Hello sir when i enable firewall in setting it shows [Error enabling firewall: Interactive authentication required.]
When i click on firewall option first time it asks for password when i give it password it allows to access firewall setting.
When i click on enable firewall option it again asks for password two times i give it , but instead of getting enabled . It shows [Error enabling firewall: Interactive authentication required.]
I am administrator user. Firewall option is showing enabled on Garuda assistant . Its icon is on taskbar but in setting it shows disabled.
Here is my Garuda-inxi
Kernel: 6.8.9-zen1-2-zen arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
root=UUID=31fd2d08-5674-4dec-a6c3-576065993e39 rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.0.4 tk: Qt v: N/A info: frameworks v: 6.2.0
Type: Laptop System: LENOVO product: 80E5 v: Lenovo G50-80
serial: <superuser required> Chassis: type: 10 v: Lenovo G50-80
Mobo: LENOVO model: Lenovo G50-80 v: NO DPK serial: <superuser required>
part-nu: LENOVO_MT_80E5_BU_idea_FM_Lenovo G50-80 uuid: <superuser required>
UEFI: LENOVO v: B0CNA0WW date: 09/30/2016
ID-1: BAT0 charge: 19.6 Wh (100.0%) condition: 19.6/28.5 Wh (68.7%)
volts: 16.1 min: 14.4 model: Lenovo IdeaPad type: Unknown serial: <filter>
status: full
Info: model: Intel Core i3-5005U bits: 64 type: MT MCP arch: Broadwell
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 1547 high: 1897 min/max: 500/1900 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 1897 2: 1896 3: 1895
4: 500 bogomips: 15963
Device-1: Intel HD Graphics 5500 vendor: Lenovo driver: i915 v: kernel
arch: Gen-8 process: Intel 14nm built: 2014-15 ports: active: eDP-1
empty: DP-1,HDMI-A-1,HDMI-A-2 bus-ID: 00:02.0 chip-ID: 8086:1616
Device-2: Bison Lenovo EasyCamera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 5986:0673
Display: wayland server: X.org v: 1.21.1.13 with: Xwayland v: 23.2.7
Monitor-1: eDP-1 res: 1366x768 size: N/A modes: N/A
drv: iris inactive: gbm
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 24.0.7-arch1.3
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 5500 (BDW
GT2) device-ID: 8086:1616 memory: 15.17 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 3 device: 0 type: integrated-gpu name: Intel
HD Graphics 5500 (BDW GT2) driver: mesa intel v: 24.0.7-arch1.3
device-ID: 8086:1616 surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.0.7-arch1.3 (LLVM 17.0.6) device-ID: 10005:0000
Device-1: Intel Broadwell-U Audio vendor: Lenovo driver: snd_hda_intel
Device-2: Intel Wildcat Point-LP High Definition Audio vendor: Lenovo
API: ALSA v: k6.8.9-zen1-2-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.0.6 status: active with: 1: pipewire-pulse
port: 3000 bus-ID: 02:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Intel Wireless 3160 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b4 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-7:5 chip-ID: 8087:07dc
Report: btmgmt ID: hci0 rfk-id: 2 state: up address: <filter> bt-v: 4.0
lmp-v: 6 status: discoverable: no pairing: no class-ID: 6c010c
Local Storage: total: 1.14 TiB used: 11.02 GiB (0.9%)
ID-1: /dev/sda maj-min: 8:0 vendor: Consistent model: SSD S6 256GB
tech: SSD serial: <filter> fw-rev: 05H3 scheme: GPT
model: WD10JPCX-24UE4T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
used: 11.02 GiB (4.6%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 65.0 C mobo: N/A
Memory: total: 16 GiB available: 15.54 GiB used: 1.56 GiB (10.0%)
Processes: 204 Power: uptime: 0m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.2 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1456 libs: 486 tools: octopi,paru Compilers:
gcc: 14.1.1 Shell: garuda-inxi default: fish v: 3.7.1 running-in: konsole
inxi: 3.3.34
System install date: 2024-05-17
Last full system update: 2024-05-17
