Hey this is something i noticed when i used manjaro in the past with kde + x11, and now i experience it with garuda gnome i don't really know if it is a problem with my old laptop or something else, whenever my system is put to sleep when i restore back flickering start and some random freezes(the display freezes for like 5 seconds), any idea
i also should say that i use electron apps looooot (teams, vscode, discord)
Kernel: 5.16.1-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=d0241718-2938-44e6-be8a-1fd8502161d4 rw [email protected]
Desktop: GNOME 41.3 tk: GTK 3.24.31 wm: gnome-shell dm: GDM 41.3
Type: Laptop System: LENOVO product: 4238AB4 v: ThinkPad T420
Mobo: LENOVO model: 4238AB4 serial: <superuser required>
UEFI-[Legacy]: LENOVO v: 83ET67WW (1.37 ) date: 11/28/2011
ID-1: BAT0 charge: 1.6 Wh (100.0%) condition: 1.6/56.2 Wh (2.8%)
volts: 12.3 min: 10.8 model: LGC 45N1005 type: Li-ion serial: <filter>
status: Full
Info: model: Intel Core i5-2520M bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 797 high: 798 min/max: 800/3200 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 797 2: 798 3: 797
4: 797 bogomips: 19937
Type: l1tf
vendor: Lenovo ThinkPad T420 driver: i915 v: kernel bus-ID: 00:02.0
chip-ID: 8086:0126 class-ID: 0300
Device-2: Chicony integrated camera type: USB driver: uvcvideo
bus-ID: 1-1.6:3 chip-ID: 04f2:b221 class-ID: 0e02
Display: wayland server: X.Org 1.21.1.4 compositor: gnome-shell driver:
loaded: intel unloaded: modesetting alternate: fbdev,vesa display-ID: :0
Screen-1: 0 s-res: 1600x900 s-dpi: 96 s-size: 423x238mm (16.7x9.4")
s-diag: 485mm (19.1")
Monitor-1: XWAYLAND0 res: 1600x900 hz: 60 dpi: 131
size: 310x170mm (12.2x6.7") diag: 354mm (13.9")
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
Sound Server-1: ALSA v: k5.16.1-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.43 running: no
Device-1: Intel 82579LM Gigabit Network vendor: Lenovo ThinkPad T520
driver: e1000e v: kernel port: 5080 bus-ID: 00:19.0 chip-ID: 8086:1502
Device-2: Intel Centrino Advanced-N 6205 [Taylor Peak] driver: iwlwifi
v: kernel bus-ID: 03:00.0 chip-ID: 8086:0085 class-ID: 0280
Local Storage: total: 119.24 GiB used: 20.4 GiB (17.1%)
ID-1: /dev/sda maj-min: 8:0 vendor: Kingfast model: N/A size: 119.24 GiB
serial: <filter> rev: 61L3 scheme: MBR
ID-1: / raw-size: 37.55 GiB size: 37.55 GiB (100.00%)
used: 20.4 GiB (54.3%) fs: btrfs dev: /dev/sda4 maj-min: 8:4
ID-2: /home raw-size: 37.55 GiB size: 37.55 GiB (100.00%)
ID-3: /var/log raw-size: 37.55 GiB size: 37.55 GiB (100.00%)
ID-4: /var/tmp raw-size: 37.55 GiB size: 37.55 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.54 GiB used: 36.5 MiB (0.5%)
System Temperatures: cpu: 45.0 C mobo: N/A
Fan Speeds (RPM): cpu: 1921
Processes: 275 Uptime: 11m wakeups: 1 Memory: 7.54 GiB
used: 4.65 GiB (61.6%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1279 lib: 353 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: gnome-terminal inxi: 3.3.11
