lanes: 1 mode: 3.2 gen-1x1 tech: N/A serial: <filter>
fw-rev: 2920 scheme: MBR
ID-1: / raw-size: 256 GiB size: 256 GiB (100.00%) used: 26.26 GiB (10.3%)
fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4 maj-min: 259:4
used: 29.5 MiB (30.7%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 256 GiB size: 256 GiB (100.00%)
used: 26.26 GiB (10.3%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p4
maj-min: 259:4
ID-4: /var/log raw-size: 256 GiB size: 256 GiB (100.00%)
maj-min: 259:4
ID-5: /var/tmp raw-size: 256 GiB size: 256 GiB (100.00%)
maj-min: 259:4
ID-1: swap-1 type: zram size: 15.54 GiB used: 482.8 MiB (3.0%)
System Temperatures: cpu: 73.1 C mobo: N/A gpu: amdgpu temp: 55.0 C
mem: 60.0 C
Processes: 462 Uptime: 8m wakeups: 0 Memory: total: 16 GiB
available: 15.54 GiB used: 8.32 GiB (53.6%) Init: systemd v: 254
pm: pacman pkgs: 1539 libs: 439 tools: octopi,pamac,paru
inxi: 3.3.30
Garuda (2.6.17-1):
System install date:     2023-10-07
Last full system update: 2023-10-10 ↻
Windows dual boot:       Yes
