Firmware Security Problem
:warning: Firmware Issue :warning:
I'm currently a newbie.I need to know why my firmware security have a lot of red and how to fixed it.It seems i get this warning "This system has HSI runtime issues.".Is that serious warning?.And i'm using only one hsi is that bad or good.
Diy you search the web about?
Yes but there’s no answer to solve it.The result is similiar but useless.It’s more like personal and not common problem.I want to send a picture but as new user i can’t upload it.If i can upload it will be more clear
Just start with things you can do in this forum. Follow the template, please.
The template you delete was
Issue still unresolved? Then:
  • ONE issue per topic.
New users are prohibited from posting pictures in order to prevent spam and other nonsense. You can use an external pic hoster for this, but I think we know what your topic is about.
For end-user hardware, most of what is marked in red is normal. You don’t usually need to worry about it. With business hardware, it’s a different story.
I think you mean HSI-1 (security level):
A safe baseline for security should be HSI-1. If your system isn’t at least meeting this criteria, you should adjust firmware setup options, contact your manufacturer or replace the hardware.
You can take a look here:
