Hello Garuda users.
After the recent update, I migrate latte to native kde system. But I lose all theme for garuada fish konsole.
Anyone would help me to restore the theme. I tried to reset the fish config from garuda assistant but the effect was to delete all themes ...
Kernel: 6.1.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=f327471a-c329-462b-a1dc-fca7bb7580b2 rw [email protected]
systemd.unified_cgroup_hierarchy=1 loglevel=3 ibt=off
Desktop: KDE Plasma v: 5.27.0 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Laptop System: LENOVO product: 20TH001AFR v: ThinkPad P1 Gen 3
Mobo: LENOVO model: 20TH001AFR v: SDK0T08861 WIN
serial: <superuser required> UEFI: LENOVO v: N2VET26W (1.11 )
date: 11/16/2020
ID-1: BAT0 charge: 70.3 Wh (97.6%) condition: 72.0/80.4 Wh (89.5%)
volts: 16.8 min: 15.4 model: SMP 5B10X19049 type: Li-poly serial: <filter>
status: not charging cycles: 214
Info: model: Intel Core i9-10885H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xF4
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 3007 high: 4912 min/max: 800/5300 scaling:
driver: intel_pstate governor: performance cores: 1: 4912 2: 4900 3: 2400
4: 2400 5: 2400 6: 4907 7: 2400 8: 4594 9: 2400 10: 2400 11: 2400 12: 2400
13: 2400 14: 2400 15: 2400 16: 2400 bogomips: 76800
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Lenovo driver: i915
active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:9bc4
Device-2: NVIDIA TU117GLM [Quadro T2000 Mobile / Max-Q] vendor: Lenovo
driver: nvidia v: 525.89.02 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2023-02) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s ports: active: none off: HDMI-A-1
empty: DP-1,DP-2 bus-ID: 01:00.0 chip-ID: 10de:1fb8 class-ID: 0300
Device-3: Chicony Integrated Camera type: USB driver: uvcvideo
bus-ID: 1-8:2 chip-ID: 04f2:b6cb class-ID: fe01 serial: <filter>
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
Screen-1: 0 s-res: 4480x1440 s-dpi: 96 s-size: 1184x380mm (46.61x14.96")
s-diag: 1243mm (48.96")
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: top-right
model: Dell U2715H serial: <filter> built: 2016 res: 2560x1440 hz: 60
dpi: 109 gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 685mm (27")
Monitor-2: eDP-1 pos: primary,bottom-l model-id: CSO 0x1500 built: 2019
res: 1920x1080 hz: 60 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
diag: 395mm (15.5") ratio: 16:9 modes: 3840x2160
API: OpenGL v: 4.6 Mesa 22.3.4 renderer: Mesa Intel UHD Graphics (CML GT2)
direct-render: Yes
Device-1: Intel Comet Lake PCH cAVS vendor: Lenovo
driver: sof-audio-pci-intel-cnl
alternate: snd_hda_intel,snd_soc_skl,snd_sof_pci_intel_cnl bus-ID: 00:1f.3
chip-ID: 8086:06c8 class-ID: 0401
Device-2: NVIDIA vendor: Lenovo driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3 speed: 8 GT/s
Sound API: ALSA v: k6.1.12-zen1-1-zen running: yes
IF-ID-1: tun0 state: unknown speed: 10 Mbps duplex: full mac: N/A
bus-ID: 1-14:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 202.16 GiB (21.2%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Toshiba model: N/A
lanes: 4 type: SSD serial: <filter> rev: 5108AGLA temp: 42.9 C scheme: GPT
ID-1: / raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
used: 202.13 GiB (34.5%) fs: btrfs dev: /dev/nvme0n1p5 maj-min: 259:5
used: 33.6 MiB (13.1%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-4: /var/log raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 585.94 GiB size: 585.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 30.98 GiB used: 1.01 GiB (3.3%)
System Temperatures: cpu: 81.0 C pch: 59.0 C mobo: N/A
Fan Speeds (RPM): fan-1: 4485 fan-2: 4335
Processes: 416 Uptime: 20m wakeups: 5 Memory: 30.98 GiB
used: 8.57 GiB (27.7%) Init: systemd v: 253 default: graphical
pkgs: 1589 libs: 375 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2021-11-16
Last full system update: 2023-02-20
Other things, but I've not realy invest for now, when I use two screens I can't move a window by taking the top bar with my mouse. I need to reduce the windows to be able to move it.
THank for your help.
