Hello, I'm new to the forum but also new to linux and was looking to get a little help. I had distrohopped between a couple different versions of Garuda before deciding on KDE Dr460nized which brought me here. Each time I performed a clean install by erasing the disk in the installer.
Recently after running the system update in Garuda Assistant the themed buttons on FireDragon have disappeared if the window is not maximized. If it is maximized they appear in the AppMenu bar at the top of the screen.
Including some screenshots so hopefully people understand what I'm talking about.
Red shows missing FireDragon buttons, yellow shows them on terminal window for example
Fullscreen shows buttons at top left in the AppMenu bar.
Sorry, couldn't upload to forum directly as a new user. Searched the forums but didn't see anything quite matching this, also checked some videos of Garuda to make sure I wasn't crazy and was misremembering something that was never there.
garuda-inxi per the instructions.
Kernel: 6.2.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
root=UUID=afd822a8-b9ff-4c05-91b6-94422d5c2990 rw rootflags=subvol=@
Desktop: KDE Plasma v: 5.27.3 tk: Qt v: 5.15.8 wm: kwin_x11 vt: 1 dm: SDDM
Type: Desktop Mobo: ASRock model: B550 Taichi serial: <superuser required>
UEFI: American Megatrends LLC. v: L2.62 date: 01/31/2023
Info: model: AMD Ryzen 7 5800X3D bits: 64 type: MT MCP arch: Zen 3+ gen: 4
L3: 96 MiB desc: 1x96 MiB
Speed (MHz): avg: 3412 high: 3593 min/max: 2200/4549 boost: enabled
scaling: driver: acpi-cpufreq governor: performance cores: 1: 3593 2: 3400
3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
12: 3400 13: 3400 14: 3400 15: 3400 16: 3400 bogomips: 108594
Device-1: AMD Navi 21 [Radeon RX 6950 XT] vendor: ASRock driver: amdgpu
pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: DP-3
empty: DP-1,DP-2,HDMI-A-1 bus-ID: 0e:00.0 chip-ID: 1002:73a5
Screen-1: 0 s-res: 3440x1440 s-dpi: 96 s-size: 910x381mm (35.83x15.00")
s-diag: 987mm (38.84")
Monitor-1: DP-3 mapped: DisplayPort-2 model: Gigabyte G34WQC A
serial: <filter> built: 2022 res: 3440x1440 dpi: 110 gamma: 1.2
size: 797x334mm (31.38x13.15") diag: 864mm (34") modes: max: 3440x1440
min: 720x400
API: OpenGL v: 4.6 Mesa 22.3.6 renderer: AMD Radeon RX 6950 XT (navi21
LLVM 15.0.7 DRM 3.49 6.2.6-zen1-1-zen) direct-render: Yes
gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 0e:00.1 chip-ID: 1002:ab28
Device-2: AMD Starship/Matisse HD Audio vendor: ASRock
bus-ID: 10:00.4 chip-ID: 1022:1487 class-ID: 0403
Sound API: ALSA v: k6.2.6-zen1-1-zen running: yes
Device-1: Intel Ethernet I225-V driver: igc v: kernel pcie: gen: 2
speed: 5 GT/s lanes: 1 port: N/A bus-ID: 05:00.0 chip-ID: 8086:15f3
speed: 5 GT/s lanes: 1 bus-ID: 08:00.0 chip-ID: 8086:2723 class-ID: 0280
Device-1: Intel AX200 Bluetooth type: USB driver: btusb v: 0.8 bus-ID: 1-9:6
chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 3.68 TiB used: 104.93 GiB (2.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Fantom Drives model: VENOM8
lanes: 4 type: SSD serial: <filter> rev: EIFM31.6 temp: 32.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:3 model: JAJPR600M2TB size: 1.86 TiB
type: SSD serial: <filter> rev: 42A7T36A temp: 47.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%) used: 104.93 GiB (5.6%)
used: 104.93 GiB (5.6%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 31.27 GiB used: 1.8 MiB (0.0%) priority: 100
System Temperatures: cpu: 37.8 C mobo: N/A gpu: amdgpu temp: 48.0 C
mem: 46.0 C
Processes: 371 Uptime: 11m wakeups: 0 Memory: 31.27 GiB
used: 3.17 GiB (10.1%) Init: systemd v: 253 default: graphical
tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1886
libs: 543 tools: octopi,paru Shell: fish v: 3.6.0 default: Bash v: 5.1.16
running-in: konsole inxi: 3.3.25
Garuda (2.6.15-1):
System install date: 2023-03-18
Last full system update: 2023-03-18 ↻
Also including what's showing in terminal when I try to launch FireDragon from there.
JavaScript warning: resource://services-settings/Utils.jsm, line 65: unreachable code after returnstatement
ATTENTION: default value of option mesa_glthread overridden by environment.
console.error: ({})
[Parent 48008, Main Thread] WARNING: dbusmenu_menuitem_property_set_shortcut: assertion 'gtk_accelerator_valid(key, modifier)' failed: 'glib warning', file /home/main-builder/pkgwork/src/firefox-111.0/toolkit/xre/nsSigHandlers.cpp:167
(firedragon:48008): LIBDBUSMENU-GTK-CRITICAL **: 17:42:07.629: dbusmenu_menuitem_property_set_shortcut: assertion 'gtk_accelerator_valid(key, modifier)' failed
Thanks for your time and work on Garuda, it really is an amazing OS.
