Hello Garuda users.
I have recently noticed that fish has stopped autobeautifying it's contents since the last update (somewhere between 10th - 12th dec) I decided to rollback to previous snapshot had to choose 9th dec one 10th dec snapshot still had the same issue. Plus a chroot and reinstalling grub later I had a working fish again.
I cleared all my paccache and updated all my packages again and rebooted the device which resulted in the same problem making me believe it's a problem with this update. Can someone please help. ![]()
I have attached Screenshots to help better understand the problem.
Before update:
After update:
I know this might not be a issue for many but it is very irksome for me. Could someone please tell me how to fix this or just point me in the general direction?? Bcoz I have no clue what this feature is even called and that just makes it searching it online very hard.
Any help is greatly appreciated. ![]()
inxi:
Kernel: 6.0.12-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.0
root=UUID=6a7bcee6-f3ae-4c03-b6b0-7cb27fb4c8d4 rw rootflags=subvol=@
resume=UUID=1b9b6f2d-a19b-4eee-b2bf-6af31dfdf566 loglevel=3 ibt=off
Type: Convertible System: LENOVO product: 81X1 v: IdeaPad Flex 5 14IIL05
serial: <superuser required> Chassis: type: 31 v: IdeaPad Flex 5 14IIL05
Mobo: LENOVO model: LNVNB161216 v: SDK0Q55722 WIN
serial: <superuser required> UEFI: LENOVO v: ECCN41WW date: 06/27/2022
ID-1: BAT0 charge: 40.0 Wh (90.7%) condition: 44.1/52.6 Wh (83.9%)
volts: 13.0 min: 11.5 model: Sunwoda L19D3PD6 type: Li-poly serial: <filter>
status: charging cycles: 1272
Device-1: wacom_battery_0 model: Wacom HID 5218 serial: N/A charge: 0%
rechargeable: yes status: N/A
Info: model: Intel Core i7-1065G7 bits: 64 type: MT MCP arch: Ice Lake
gen: core 10 level: v4 note: check built: 2019-21 process: Intel 10nm
family: 6 model-id: 0x7E (126) stepping: 5 microcode: 0xB6
L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 2 MiB desc: 4x512 KiB L3: 8 MiB
desc: 1x8 MiB
Speed (MHz): avg: 1260 high: 1500 min/max: 400/3900 scaling:
driver: intel_pstate governor: powersave cores: 1: 1500 2: 1000 3: 1009
4: 1078 5: 1500 6: 1500 7: 1000 8: 1500 bogomips: 23961
Device-1: Intel Iris Plus Graphics G7 vendor: Lenovo driver: i915 v: kernel
arch: Gen-11 process: Intel 10nm built: 2019-21 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, HDMI-A-1 bus-ID: 00:02.0 chip-ID: 8086:8a52
Device-2: NVIDIA GP108M [GeForce MX330] vendor: Lenovo driver: nvidia
v: 525.60.11 alternate: nouveau,nvidia_drm non-free: 525.xx+
status: current (as of 2022-12) arch: Pascal code: GP10x
process: TSMC 16nm built: 2016-21 pcie: gen: 1 speed: 2.5 GT/s lanes: 4
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:1d16
class-ID: 0302
Device-3: Acer Integrated Camera type: USB driver: uvcvideo bus-ID: 3-2:2
chip-ID: 5986:212a class-ID: 0e02
Monitor-1: eDP-1 model: ChiMei InnoLux 0x1406 built: 2019 res: 1920x1080
hz: 60 dpi: 158 gamma: 1.2 size: 309x173mm (12.17x6.81") diag: 354mm (13.9")
ratio: 16:9 modes: 1920x1080
API: OpenGL v: 4.6 Mesa 22.2.3 renderer: Mesa Intel Iris Plus Graphics
(ICL GT2) direct render: Yes
Device-1: Intel Ice Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-icl
alternate: snd_hda_intel,snd_sof_pci_intel_icl bus-ID: 00:1f.3
chip-ID: 8086:34c8 class-ID: 0401
Sound API: ALSA v: k6.0.12-zen1-1-zen running: yes
Device-1: Intel Ice Lake-LP PCH CNVi WiFi driver: iwlwifi v: kernel
bus-ID: 00:14.3 chip-ID: 8086:34f0 class-ID: 0280
bus-ID: 3-10:4 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 476.94 GiB used: 38.81 GiB (8.1%)
model: MZALQ512HALU-000L2 size: 476.94 GiB block-size: physical: 512 B
rev: 3L1QFXV7 temp: 36.9 C scheme: GPT
ID-1: / raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
used: 38.81 GiB (8.4%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-3: /home raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-4: /var/log raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-5: /var/tmp raw-size: 459.82 GiB size: 459.82 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.29 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 16.82 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 59.0 C mobo: N/A
Processes: 264 Uptime: 25m wakeups: 6 Memory: 15.29 GiB
used: 4.12 GiB (26.9%) Init: systemd v: 252 default: graphical
tool: systemctl Compilers: gcc: 12.2.0 Packages: pm: pacman pkgs: 1306
libs: 353 tools: octopi,pamac,paru Shell: fish v: 3.5.1 default: Bash
v: 5.1.16 running-in: konsole inxi: 3.3.24
e[1;34mGaruda (2.6.10-1):e[0m
e[1;34m System install date:e[0m 2022-11-12
e[1;34m Last full system update:e[0m 2022-12-12
e[1;34m Is partially upgraded: e[0m No
e[1;34m Relevant software: e[0m NetworkManager
e[1;34m Windows dual boot: e[0m Probably (Run as root to verify)
e[1;34m Snapshots: e[0m Snapper
e[1;34m Failed units: e[0m
