FireDragon seems to display images in unusually dark colors
I am a huge fan of FireDragon, I think it looks amazing and runs well. However, one huge issue I have is that the colors on pictures displayed on Fire Dragon are unusually dark. This isn't applied on websites, but usually jpegs and pngs. The new tab page on FIreDragon seems dark as well. I would like to fix this issue since I am an artist, and it is a bit cumbersome to open up another web browser just to get color-accurate images.
(I cannot upload images due to being a new user, so I will link them.)
Image shown on FireDragon: https://files.catbox.moe/57vldu.png
New Tab page: https://files.catbox.moe/pq2361.png
Image shown on Chromium: https://files.catbox.moe/v3jvhy.png
My garuda-inxi:
  Kernel: 6.2.7-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.2.1
    root=UUID=7cc289fb-c27a-4266-84b8-4ebdf4e6aa7a rw [email protected]
    resume=UUID=8bf68e3b-82b0-467b-ba0b-3e4e51481ab0 loglevel=3
  Desktop: Cinnamon v: 5.6.8 tk: GTK v: 3.24.37 wm: muffin vt: 7 dm: LightDM
    v: 1.32.0 Distro: Garuda Linux base: Arch Linux
  Type: Desktop Mobo: Gigabyte model: B550I AORUS PRO AX v: x.x
    serial: <superuser required> UEFI: American Megatrends LLC. v: FA
    date: 11/30/2022
  Info: model: AMD Ryzen 7 5700X bits: 64 type: MT MCP arch: Zen 3+ gen: 4
    L3: 32 MiB desc: 1x32 MiB
  Speed (MHz): avg: 3435 high: 3590 min/max: 2200/4662 boost: enabled
    scaling: driver: acpi-cpufreq governor: performance cores: 1: 3400 2: 3400
    3: 3400 4: 3400 5: 3400 6: 3400 7: 3400 8: 3400 9: 3400 10: 3400 11: 3400
    12: 3581 13: 3590 14: 3589 15: 3400 16: 3400 bogomips: 108604
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Gigabyte
    active: DP-1,HDMI-A-1 empty: DP-2,HDMI-A-2 bus-ID: 09:00.0
    chip-ID: 1002:73bf class-ID: 0300
  Display: x11 server: X.Org v: 21.1.7 driver: X: loaded: amdgpu
    unloaded: modesetting,radeon alternate: fbdev,vesa dri: radeonsi gpu: amdgpu
  Screen-1: 0 s-res: 2560x2520 s-dpi: 96 s-size: 677x667mm (26.65x26.26")
    s-diag: 950mm (37.42")
  Monitor-1: DP-1 mapped: DisplayPort-0 pos: primary,top-left
    model: MSI G271CQP serial: <filter> built: 2022 res: 2560x1440 dpi: 109
    gamma: 1.2 size: 597x336mm (23.5x13.23") diag: 676mm (26.6") ratio: 16:9
    modes: max: 2560x1440 min: 720x400
  Monitor-2: HDMI-A-1 mapped: HDMI-A-0 pos: bottom-r model: Kamvas 12
    built: 2020 res: 1920x1080 hz: 60 dpi: 190 gamma: 1.2
    size: 256x144mm (10.08x5.67") diag: 294mm (11.6") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  API: OpenGL v: 4.6 Mesa 23.0.0 renderer: AMD Radeon RX 6800 XT (navi21
    LLVM 15.0.7 DRM 3.49 6.2.7-zen1-1-zen) direct-render: Yes
    gen: 4 speed: 16 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:ab28
    bus-ID: 0b:00.4 chip-ID: 1022:1487 class-ID: 0403
  Sound API: ALSA v: k6.2.7-zen1-1-zen running: yes
    pcie: gen: 2 speed: 5 GT/s lanes: 1 port: f000 bus-ID: 05:00.0
  Device-2: MEDIATEK MT7921K Wi-Fi 6E 80MHz driver: mt7921e v: kernel pcie:
    gen: 2 speed: 5 GT/s lanes: 1 bus-ID: 06:00.0 chip-ID: 14c3:0608
  Device-1: MediaTek Wireless_Device type: USB driver: btusb v: 0.8
    bus-ID: 1-8:3 chip-ID: 0e8d:0608 class-ID: e001 serial: <filter>
  Local Storage: total: 2.73 TiB used: 575.7 GiB (20.6%)
  ID-1: /dev/nvme0n1 maj-min: 259:2 vendor: Samsung model: SSD 980 1TB
    lanes: 4 type: SSD serial: <filter> rev: 3B4QFXO7 temp: 38.9 C scheme: GPT
  ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
    rev: 2B2QEXM7 temp: 46.9 C scheme: GPT
  ID-1: / raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
    used: 13.23 GiB (1.5%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:4
    used: 608 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:3
  ID-3: /home raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
  ID-4: /var/log raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
  ID-5: /var/tmp raw-size: 896.82 GiB size: 896.82 GiB (100.00%)
  ID-1: swap-1 type: zram size: 31.27 GiB used: 1.8 MiB (0.0%) priority: 100
  ID-2: swap-2 type: partition size: 34.4 GiB used: 0 KiB (0.0%)
    priority: -2 dev: /dev/nvme0n1p3 maj-min: 259:5
  System Temperatures: cpu: 38.6 C mobo: 37.0 C gpu: amdgpu temp: 63.0 C
    mem: 66.0 C
  Processes: 426 Uptime: 8h 52m wakeups: 0 Memory: 31.27 GiB
  used: 5.54 GiB (17.7%) Init: systemd v: 253 default: graphical
  tool: systemctl Compilers: gcc: 12.2.1 Packages: pm: pacman pkgs: 1598
  libs: 519 tools: octopi,paru Shell: fish v: 3.6.0 running-in: gnome-terminal
  inxi: 3.3.25
Garuda (2.6.15-1):
  System install date:     2023-03-22
  Last full system update: 2023-03-23 ↻
Have you rebooted
Rebooted just now. No difference, unfortunately.
Could you provide the full URL (blogspot.com) of that cute little beaver?
Yes I know it's there in the screenshot, but it's a long URL with every possible character and there's too many chances I make a typo. :smiley:
Also the question is "Which one is right? Chromium or Firedragon?"
Both look possible to me.
How certain are you Chromium would display the accurate colors?
https://2.bp.blogspot.com/-e1__gaQz8fw/Uobv-jn36aI/AAAAAAAAFLk/srSymnOIVog/s1600/Capybara-Animals-Pictures.jpg is the link.
I found a solution. It was unusually, a color profile issue. The solution was to change the color profile to both of my monitors to be of the "D65" color profile. I don't understand why that gave FireDragon/Firefox issues, though...
I was certain Chromium displayed the correct colors, because I checked the image on my phone and it displayed the same colors as it was in Chromium.
Ok that's great you found it, cuz on my end the beaver displays exactly like in Chromium link you posted. You were right.
Subjectively, I'd say the Firedragon one is too dark and the Chromium one is too light/desaturated.
I think it's a Firefox thing rather than Firedragon specific.
Maybe something to do with color profiles?
How to configure Firefox color management
edit: derp, just saw your reply above.
