Hello! I am getting a lot of flickering and lagging in code editors like vs-code and fleet. I have everything up to date since I updated the system last night. I am experiencing this for the last 2 months after garuda-update
that blew up my system in the sense that I needed to put all the panels back into place. Oh, and the dragging bar on the windows vanished. I reconstructed my desktop from scratch and got a lot of flickering on my vs-code and discord, and now on fleet. I completely reinstall the OS to no avail.
Kernel: 6.8.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=8e5a7df5-e917-434b-84d5-903c40e177cf rw rootflags=subvol=@
wm: kwin_wayland with: Docker,krunner vt: 1 dm: SDDM Distro: Garuda
Type: Desktop Mobo: Micro-Star model: X570-A PRO (MS-7C37) v: 3.0
UEFI: American Megatrends v: H.60 date: 11/06/2019
Info: model: AMD Ryzen 7 3800X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4249 high: 4255 min/max: N/A cores: 1: 4250 2: 4255
3: 4250 4: 4250 5: 4249 6: 4250 7: 4250 8: 4250 9: 4250 10: 4250 11: 4245
12: 4250 13: 4250 14: 4250 15: 4250 16: 4250 bogomips: 136000
Device-1: NVIDIA TU116 [GeForce GTX 1650 SUPER] vendor: Micro-Star MSI
driver: nvidia v: 550.76 alternate: nouveau,nvidia_drm non-free: 550.xx+
status: current (as of 2024-04; EOL~2026-12-xx) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none
off: DP-1,HDMI-A-1 empty: DVI-D-1 bus-ID: 2d:00.0 chip-ID: 10de:2187
alternate: fbdev,nouveau,nv,vesa gpu: nvidia d-rect: 3840x1080
display-ID: 0
Monitor-1: DP-1 pos: primary,left res: 1920x1080 size: N/A modes: N/A
Monitor-2: HDMI-A-1 pos: right res: 1920x1080 size: N/A modes: N/A
x11: drv: zink inactive: device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.76
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce GTX 1650
SUPER/PCIe/SSE2 memory: 3.91 GiB display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 1 device: 0 type: discrete-gpu name: NVIDIA
GeForce GTX 1650 SUPER driver: nvidia v: 550.76 device-ID: 10de:2187
Device-1: NVIDIA TU116 High Definition Audio vendor: Micro-Star MSI
bus-ID: 2d:00.1 chip-ID: 10de:1aeb class-ID: 0403
Device-2: AMD Starship/Matisse HD Audio vendor: Micro-Star MSI X570-A PRO
bus-ID: 2f:00.4 chip-ID: 1022:1487 class-ID: 0403
Device-3: Logitech PRO X Wireless Gaming Headset
lanes: 1 mode: 1.1 bus-ID: 7-1:2 chip-ID: 046d:0aba class-ID: 0300
API: ALSA v: k6.8.7-zen1-1-zen status: kernel-api tools: N/A
Server-2: PipeWire v: 1.0.5 status: active with: 1: pipewire-pulse
vendor: Micro-Star MSI X570-A PRO driver: r8169 v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: d000 bus-ID: 27:00.0 chip-ID: 10ec:8168
IF: enp39s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Local Storage: total: 2.05 TiB used: 23.08 GiB (1.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Kingston model: SA2000M81000G
lanes: 4 tech: SSD serial: <filter> fw-rev: S5Z42105 temp: 36.9 C
scheme: MBR
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Samsung model: SSD 980 250GB
size: 232.89 GiB block-size: physical: 512 B logical: 512 B speed: 31.6 Gb/s
lanes: 4 tech: SSD serial: <filter> fw-rev: 3B4QFXO7 temp: 31.9 C
model: WD10EZEX-08WN4A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A02 scheme: GPT
used: 23.08 GiB (9.9%) fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:4
used: 584 KiB (0.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-1: swap-1 type: zram size: 31.29 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 51.0 C mobo: N/A
Memory: total: 32 GiB available: 31.29 GiB used: 4.66 GiB (14.9%)
Processes: 403 Power: uptime: 22m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.47 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1465 libs: 385 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-04-22
Last full system update: 2024-04-23 ↻
