You don't need to wait a week or two for help. The normal procedure if you haven't received any assistance after waiting several days is to post an update (not an empty bump).
On this update you list all new troubleshooting steps you have taken, including all terminal outputs of commands you've run. Also include links to any pertinent information you have found online.
There's a fine line between letting your post go dormant, and continually spamming a thread. I have noticed you have a bad habit of posting numerous consecutive comments one after another. This forum is not chat, consolidate your posts if you have something to add by editing your post and add your new comment to the first
If you wish to respond to different users in the same post you can do this by using the forums quote feature. You do not need to respond to each user individually, you can respond to multiple users on a single post by quoting.
Follow these tips to conform to the way we expect users to conduct themselves on our forum and you will not likely receive further static from myself or other moderators.
Thank you for you cooperation.
update !
here is the output of
inxi -Fxxxza
please compare it with earlier one. is the error solved?
skulldealer:
╰─λ ininxi -Fxxxza
OUTPUT -
╰─λ inxi -Fxxxza
System: Kernel: 5.10.35-1-lts x86_64 bits: 64 compiler: gcc v: 10.2.0
parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts root=UUID=9f1aeaa5-470f-4043-80db-a6285d36379e rw
rootflags=subvol=@
cryptdevice=UUID=61943d89-e377-44ac-8a75-b8b776b2a841:luks-61943d89-e377-44ac-8a75-b8b776b2a841
root=/dev/mapper/luks-61943d89-e377-44ac-8a75-b8b776b2a841 rd.udev.log_priority=3 vt.global_cursor_default=0
systemd.unified_cgroup_hierarchy=1 resume=/dev/mapper/luks-0a3d92e7-e950-47a5-acdf-c8b9f11112a4 loglevel=3
quiet splash
Desktop: Xfce 4.16.0 tk: Gtk 3.24.24 info: xfce4-panel, plank, vala-panel wm: xfwm4 vt: 7 dm: LightDM 1.30.0
Machine: Type: Laptop System: ASUSTeK product: ROG Strix G731GT_G731GT v: 1.0 serial: <filter>
Mobo: ASUSTeK model: G731GT v: 1.0 serial: <filter> UEFI: American Megatrends v: G731GT.307 date: 04/28/2020
Battery: ID-1: BAT0 charge: 37.9 Wh (95.9%) condition: 39.5/50.5 Wh (78.2%) volts: 12.5 min: 12.5
model: ASUSTeK ASUS Battery type: Li-ion serial: N/A status: Charging
Device-1: hidpp_battery_0 model: Logitech M350 Wireless Mouse serial: <filter>
CPU: Info: 6-Core model: Intel Core i7-9750H bits: 64 type: MT MCP arch: Kaby Lake note: check family: 6
model-id: 9E (158) stepping: D (13) microcode: DE cache: L2: 12 MiB
flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx bogomips: 62399
Speed: 900 MHz min/max: 800/4500 MHz Core speeds (MHz): 1: 900 2: 900 3: 900 4: 900 5: 900 6: 883 7: 900
8: 900 9: 900 10: 900 11: 900 12: 869
Graphics: Device-1: Intel UHD Graphics 630 vendor: ASUSTeK driver: i915 v: kernel bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q] vendor: ASUSTeK driver: nvidia v: 465.27
alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0300
Display: x11 server: X.Org 1.20.11 driver: loaded: modesetting,nvidia display-ID: :0.0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 508x286mm (20.0x11.3") s-diag: 583mm (23")
Monitor-1: eDP-1-1 res: 1920x1080 dpi: 128 size: 382x215mm (15.0x8.5") diag: 438mm (17.3")
OpenGL: renderer: NVIDIA GeForce GTX 1650/PCIe/SSE2 v: 4.6.0 NVIDIA 465.27 direct render: Yes
Audio: Device-1: Intel Cannon Lake PCH cAVS vendor: ASUSTeK driver: snd_hda_intel v: kernel
alternate: snd_soc_skl,snd_sof_pci bus-ID: 00:1f.3 chip-ID: 8086:a348 class-ID: 0403
Sound Server-1: ALSA v: k5.10.35-1-lts running: yes
Sound Server-4: PipeWire v: 0.3.27 running: yes
Network: Device-1: Intel Wireless-AC 9560 [Jefferson Peak] driver: iwlwifi v: kernel port: 5000 bus-ID: 00:14.3
chip-ID: 8086:a370 class-ID: 0280
Device-2: Realtek RTL8111/8168/8411 PCI Express Gigabit Ethernet vendor: ASUSTeK driver: r8169 v: kernel
port: 3000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
IF: eno2 state: up speed: 1000 Mbps duplex: full mac: <filter>
Bluetooth: Device-1: Intel Bluetooth 9460/9560 Jefferson Peak (JfP) type: USB driver: btusb v: 0.8 bus-ID: 1-14:4
Drives: Local Storage: total: 476.94 GiB used: 16.28 GiB (3.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Micron model: 2200V MTFDHBA512TCK size: 476.94 GiB block-size:
physical: 512 B logical: 512 B speed: 31.6 Gb/s lanes: 4 rotation: SSD serial: <filter> rev: P1MA0V4
temp: 50.9 C scheme: GPT
Partition: ID-1: / raw-size: 459.65 GiB size: 459.65 GiB (100.00%) used: 16.28 GiB (3.5%) fs: btrfs dev: /dev/dm-0
maj-min: 254:0 mapped: luks-61943d89-e377-44ac-8a75-b8b776b2a841
ID-2: /boot/efi raw-size: 256 MiB size: 252 MiB (98.46%) used: 682 KiB (0.3%) fs: vfat dev: /dev/nvme0n1p1
maj-min: 259:1
ID-3: /home raw-size: 459.65 GiB size: 459.65 GiB (100.00%) used: 16.28 GiB (3.5%) fs: btrfs dev: /dev/dm-0
ID-4: /var/log raw-size: 459.65 GiB size: 459.65 GiB (100.00%) used: 16.28 GiB (3.5%) fs: btrfs dev: /dev/dm-0
ID-5: /var/tmp raw-size: 459.65 GiB size: 459.65 GiB (100.00%) used: 16.28 GiB (3.5%) fs: btrfs dev: /dev/dm-0
ID-1: swap-1 type: partition size: 17.03 GiB used: 0 KiB (0.0%) priority: -2 dev: /dev/dm-1 maj-min: 254:1
mapped: luks-0a3d92e7-e950-47a5-acdf-c8b9f11112a4
ID-2: swap-2 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram0
ID-3: swap-3 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram1
ID-4: swap-4 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram2
ID-5: swap-5 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram3
ID-6: swap-6 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram4
ID-7: swap-7 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram5
ID-8: swap-8 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram6
ID-9: swap-9 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram7
ID-10: swap-10 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram8
ID-11: swap-11 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram9
ID-12: swap-12 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram10
ID-13: swap-13 type: zram size: 1.29 GiB used: 0 KiB (0.0%) priority: 32767 dev: /dev/zram11
Sensors: System Temperatures: cpu: 63.0 C mobo: N/A gpu: nvidia temp: 56 C
Fan Speeds (RPM): cpu: 4200
Info: Processes: 410 Uptime: 52m wakeups: 3 Memory: 15.49 GiB used: 2.03 GiB (13.1%) Init: systemd v: 248
tool: systemctl Compilers: gcc: 10.2.0 clang: 11.1.0 Packages: pacman: 1279 lib: 319 Shell: fish v: 3.2.2
running-in: kitty inxi: 3.3.04
in context to locales
Final Update !
It was a problem in Garuda settings manager,locales menu. On changing the locale from en us to en in, problems were seen in terminal. localectl, locale-gen, locale -a showed that not all types locales were converted. Some necessary locales like c I guess we're not configured to any locale and left blank. This led to the issue. 2 to 3 users on slackware forum were kind enough to help me instantly. They asked me output of some locale related commands and told me to reinstall fish and glibc.
So the solution that worked was
sudo pacman -Syu glibc fish fish-autopair garuda-fish-config
After installing, in the post install part, I saw it regenerated the locales and configured them flawlessly. After a reboot, now things are fine. All issues are gone. Thanks.
Good work, nice job figuring out how to correct your issue.
system
Closed
13 May 2021 18:39
26
