Hey guys,
I already fixed this but I will post in case somebody else will hit this problem. After the latest KCD2 patch controllers stopped to work in the game.
I tested all owned controller I have:
- PS3
- PS4
- PS5
- Steam controller
And none of them worked. However Steam Deck controller support works. SO, if you have this problem just add this launch option into the game.
SteamDeck=1 %command%
This will make the steam input and controller behave and make it work.
Also note, you can try this option for other games if your controller stopped and does not work. The command is not exclusive to this game its universal in steam.
Forgot inxi ![]()
Kernel: 6.18.9-arch1-2-znver5 arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-znver5
root=UUID=aaf2fe4c-290b-4ef4-bfd4-1736576d2c89 rw rootflags=subvol=@
quiet resume=UUID=8dd78827-8cbe-4c44-a410-a36c948cce40 loglevel=3
split_lock_detect=off
Desktop: KDE Plasma v: 6.5.5 tk: Qt v: N/A info: frameworks v: 6.22.0
Type: Desktop System: Micro-Star product: MS-7E51 v: 1.0
Mobo: Micro-Star model: MAG X870 TOMAHAWK WIFI (MS-7E51) v: 1.0
serial: <superuser required> uuid: <superuser required> Firmware: UEFI
vendor: American Megatrends LLC. v: 1.A44 date: 04/24/2025
Device-1: hid-dc:2c:26:0e:85:7b-battery model: Keychron K2 serial: N/A
charge: N/A status: discharging
Info: model: AMD Ryzen 7 9800X3D bits: 64 type: MT MCP arch: Zen 5 gen: 5
level: v4 note: check built: 2024+ process: TSMC n4 (4nm) family: 0x1A (26)
model-id: 0x44 (68) stepping: 0 microcode: 0xB404035
smt: enabled cache: L1: 640 KiB desc: d-8x48 KiB; i-8x32 KiB L2: 8 MiB
desc: 8x1024 KiB L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 5245 min/max: 603/5272 boost: enabled scaling:
driver: amd-pstate-epp governor: performance cores: 1: 5245 2: 5245 3: 5245
4: 5245 5: 5245 6: 5245 7: 5245 8: 5245 9: 5245 10: 5245 11: 5245 12: 5245
13: 5245 14: 5245 15: 5245 16: 5245 bogomips: 150399
ssse3 svm
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 [Radeon RX 9070/9070
XT/9070 GRE] vendor: XFX driver: amdgpu v: kernel arch: RDNA-4
code: Navi-4x process: TSMC n4 (4nm) built: 2025+ pcie: gen: 5
speed: 32 GT/s lanes: 16 ports: active: DP-3 empty: DP-1, DP-2, HDMI-A-1,
Writeback-1 bus-ID: 03:00.0 chip-ID: 1002:7550 class-ID: 0300
vendor: Micro-Star MSI driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x
lanes: 16 ports: active: none empty: DP-4, DP-5, DP-6, HDMI-A-2,
Writeback-2 bus-ID: 74:00.0 chip-ID: 1002:13c0 class-ID: 0300 temp: 39.0 C
gpu: amdgpu display-ID: 0
Monitor-1: DP-3 model: Dell AW3423DWF serial: <filter> built: 2023 res:
mode: 3440x1440 hz: 165 scale: 100% (1) dpi: 109 gamma: 1.2
size: 800x337mm (31.5x13.27") diag: 868mm (34.2") modes: max: 3440x1440
min: 720x400
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.3.5-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon RX 9070 XT (radeonsi
gfx1201 LLVM 21.1.6 DRM 3.64 6.18.9-arch1-2-znver5) device-ID: 1002:7550
memory: 15.62 GiB unified: no display-ID: :0.0
API: Vulkan v: 1.4.341 layers: 13 device: 0 type: discrete-gpu name: AMD
Radeon RX 9070 XT (RADV GFX1201) driver: mesa radv v: 25.3.5-arch1.1
device-ID: 1002:7550 surfaces: N/A device: 1 type: integrated-gpu name: AMD
Ryzen 7 9800X3D 8-Core Processor (RADV RAPHAEL_MENDOCINO)
driver: mesa radv v: 25.3.5-arch1.1 device-ID: 1002:13c0 surfaces: N/A
device: 2 type: cpu name: llvmpipe (LLVM 21.1.6 256 bits)
driver: mesa llvmpipe v: 25.3.5-arch1.1 (LLVM 21.1.6)
de: kscreen-console,kscreen-doctor gpu: amdgpu_top, corectrl, lact
Device-1: Advanced Micro Devices [AMD/ATI] Navi 48 HDMI/DP Audio
driver: snd_hda_intel v: kernel pcie: gen: 5 speed: 32 GT/s lanes: 16
bus-ID: 03:00.1 chip-ID: 1002:ab40 class-ID: 0403
speed: 16 GT/s lanes: 16 bus-ID: 74:00.1 chip-ID: 1002:1640 class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Ryzen HD Audio
speed: 16 GT/s lanes: 16 bus-ID: 74:00.6 chip-ID: 1022:15e3 class-ID: 0403
Device-4: Fractal Scape Dongle driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-3.3:8
chip-ID: 36bc:0001 class-ID: 0300 serial: <filter>
Device-5: Micro Star USB Audio driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-5:7
chip-ID: 0db0:cd0e class-ID: 0300
Device-6: VIA USB Audio Device driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2.2:3
chip-ID: 040d:340a class-ID: 0300
API: ALSA v: k6.18.9-arch1-2-znver5 status: kernel-api with: aoss
Server-2: PipeWire v: 1.4.10 status: active with: 1: pipewire-pulse
Device-1: Qualcomm WCN785x Wi-Fi 7 320MHz 2x2 [FastConnect 7800]
vendor: Foxconn Band Simultaneous Wireless driver: ath12k_pci v: N/A
modules: ath12k pcie: gen: 3 speed: 8 GT/s lanes: 1 link-max: lanes: 2
bus-ID: 09:00.0 chip-ID: 17cb:1107 class-ID: 0280
IF: wlp9s0 state: down mac: <filter>
Device-2: Realtek RTL8126 5GbE vendor: Micro-Star MSI driver: r8126
v: 10.016.00 modules: r8169 pcie: gen: 3 speed: 8 GT/s lanes: 1 port: e000
bus-ID: 0a:00.0 chip-ID: 10ec:8126 class-ID: 0200
IF: enp10s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-1: Foxconn / Hon Hai driver: btusb v: 0.8 type: USB rev: 1.1
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-12:12 chip-ID: 0489:e10a
Local Storage: total: 3.18 TiB used: 1.58 TiB (49.5%)
ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 970 EVO 500GB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:6 vendor: Samsung model: SSD 970 EVO 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 2B2QEXE7 temp: 30.9 C
ID-3: /dev/nvme2n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 4B2QJXD7 temp: 44.9 C
ID-1: / raw-size: 432.02 GiB size: 432.02 GiB (100.00%)
used: 126.47 GiB (29.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
used: 664 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
ID-3: /home raw-size: 432.02 GiB size: 432.02 GiB (100.00%)
ID-4: /var/log raw-size: 432.02 GiB size: 432.02 GiB (100.00%)
ID-5: /var/tmp raw-size: 432.02 GiB size: 432.02 GiB (100.00%)
Kernel: swappiness: 10 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: zram size: 30.4 GiB used: 2.1 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 33.45 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
System Temperatures: cpu: 44.9 C mobo: 36.2 C
GPU: device: amdgpu temp: 50.0 C mem: 66.0 C fan: 0 watts: 47.00
device: amdgpu temp: 38.0 C
Memory: total: 32 GiB note: est. available: 30.4 GiB used: 14.59 GiB (48.0%)
Processes: 576 Power: uptime: 34m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.15 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1563 libs: 448 tools: octopi,paru Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.9 default: fish v: 4.4.0 running-in: konsole
inxi: 3.3.40
Garuda (2.12.3-2):
System install date: 2025-03-16
Garuda release: 250308
Last full system update: 2026-02-14
Relevant software: snapper NetworkManager dracut garuda-hardware-profile-standard garuda-hardware-profile-standard-x11
25/26 checks run in 0.37 seconds ⌛
Powered by garuda-health 🦅
