If anyone has any problem with his/her mic you can add the following libraries with pacman:
sudo pacman -S glibc alsa-lib gcc-libs gconf libnotify nspr nss libxss libxtst libc++
I struggled a bit to find this also removing noise reduction from the settings in discord seems to help as well.
