honza
17 August 2024 11:25
1
I used garuda-update -a, and under :: Retrieving packages...
on the first line, there was this:
linux-firmware-20240809.59460076-1-any 42.3 KiB 107 B/s --:-- [C o o o o o o o o o o o o o o o o o ] 0%
I copied this after the update finished, meaning it probably never downloaded
I have Lenovo Yoga 14IAP7, can someone please tell me if this means something important?
I’ll post garuda-inxi after reboot
honza
17 August 2024 11:31
2
.%;888:8898898: honza@honza
x;XxXB%89b8:b8%b88: -----------
.8Xxd 8X:. OS: Garuda Linux x86_64
.8Xx; 8x:. Host: 82LU (Yoga 9 14IAP7)
.tt8x .d x88; Kernel: 6.10.5-zen1-1-zen
.@8x8; .db: xx@; Uptime: 50 seconds
,tSXX° .bbbbbbbbbbbbbbbbbbbB8x@; Packages: 2425 (pacman)[stable], 6 (snap)
.SXxx bBBBBBBBBBBBBBBBBBBBbSBX8; Shell: fish 3.7.1
,888S pd! Resolution: 3840x2400
8X88/ q DE: KDE Plasma 6.1.4
8X88/ WM: KWin (Wayland)
GBB. WM Theme: Sweet-Dark
x%88 d888@8@X@X@X88X@@XX@@X@8@X. Theme: Dr460nized (Sweet) [Qt], Sweet-Dark [GTK2/3/4]
dxXd dB8b8b8B8B08bB88b998888b88x. Icons: BeautyLine [Qt], BeautyLine [GTK2/3/4]
dxx8o .@@;. Terminal: konsole 24.5.2
dx88 .t@x. Terminal Font: FiraCode Nerd Font Mono 12
d:SS@8ba89aa67a853Sxxad. CPU: 12th Gen Intel(R) Core(TM) i7-1260P (16) @ 4,70 GHz
.d988999889889899dd. GPU: Intel Iris Xe Graphics @ 1,40 GHz [Integrated]
Memory: 4691 MiB / 15713 MiB
╭─honza@honza in ~
╰─λ garuda-inxi
Kernel: 6.10.5-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=6519954b-9606-4557-b953-512403841361 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.1.4 tk: Qt v: N/A info: frameworks v: 6.5.0
Type: Convertible System: LENOVO product: 82LU v: Yoga 9 14IAP7
serial: <superuser required> Chassis: type: 31 v: Yoga 9 14IAP7
Mobo: LENOVO model: LNVNB161216 v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_82LU_BU_idea_FM_Yoga 9
14IAP7 uuid: <superuser required> UEFI: LENOVO v: HNCN46WW
date: 09/08/2023
ID-1: BAT0 charge: 60.8 Wh (91.8%) condition: 66.2/75.0 Wh (88.3%)
power: 13.6 W volts: 16.9 min: 15.5 model: Celxpert L21C4PH0 type: Li-poly
serial: <filter> status: discharging cycles: 149
Info: model: 12th Gen Intel Core i7-1260P bits: 64 type: MST AMCP
arch: Alder Lake level: v3 note: check built: 2021+
microcode: 0x433
Topology: cpus: 1x cores: 12 mt: 4 tpc: 2 st: 8 threads: 16 smt: enabled
cache: L1: 1.1 MiB desc: d-8x32 KiB, 4x48 KiB; i-4x32 KiB, 8x64 KiB
L2: 9 MiB desc: 4x1.2 MiB, 2x2 MiB L3: 18 MiB desc: 1x18 MiB
Speed (MHz): avg: 419 high: 620 min/max: 400/4700:3400 scaling:
driver: intel_pstate governor: powersave cores: 1: 400 2: 416 3: 400 4: 400
5: 470 6: 400 7: 620 8: 400 9: 400 10: 400 11: 400 12: 400 13: 400 14: 400
15: 400 16: 400 bogomips: 79872
Device-1: Intel Alder Lake-P GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Gen-12.2 process: Intel 10nm
built: 2021-22+ ports: active: eDP-1 empty: DP-1,DP-2,DP-3 bus-ID: 00:02.0
chip-ID: 8086:46a6 class-ID: 0300
Device-2: Luxvisions Innotech Integrated RGB Camera driver: uvcvideo
type: USB rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-8:3
chip-ID: 30c9:0057 class-ID: fe01 serial: <filter>
Monitor-1: eDP-1 res: 1536x960 size: N/A modes: N/A
drv: iris x11: drv: iris
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.1.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Graphics (ADL GT2)
device-ID: 8086:46a6 memory: 7.49 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 15 device: 0 type: integrated-gpu
name: Intel Graphics (ADL GT2) driver: mesa intel v: 24.1.6-arch1.1
device-ID: 8086:46a6 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.1.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Lenovo
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:51c8 class-ID: 0401
API: ALSA v: k6.10.5-zen1-1-zen status: kernel-api with: aoss
Server-2: PipeWire v: 1.2.2 status: active with: 1: pipewire-pulse
rfk-block: hardware: no software: yes address: <filter> bt-v: 5.3 lmp-v: 12
Local Storage: total: 953.87 GiB used: 785.72 GiB (82.4%)
model: MZVL21T0HCLR-00BL2 size: 953.87 GiB block-size: physical: 512 B
fw-rev: CL1QGXA7 temp: 47.9 C scheme: GPT
ID-1: / raw-size: 835.94 GiB size: 835.94 GiB (100.00%)
used: 785.68 GiB (94.0%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 31.4 MiB (10.5%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 835.94 GiB size: 835.94 GiB (100.00%)
ID-4: /var/log raw-size: 835.94 GiB size: 835.94 GiB (100.00%)
ID-5: /var/tmp raw-size: 835.94 GiB size: 835.94 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.34 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 46.0 C mobo: N/A
Memory: total: 16 GiB note: est. available: 15.34 GiB used: 4.63 GiB (30.2%)
Processes: 369 Power: uptime: 1m states: freeze,mem,disk suspend: s2idle
image: 6.13 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 2425 libs: 612 tools: octopi,pamac,paru
pm: flatpak pkgs: 0 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: fish v: 3.7.1 running-in: konsole inxi: 3.3.35
System install date: 2024-06-24
Last full system update: 2024-08-17
╭─honza@honza in ~ took 22s
╰─λ
filo
17 August 2024 11:35
3
This is a normal firmware package, although flagged out of date (means it will be further updated soon due to newer upstream version):
https://archlinux.org/packages/core/any/linux-firmware/
What’s the problem with it?
The linux-firmware package is a collection of binary firmware files provided by hardware manufacturers so that the Linux kernel can support their hardware.
honza
17 August 2024 11:42
4
the problem is that it looks like it didn’t download at all, look at the progress bar
filo
17 August 2024 11:54
5
That was probably a graphical glitch, otherwise your inxi would show a partial upgrade.
What do you get with
pacman -Ss linux-firmware | grep installed
And maybe
cat /var/log/pacman.log | grep 'linux-firmware'
system
Closed
31 August 2024 11:55
6
