Firefox crashing unexpectedly when taking a screenshot using spectacle
as usual , the inxi:
sudo garuda-inxi
[sudo] password for cnqur:
Kernel: 6.18.2-zen2-1-zen arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
root=UUID=e5479ac6-e147-4911-a699-4456d244dad7 rw rootflags=subvol=@
mem_sleep_default=s2idle nvidia-drm.modeset=1
Desktop: KDE Plasma v: 6.5.4 tk: Qt v: N/A wm: kwin_wayland dm: SDDM
Type: Laptop System: HP product: Victus by HP Gaming Laptop 16-r1xxx
v: Type1ProductConfigId serial: <filter> Chassis: type: 10 serial: <filter>
Mobo: HP model: 8C99 v: 10.33 serial: <filter> part-nu: 9U2F0EA#ABV
uuid: 7f479588-8503-ef11-a4f6-30138b12ae44 Firmware: UEFI vendor: Insyde
v: F.15 date: 01/13/2025
ID-1: BAT1 charge: 69.8 Wh (100%) condition: 69.8/83 Wh (84%) volts: 12.57
min: 11.58 model: 313-CD-12-A WK06083XL type: Li-ion serial: <filter>
charging: status: full cycles: N/A
Info: model: Intel Core i7-14650HX socket: LGA1700 (U3E1) note: check
bits: 64 type: MST AMCP arch: Raptor Lake gen: core 14 level: v3 note: check
built: 2022+ process: Intel 7 (10nm) family: 6 model-id: 0xB7 (183)
stepping: 1 microcode: 0x132
Topology: cpus: 1x dies: 1 clusters: 10 cores: 16 threads: 24 mt: 8 tpc: 2
st: 8 smt: enabled cache: L1: 1.4 MiB desc: d-8x32 KiB, 8x48 KiB; i-8x32
KiB, 8x64 KiB L2: 24 MiB desc: 8x2 MiB, 2x4 MiB L3: 30 MiB desc: 1x30 MiB
Speed (MHz): avg: 1053 min/max: 800/5000:5200:3700 base/boost: 4752/8500
scaling: driver: intel_pstate governor: powersave volts: 1.3 V
ext-clock: 100 MHz cores: 1: 1053 2: 1053 3: 1053 4: 1053 5: 1053 6: 1053
7: 1053 8: 1053 9: 1053 10: 1053 11: 1053 12: 1053 13: 1053 14: 1053
15: 1053 16: 1053 17: 1053 18: 1053 19: 1053 20: 1053 21: 1053 22: 1053
23: 1053 24: 1053 bogomips: 116121
Device-1: NVIDIA AD107M [GeForce RTX 4050 Max-Q / Mobile]
vendor: Hewlett-Packard driver: nvidia v: 590.48.01
alternate: nouveau,nvidia_drm non-free: 550-580.xx+
status: current (as of 2025-11) arch: Lovelace code: AD1xx
process: TSMC n4 (5nm) built: 2022+ pcie: gen: 4 speed: 16 GT/s lanes: 8
ports: active: HDMI-A-1 off: eDP-1 empty: DP-1 bus-ID: 01:00.0
chip-ID: 10de:28a1 class-ID: 0300
Device-2: Quanta HP True Vision FHD Camera driver: uvcvideo type: USB
rev: 2.0 speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 1-6:4 chip-ID: 0408:548d
Display: unspecified server: X.Org v: 24.1.9 with: Xwayland v: 24.1.9
gpu: nv_platform,nvidia,nvidia-nvswitch display-ID: :1 screens: 1
Screen-1: 0 s-res: 2259x1271 s-dpi: 96 s-size: 598x336mm (23.54x13.23")
s-diag: 686mm (27.01")
Monitor-1: HDMI-A-1 res: mode: 2259x1271 hz: 144 scale: 100% (1) dpi: 96
API: EGL v: 1.5 hw: drv: nvidia platforms: gbm: drv: nvidia
API: OpenGL v: 4.6.0 vendor: nvidia v: 590.48.01 glx-v: 1.4
direct-render: yes renderer: NVIDIA GeForce RTX 4050 Laptop GPU/PCIe/SSE2
memory: 5.86 GiB
API: Vulkan v: 1.4.335 layers: 8 device: 0 type: discrete-gpu name: NVIDIA
GeForce RTX 4050 Laptop GPU driver: nvidia v: 590.48.01
device-ID: 10de:28a1 surfaces: N/A device: 1 type: cpu name: llvmpipe
(LLVM 21.1.6 256 bits) driver: mesa llvmpipe v: 25.3.2-arch1.1 (LLVM
Device-1: Intel Raptor Lake High Definition Audio vendor: Hewlett-Packard
driver: sof-audio-pci-intel-tgl alternate: snd_soc_avs,
snd_sof_pci_intel_tgl, snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:7a50
class-ID: 0401
Device-2: NVIDIA AD107 High Definition Audio vendor: Hewlett-Packard
API: ALSA v: k6.18.2-zen2-1-zen status: kernel-api
Server-1: PipeWire v: 1.4.9 status: n/a (root, process) with:
lanes: 1 port: 4000 bus-ID: 03:00.0 chip-ID: 10ec:8168 class-ID: 0200
Device-2: Realtek RTL8852BE PCIe 802.11ax Wireless Network
vendor: Hewlett-Packard driver: rtw89_8852be v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 04:00.0 chip-ID: 10ec:b852
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 0bda:b85c
Report: hciconfig ID: hci0 rfk-id: 0 state: down
address: <filter>
Info: acl-mtu: 1021:6 sco-mtu: 255:12 link-policy: rswitch hold sniff park
link-mode: peripheral accept
Local Storage: total: 953.87 GiB used: 69.43 GiB (7.3%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: KIOXIA model: N/A
lanes: 4 tech: SSD serial: <filter> fw-rev: HP02AN00 temp: 34.9 C
SMART: yes health: PASSED on: 194d 5h cycles: 1,078
read-units: 65,333,341 [33.4 TB] written-units: 51,914,040 [26.5 TB]
ID-1: / raw-size: 118.64 GiB size: 118.64 GiB (100.00%)
used: 69.43 GiB (58.5%) fs: btrfs block-size: 4096 B dev: /dev/nvme0n1p7
maj-min: 259:7
used: 668 KiB (0.1%) fs: vfat block-size: 512 B dev: /dev/nvme0n1p5
maj-min: 259:5
ID-3: /home raw-size: 118.64 GiB size: 118.64 GiB (100.00%)
maj-min: 259:7
ID-4: /var/log raw-size: 118.64 GiB size: 118.64 GiB (100.00%)
maj-min: 259:7
ID-5: /var/tmp raw-size: 118.64 GiB size: 118.64 GiB (100.00%)
maj-min: 259:7
ID-1: swap-1 type: zram size: 15.31 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 7.81 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme0n1p6 maj-min: 259:6
System Temperatures: cpu: 48.0 C mobo: N/A
Fan Speeds (rpm): cpu: 3900 fan-2: 4200
Memory: total: 16 GiB note: est. available: 15.31 GiB used: 5.1 GiB (33.3%)
Processes: 498 Power: uptime: 8h 7m states: freeze,mem,disk
suspend: s2idle avail: deep wakeups: 0 hibernate: platform avail: shutdown,
reboot, suspend, test_resume image: 6.08 GiB services: org_kde_powerdevil,
Packages: 1752 pm: dpkg pkgs: 1 tools: apt,apt-get pm: pacman pkgs: 1716
libs: 391 tools: octopi,pamac,paru,yay pm: flatpak pkgs: 28 pm: snap pkgs: 7
Compilers: clang: 21.1.6 gcc: 15.2.1 Shell: Bash (sudo) v: 5.3.9
running-in: konsole inxi: 3.3.40
Garuda (2.11.1-1):
System install date:     2025-07-17
Last full system update: 2026-01-13
Windows dual boot:       Yes
26/26 checks run in 0.55 seconds ⌛
Powered by garuda-health 🦅
and this problem has occurred for multiple times weekly since getting a new external monitor to my laptop , so i wanted to determine if logging firefox while usually surfing would make any difference and give me a good cause :
╭─cnqur@victus in ~
╰─λ firefox
ExceptionHandler::GenerateDump attempting to generate:/home/cnqur/.mozilla/firefox/vt9ea8ec.homeuser_wins11/minidumps/45e67ddf-d09a-4218-7c84-dc3475cb013c.dmp
ExceptionHandler::GenerateDump cloned child 64559
ExceptionHandler::SendContinueSignalToChild sent continue signal to child
ExceptionHandler::WaitForContinueSignal waiting for continue signal...
ExceptionHandler::GenerateDump minidump generation succeeded
Exiting due to channel error.
╭─cnqur@victus in ~ took 55m23s
i can take a guess that at the moment of taking a screenshot using Spectacle , these subsequent channel errors were the result.
It seems like the channel errors happen after the actual crash and are therefore probably unrelated.
yeah maybe its better for me to open the terminal side-by-side w/ firefox to determine that.
are there main possible causes in which i can help search for them ?
At this point , switching to Firedragon is way easier and more stable ( until now ) than bothering with firefox issues on arch-based distros.
