Fish-shell and gpg/ssh-agent help
I have searched the web but I can not find a solution that does what I want the fish shell to do.
With oh-my-zsh, you can add plugins such as gpg-agent and ssh-agent.
Once zsh is launched and there is no ssh-agent running, it will prompt for ssh passphrase and it keeps the ssh-agent running and remember values until next reboot. Same thing with gpg-agent, except that only gets unlocked when one uses gpg to sign something.
Kernel: 6.7.8-273-tkg-linux-tkg-pds arch: x86_64 bits: 64 compiler: gcc
v: 13.2.1 clocksource: tsc avail: hpet,acpi_pm
parameters: intel_pstate=passive kernel.split_lock_mitigate=0
BOOT_IMAGE=/@/boot/vmlinuz-linux-tkg-pds
root=UUID=d317771f-a3af-43ab-ae96-fc60f2ab2018 rw rootflags=subvol=@
Type: Desktop System: Gigabyte product: Z97X-SLI v: N/A
Mobo: Gigabyte model: Z97X-SLI-CF v: x.x serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends v: F10b
date: 03/03/2016
Info: model: Intel Core i5-4670K bits: 64 type: MCP arch: Haswell
desc: 1x6 MiB
Speed (MHz): avg: 3800 min/max: 800/3800 scaling: driver: intel_cpufreq
governor: performance cores: 1: 3800 2: 3800 3: 3800 4: 3800 bogomips: 27224
Device-1: NVIDIA AD107 [GeForce RTX 4060] vendor: Micro-Star MSI
driver: nvidia v: 550.54.14 alternate: nouveau,nvidia_drm non-free: 545.xx+
status: current (as of 2024-02) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 3 speed: 8 GT/s lanes: 8
link-max: gen: 4 speed: 16 GT/s bus-ID: 01:00.0 chip-ID: 10de:2882
s-diag: 610mm (24")
Monitor-1: HDMI-0 res: 1920x1080 hz: 60 dpi: 92
drv: swrast gbm: drv: kms_swrast surfaceless: drv: nvidia x11: drv: nvidia
inactive: wayland,device-1
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: nvidia mesa v: 550.54.14
glx-v: 1.4 direct-render: yes renderer: NVIDIA GeForce RTX 4060/PCIe/SSE2
memory: 7.81 GiB
API: Vulkan v: 1.3.276 layers: 9 device: 0 type: discrete-gpu
name: NVIDIA GeForce RTX 4060 driver: nvidia v: 550.54.14
device-ID: 10de:2882 surfaces: xcb,xlib device: 1 type: discrete-gpu
device-ID: 10de:2882 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
(LLVM 16.0.6 256 bits) driver: mesa llvmpipe v: 24.0.2-arch1.1.1 (LLVM
Device-1: Intel 9 Series Family HD Audio vendor: Gigabyte 9
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:8ca0
Device-2: NVIDIA vendor: Micro-Star MSI driver: snd_hda_intel v: kernel
pcie: gen: 3 speed: 8 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s
Device-3: Tenx USB AUDIO driver: hid-generic,snd-usb-audio,usbhid
type: USB rev: 1.1 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-6:5
chip-ID: 1130:1620 class-ID: 0300
API: ALSA v: k6.7.8-273-tkg-linux-tkg-pds status: kernel-api with: aoss
Device-1: Intel Ethernet I217-V vendor: Gigabyte driver: e1000e v: kernel
port: f040 bus-ID: 00:19.0 chip-ID: 8086:153b class-ID: 0200
IF-ID-1: tailscale0 state: unknown speed: -1 duplex: full mac: N/A
Local Storage: total: 935.29 GiB used: 72.65 GiB (7.8%)
model: WD10EZEX-00ZF5A0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: SanDisk model: SanDisk Cruzer
size: 3.77 GiB block-size: physical: 512 B logical: 512 B type: USB rev: 2.0
spd: 480 Mb/s lanes: 1 mode: 2.0 tech: N/A serial: <filter> fw-rev: 8.02
ID-1: / raw-size: 500 GiB size: 500 GiB (100.00%) used: 70.75 GiB (14.1%)
fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /boot/efi raw-size: 2.17 GiB size: 2.17 GiB (99.80%)
used: 1.91 GiB (88.0%) fs: vfat dev: /dev/sda4 maj-min: 8:4
ID-3: /home raw-size: 500 GiB size: 500 GiB (100.00%)
used: 70.75 GiB (14.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-4: /var/log raw-size: 500 GiB size: 500 GiB (100.00%)
ID-5: /var/tmp raw-size: 500 GiB size: 500 GiB (100.00%)
zswap: no
System Temperatures: cpu: 52.0 C mobo: N/A gpu: nvidia temp: 52 C
Fan Speeds (rpm): N/A gpu: nvidia fan: 34%
Memory: total: 32 GiB available: 31.25 GiB used: 7.58 GiB (24.2%)
Processes: 234 Power: uptime: 1h 14m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.46 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1633 libs: 490 tools: octopi,paru Compilers:
gcc: 13.2.1 Shell: garuda-inxi default: fish v: 3.7.0 running-in: konsole
inxi: 3.3.33
Garuda (2.6.23-1):
System install date:     2024-03-04
Last full system update: 2024-03-05 ↻
:policeman: “papers please” :oncoming_police_car:
https://searx.garudalinux.org/search?q=fish+shell+ssh-agent
Thanks, trying the first result and see if it works verses last time I tried
Means
:warning: Missing information requested in the template may result in not receiving assistance
Issue still unresolved? Then:
  • ONE issue per topic.
