mazzy
February 18, 2023, 9:20am
1
Hello guys,
I'm running Garuda on my dell xps plus 9320. the current video drivers are: modesetting
and unfortunately they are awful. Very high flickering is experimented on my laptop.
Here the output of the command:
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen-12.2 process: Intel 10nm built: 2021-22+ ports:
active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Display: x11 server: X.Org v: 21.1.7 compositor: Picom v: git-b700a
driver: X: loaded: modesetting alternate: fbdev,intel,vesa dri: iris
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: Sharp 0x1548 built: 2021 res: 1920x1200 hz: 60
dpi: 169 gamma: 1.2 size: 288x180mm (11.34x7.09") diag: 340mm (13.4")
ratio: 16:10 modes: 1920x1200
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel Graphics (ADL GT2)
direct-render: Yes
I would like to switch from modesetting into intel.
Do you know which is the best way to do that?
Update
I've checked the intel module i915
is loaded. lsmod shows that loaded.
the kernel parameters as recommended are right.
SGS
February 18, 2023, 10:34am
2
Welcome
We do not need sudo for inxi.
And the template ask for garuda-inxi, check the difference, please edit your post.
mazzy:
driver: i915
You are already using the Intel driver. As for modesetting, that loads the graphics drivers early for you–I think you need that, see this note from the ArchWiki :
The Intel kernel module should load fine automatically on system boot.
If it does not happen, then:
Make sure you do not have nomodeset
as a kernel parameter , since Intel requires kernel mode-setting.
I would forget about the drivers and test another intervention instead, for example switching to Wayland or trying a different hardware configuration.
mazzy
February 18, 2023, 1:28pm
4
ok. i've edited posting the graphic parts of the garuda-inxi command. it should be enough.
mazzy
February 18, 2023, 1:30pm
5
i do not think so it's a problem of the hardware. there are definitely some issues in the configuration. when i've installed garuda from the live usb the video was perfect. then when i've updated garuda after the installation has ended the problems started. so something new, more up to date, fsck
ed up things.
It is enough for me.
Everyone else happy? To the bin it goes.
mazzy
February 18, 2023, 3:07pm
7
Hello. I'm having serious flickering issues after i've updated Garuda after installed it via live USB.
here the output of the command
╰─λ garuda-inxi
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f199b624-ffa0-40b4-945c-c4e71ca3d9ec rw rootflags=subvol=@
loglevel=3 ibt=off
Desktop: i3 v: 4.22 info: i3bar vt: 7 dm: LightDM v: 1.32.0
Type: Laptop System: Dell product: XPS 9320 v: N/A
Mobo: Dell model: 0V0059 v: A00 serial: <superuser required> UEFI: Dell
v: 1.11.0 date: 12/09/2022
ID-1: BAT0 charge: 21.4 Wh (39.3%) condition: 54.4/54.4 Wh (100.0%)
volts: 11.4 min: 11.6 model: SMP DELL J7H5M23 type: Li-poly serial: <filter>
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x429
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 2297 high: 2500 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: performance cores: 1: 1157 2: 2500 3: 2500
4: 2500 5: 2500 6: 2500 7: 2500 8: 2500 9: 608 10: 2500 11: 2500 12: 2500
13: 2500 14: 2500 15: 2500 16: 2500 bogomips: 79872
direct-render: Yes
Device-1: Intel vendor: Dell driver: N/A bus-ID: 00:05.0 chip-ID: 8086:465d
class-ID: 0480
Device-2: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
chip-ID: 8086:51c8 class-ID: 0401
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 3-10:4
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 476.94 GiB used: 11.94 GiB (2.5%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: PM9A1 NVMe 512GB
lanes: 4 type: SSD serial: <filter> rev: 36308229 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
used: 11.84 GiB (2.6%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-2: /boot/efi raw-size: 240 MiB size: 236 MiB (98.33%)
used: 98.9 MiB (41.9%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
ID-4: /var/log raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
ID-5: /var/tmp raw-size: 457.45 GiB size: 457.45 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.24 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 63.0 C mobo: N/A
Processes: 374 Uptime: 1h 40m wakeups: 4007 Memory: 15.24 GiB
used: 3 GiB (19.7%) Init: systemd v: 253 default: graphical tool: systemctl
Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1353 libs: 328
tools: pamac,paru Shell: fish v: 3.6.0 running-in: alacritty inxi: 3.3.25
Garuda (2.6.14-1):
System install date: 2023-02-16
Last full system update: 2023-02-18
it's important to notice that Intel graphic module is loaded. lsmod command reports it as loaded.
I'm running out of ideas. any other inputs are very appreciated.
SGS
February 18, 2023, 3:18pm
8
Try other kernel, lts, mainline ...
No flickering on lenovo i3wm here with zen kernel.
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
mazzy
February 18, 2023, 3:42pm
10
seems that only the LTS solves the issue with the video BUT running it does not load anymore the Wifi so need to debug why the wifi died with the LTS version
