Hello all. Fully updated system. showed up after one reboot after a update. I did try copying fish.config file like in previous posts.
LANGUAGE = "",
LC_ALL = (unset),
LC_ADDRESS = "en_GB.UTF-8",
LC_NAME = "en_GB.UTF-8",
LC_MONETARY = "en_GB.UTF-8",
LC_PAPER = "en_GB.UTF-8",
LC_IDENTIFICATION = "en_GB.UTF-8",
LC_TELEPHONE = "en_GB.UTF-8",
LC_MEASUREMENT = "en_GB.UTF-8",
LC_TIME = "en_GB.UTF-8",
LC_NUMERIC = "en_GB.UTF-8",
LANG = "en_GB.UTF-8"
perl: warning: Falling back to the standard locale ("C").
Kernel: 5.16.18-1-ck-generic-v3 arch: x86_64 bits: 64 compiler: gcc
v: 11.2.0 parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-ck-generic-v3
root=UUID=ce5da691-f89b-4cd8-b44f-90011d7f627a rw rootflags=subvol=@
loglevel=3 quiet sysrq_always_enabled=1 mitigations=off
Type: Laptop System: ASUSTeK product: VivoBook_ASUSLaptop X513UA_M513UA
Mobo: ASUSTeK model: X513UA v: 1.0 serial: <superuser required>
UEFI: American Megatrends LLC. v: X513UA.311 date: 10/26/2021
ID-1: BAT0 charge: 24.9 Wh (58.9%) condition: 42.3/42.1 Wh (100.6%)
volts: 11.8 min: 11.8 model: ASUSTeK ASUS Battery type: Li-ion serial: N/A
status: discharging cycles: 1
Device-1: hidpp_battery_0 model: Logitech M570 serial: <filter>
charge: 65% rechargeable: yes status: discharging
Info: model: AMD Ryzen 7 5700U with Radeon Graphics bits: 64 type: MT MCP
arch: Zen 2 family: 0x17 (23) model-id: 0x68 (104) stepping: 1
microcode: 0x8608103
L3: 8 MiB desc: 2x4 MiB
Speed (MHz): avg: 1557 high: 2347 min/max: 1400/4370 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 1533 2: 1397
3: 1397 4: 1397 5: 1397 6: 2347 7: 1397 8: 1397 9: 1729 10: 1512 11: 1399
12: 2206 13: 1412 14: 1423 15: 1421 16: 1562 bogomips: 57494
Device-1: AMD Lucienne vendor: ASUSTeK driver: amdgpu v: kernel pcie:
active: eDP-1 empty: HDMI-A-1 bus-ID: 03:00.0 chip-ID: 1002:164c
loaded: amdgpu unloaded: modesetting alternate: fbdev,vesa gpu: amdgpu
Monitor-1: eDP-1 mapped: eDP model: Samsung 0x4161 built: 2020
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
OpenGL:
renderer: AMD RENOIR (LLVM 13.0.1 DRM 3.44 5.16.18-1-ck-generic-v3)
v: 4.6 Mesa 22.0.0 direct render: Yes
speed: 16 GT/s bus-ID: 03:00.1 chip-ID: 1002:1637 class-ID: 0403
Device-2: AMD ACP/ACP3X/ACP6x Audio Coprocessor vendor: ASUSTeK
driver: N/A
alternate: snd_pci_acp3x, snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x
link-max: gen: 4 speed: 16 GT/s bus-ID: 03:00.6 chip-ID: 1022:15e3
Sound Server-1: ALSA v: k5.16.18-1-ck-generic-v3 running: yes
Sound Server-2: JACK v: 1.9.20 running: no
Sound Server-4: PipeWire v: 0.3.49 running: yes
Device-1: MEDIATEK MT7921 802.11ax PCI Express Wireless Network Adapter
lanes: 1 bus-ID: 01:00.0 chip-ID: 14c3:7961 class-ID: 0280
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
Local Storage: total: 1.82 TiB used: 463.7 GiB (24.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Sabrent model: Rocket Q4
lanes: 4 type: SSD serial: <filter> rev: RKT40Q.2 temp: 38.9 C
ID-1: / raw-size: 115.23 GiB size: 115.23 GiB (100.00%)
used: 35.2 GiB (30.5%) fs: btrfs dev: /dev/nvme0n1p1 maj-min: 259:1
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%)
used: 546 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p3 maj-min: 259:3
ID-3: /home raw-size: 1.59 TiB size: 1.59 TiB (100.00%)
used: 415.18 GiB (25.5%) fs: btrfs dev: /dev/nvme0n1p4 maj-min: 259:4
ID-4: /var/log raw-size: 115.23 GiB size: 115.23 GiB (100.00%)
ID-5: /var/tmp raw-size: 115.23 GiB size: 115.23 GiB (100.00%)
ID-1: swap-1 type: partition size: 8.8 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.09 GiB used: 626.2 MiB (4.1%)
System Temperatures: cpu: 49.0 C mobo: N/A gpu: amdgpu temp: 42.0 C
Fan Speeds (RPM): cpu: 2200
Processes: 425 Uptime: 1h 8m wakeups: 4 Memory: 15.09 GiB
used: 3.19 GiB (21.1%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: pacman: 1535 lib: 379 Shell: fish
v: 3.3.1 running-in: konsole inxi: 3.3.14
Garuda (2.5.6-2):
System install date: 2021-04-26
Last full system update: 2022-03-30
Snapshots: Timeshift
Failed units: systemd-oomd.socket
each time I open the Konsole:
fish: Unknown command: '##'
~/.config/fish/config.fish (line 1):
?>>?## Set values
from sourcing file ~/.config/fish/config.fish
called during startup
config file not corrupted. deleting lines not helping either.
