Hi I've been having issues with Firedragon browser crashing on YouTube and Whats App. I noticed this first when I was using WhatsApp Web, the browser would display a message stating there's no memory, but checking my resources Ill be having about 6GB RAM.
The site(s) will work for less than a minute and it crashes. reloading the tab doesn't help.
May you please fix this. If I use another browser I don't experience this. I use Firefox and it works without any problems.
Kernel: 5.18.0-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=fd064626-5c5f-4be1-9f81-5f6ac8b2f47d rw [email protected]
resume=UUID=d8ae0431-a1a2-48e5-b320-073dd2566394 loglevel=3
Type: Desktop System: HP product: HP ProDesk 600 G2 DM v: N/A
serial: <superuser required> Chassis: type: 15 serial: <superuser required>
Mobo: HP model: 8169 v: KBC Version 05.26 serial: <superuser required>
UEFI: HP v: N22 Ver. 02.09 date: 03/10/2016
Info: model: Intel Core i5-6500T bits: 64 type: MCP arch: Skylake-S
family: 6 model-id: 0x5E (94) stepping: 3 microcode: 0xF0
desc: 1x6 MiB
Speed (MHz): avg: 3023 high: 3086 min/max: 800/3100 scaling:
driver: intel_pstate governor: performance cores: 1: 3000 2: 3009 3: 3000
4: 3086 bogomips: 19999
STIBP: disabled, RSB filling
Device-1: Intel HD Graphics 530 vendor: Hewlett-Packard driver: i915
v: kernel ports: active: HDMI-A-1 empty: DP-1, DP-2, DP-3, HDMI-A-2
bus-ID: 00:02.0 chip-ID: 8086:1912 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Monitor-1: HDMI-A-1 mapped: HDMI1 model: Mi Monitor serial: <filter>
built: 2020 res: 1920x1080 dpi: 92 gamma: 1.2
size: 530x290mm (20.87x11.42") diag: 603mm (23.7") ratio: 16:9 modes:
OpenGL: renderer: Mesa Intel HD Graphics 530 (SKL GT2) v: 4.6 Mesa 22.1.0
direct render: Yes
vendor: Hewlett-Packard driver: snd_hda_intel v: kernel bus-ID: 00:1f.3
Sound Server-1: ALSA v: k5.18.0-zen1-1-zen running: yes
Sound Server-2: JACK v: 1.9.21 running: no
Sound Server-4: PipeWire v: 0.3.51 running: yes
v: kernel port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b7 class-ID: 0200
Device-2: Realtek RTL8188EUS 802.11n Wireless Network Adapter type: USB
driver: r8188eu bus-ID: 1-4.3:5 chip-ID: 0bda:8179 class-ID: 0000
IF: wlp0s20f0u4u3 state: up mac: <filter>
Local Storage: total: 618.54 GiB used: 110.21 GiB (17.8%)
model: MZVLB512HAJQ-000L7 size: 476.94 GiB block-size: physical: 512 B
rev: 4L2QEXA7 temp: 34.9 C scheme: GPT
ID-2: /dev/sda maj-min: 8:0 vendor: TCSunBow model: X3 120GB
type: SSD serial: <filter> rev: 8A scheme: MBR
ID-3: /dev/sdb maj-min: 8:16 type: USB model: Multi Flash Reader
size: 29.81 GiB block-size: physical: 512 B logical: 512 B type: SSD
ID-1: / raw-size: 468.5 GiB size: 468.5 GiB (100.00%)
used: 110.21 GiB (23.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 562 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 468.5 GiB size: 468.5 GiB (100.00%)
ID-4: /var/log raw-size: 468.5 GiB size: 468.5 GiB (100.00%)
ID-5: /var/tmp raw-size: 468.5 GiB size: 468.5 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.65 GiB used: 1.5 MiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 8.18 GiB used: 0 KiB (0.0%)
System Temperatures: cpu: 41.0 C pch: 44.5 C mobo: N/A
Processes: 232 Uptime: 1h 30m wakeups: 0 Memory: 7.65 GiB
used: 3.75 GiB (49.0%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1371 lib: 340 Shell: fish
v: 3.4.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2021-09-24
Last full system update: 2022-05-29
Snapshots: Timeshift (maybe)
Failed units: bluetooth-autoconnect.service systemd-guest-user.service
