This issue seems to be like this one: NVME kernel bug leads to I/O errors and system crash · Issue #2355 · ublue-os/bazzite · GitHub
Right now, I upgraded the kernel to 6.14 & haven’t run into this issue (tested by resuming the rsync job).
My boot drive is a Samsung 990 Pro & it’s relatively new (bought around Black Friday). I was using it on Tuxedo OS (kernel 6.11 & 6.14) just before I made the switch to Garuda.
Just want to bring this to someone’s attention and I’m wondering if someone else ran into it? I don’t see any post here about it.
Kernel: 6.14.10-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.1.1 clocksource: tsc
root=UUID=5478d0cc-e982-4347-a7e1-040d1c432850 rw rootflags=subvol=@
lsm=landlock,lockdown,yama,integrity,apparmor,bpf amd_iommu=on iommu=pt kvm_amd.npt=1
kvm_amd.avic=1 amdgpu.ppfeaturemask=0xffffffff vfio-pci.ids=10de:2882,10de:22be,1b21:2142
Desktop: KDE Plasma v: 6.3.5 tk: Qt v: N/A info: frameworks v: 6.14.0 wm: kwin_wayland
with: krunner vt: 1 dm: SDDM Distro: Garuda base: Arch Linux
Type: Desktop System: Gigabyte product: X570S AORUS MASTER v: -CF serial: <superuser required>
Mobo: Gigabyte model: X570S AORUS MASTER serial: <superuser required>
uuid: <superuser required> UEFI: American Megatrends LLC. v: F8g date: 03/11/2025
Info: model: AMD Ryzen 9 5900X bits: 64 type: MT MCP arch: Zen 3+ gen: 3 level: v3 note: check
built: 2022 process: TSMC n6 (7nm) family: 0x19 (25) model-id: 0x21 (33) stepping: 0
microcode: 0xA201030
Topology: cpus: 1x dies: 1 clusters: 1 cores: 12 threads: 24 tpc: 2 smt: enabled cache:
L1: 768 KiB desc: d-12x32 KiB; i-12x32 KiB L2: 6 MiB desc: 12x512 KiB L3: 64 MiB desc: 2x32 MiB
Speed (MHz): avg: 3597 min/max: 550/4954 boost: enabled scaling: driver: amd-pstate-epp
governor: performance cores: 1: 3597 2: 3597 3: 3597 4: 3597 5: 3597 6: 3597 7: 3597 8: 3597
9: 3597 10: 3597 11: 3597 12: 3597 13: 3597 14: 3597 15: 3597 16: 3597 17: 3597 18: 3597
19: 3597 20: 3597 21: 3597 22: 3597 23: 3597 24: 3597 bogomips: 177616
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21 [Radeon RX 6800/6800 XT / 6900 XT]
vendor: ASRock driver: amdgpu v: kernel arch: RDNA-2 code: Navi-2x process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-1,DP-3,HDMI-A-1
empty: DP-2,Writeback-1 bus-ID: 0e:00.0 chip-ID: 1002:73bf class-ID: 0300
Device-2: NVIDIA AD107 [GeForce RTX 4060] vendor: Gigabyte driver: vfio-pci v: N/A
alternate: nouveau non-free: 550-570.xx+ status: current (as of 2025-04) arch: Lovelace
code: AD1xx process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
bus-ID: 0f:00.0 chip-ID: 10de:2882 class-ID: 0300
Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6 compositor: kwin_wayland
gpu: amdgpu d-rect: 6000x4320 display-ID: 0
Monitor-1: DP-1 pos: middle-l model: MSI MAG342CQR serial: <filter> built: 2022 res:
mode: 3440x1440 hz: 144 scale: 100% (1) dpi: 111 gamma: 1.2 size: 797x333mm (31.38x13.11")
diag: 864mm (34") modes: max: 3440x1440 min: 720x400
Monitor-2: DP-3 pos: top-right model: LG (GoldStar) SDQHD serial: <filter> built: 2023 res:
mode: 2560x1440 hz: 60 scale: 100% (1) dpi: 140 gamma: 1.2 size: 465x262mm (18.31x10.31")
diag: 534mm (21") ratio: 16:9 modes: max: 2560x1440 min: 640x480
Monitor-3: HDMI-A-1 pos: bottom-r model: LG (GoldStar) SDQHD serial: <filter> built: 2023 res:
gbm: drv: kms_swrast surfaceless: drv: radeonsi wayland: drv: radeonsi x11: drv: radeonsi
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 25.1.3-arch1.3 glx-v: 1.4
direct-render: yes renderer: AMD Radeon RX 6900 XT (radeonsi navi21 LLVM 20.1.6 DRM 3.61
6.14.10-zen1-1-zen) device-ID: 1002:73bf memory: 15.62 GiB unified: no display-ID: :1.0
API: Vulkan v: 1.4.313 layers: 13 device: 0 type: discrete-gpu name: AMD Radeon RX 6900 XT
(RADV NAVI21) driver: mesa radv v: 25.1.3-arch1.3 device-ID: 1002:73bf surfaces: N/A device: 1
type: cpu name: llvmpipe (LLVM 20.1.6 256 bits) driver: mesa llvmpipe v: 25.1.3-arch1.3 (LLVM
gpu: corectrl wl: wayland-info x11: xdpyinfo, xprop, xrandr
Device-1: Advanced Micro Devices [AMD/ATI] Navi 21/23 HDMI/DP Audio driver: snd_hda_intel
v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:ab28 class-ID: 0403
Device-2: NVIDIA AD107 High Definition Audio vendor: Gigabyte driver: vfio-pci
alternate: snd_hda_intel pcie: speed: Unknown lanes: 63 link-max: gen: 4 speed: 16 GT/s
bus-ID: 0f:00.1 chip-ID: 10de:22be class-ID: 0403
Device-3: Advanced Micro Devices [AMD] Starship/Matisse HD Audio vendor: Gigabyte
driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 11:00.4
chip-ID: 1022:1487 class-ID: 0403
Device-4: SteelSeries ApS Arctis Nova 7 driver: hid-generic,snd-usb-audio,usbhid type: USB
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 1038:2202 class-ID: 0300
API: ALSA v: k6.14.10-zen1-1-zen status: kernel-api with: aoss type: oss-emulator tools: N/A
Server-1: PipeWire v: 1.4.5 status: active with: 1: pipewire-pulse status: active
Device-1: Intel Wi-Fi 6E AX210/AX1675 2x2 [Typhoon Peak] driver: iwlwifi v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:2725 class-ID: 0280
IF: wlp7s0 state: down mac: <filter>
Device-2: Intel Ethernet I225-V vendor: Gigabyte driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 08:00.0 chip-ID: 8086:15f3 class-ID: 0200
IF: enp8s0 state: up speed: 2500 Mbps duplex: full mac: <filter>
IF-ID-1: br0 state: up speed: 10000 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10000 Mbps duplex: full mac: <filter>
Info: services: NetworkManager, sshd, systemd-timesyncd
Device-1: Intel AX210 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1
mode: 1.1 bus-ID: 7-5:3 chip-ID: 8087:0032 class-ID: e001
Local Storage: total: 25.47 TiB used: 9.27 TiB (36.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 990 PRO 4TB size: 3.64 TiB
fw-rev: 4B2QJXD7 temp: 43.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Western Digital model: WD BLACK SN850X 8000GB
size: 7.28 TiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD
serial: <filter> fw-rev: 638201WD temp: 53.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 4TB size: 3.64 TiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: 2B6Q
ID-4: /dev/sdb maj-min: 8:16 vendor: Western Digital model: WD4004FZWX-00GBGB0 size: 3.64 TiB
fw-rev: 0A81 scheme: GPT
ID-5: /dev/sdc maj-min: 8:32 vendor: Western Digital model: WD8001FZBX-00ASYA0 size: 7.28 TiB
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 823.01 GiB (22.1%) fs: btrfs
ID-2: /boot/efi raw-size: 1000 MiB size: 998 MiB (99.80%) used: 7.8 MiB (0.8%) fs: vfat
ID-3: /home raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 823.01 GiB (22.1%) fs: btrfs
ID-4: /var/log raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 823.01 GiB (22.1%) fs: btrfs
ID-5: /var/tmp raw-size: 3.64 TiB size: 3.64 TiB (100.00%) used: 823.01 GiB (22.1%) fs: btrfs
ID-1: swap-1 type: zram size: 62.68 GiB used: 3.9 MiB (0.0%) priority: 100 comp: zstd
avail: lzo-rle,lzo,lz4,lz4hc,deflate,842 max-streams: 24 dev: /dev/zram0
System Temperatures: cpu: 54.2 C mobo: N/A gpu: amdgpu temp: 59.0 C mem: 54.0 C
Memory: total: 64 GiB note: est. available: 62.68 GiB used: 10.02 GiB (16.0%)
Processes: 574 Power: uptime: 44m states: freeze,mem,disk suspend: deep avail: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume image: 25.05 GiB
Packages: 1884 pm: pacman pkgs: 1776 libs: 532 tools: octopi,paru pm: flatpak pkgs: 36 pm: snap
pkgs: 72 Compilers: clang: 20.1.6 gcc: 15.1.1 Client: Unknown Client: garuda-rani inxi: 3.3.38
System install date: 2025-06-08
Last full system update: 2025-06-09 ↻
