Hello.
The “Save as” dialog has a dropdownmenu with:
(I’ll translate from the german text)
“Website, complete”: Pics etc will go in a subdir (default)
“Website HTML only”: Saves the HTML page only
“Text files”: didn’t tried yet
“All Files”: didn’t tried yet
I will use “HTML only” more often.
Is it possible to change the order? Or make “HTML only” to default?
Hello.
That is not working. The Dropdownmenu is the same as before.
What I tried: Lookup a page → Save As HTML-Only somewhere → directly save as again same directory and “Website complete” is back again and saves as complete
Next Try: Another page opening a few sub pages → On a sub page save as HTML → that page again complete is default → close that page and look at the next opened sub page → save as in same directory HTML only → save as again and is complete again (and if i save, it is a complete save).
Hi @Amiganer , even though i don’t think is an issue , but there is no such a thing or a feature that can be changed there , at least in Firefox based browsers .
This is not what happened when I tested. Do you have “Website complete” files saved in that directory? Try moving those out or deleting them, so the directory contains only HTML-only files.
I opened a Webpage, Ctrl-S for Save as, Going to a Directory outside the old one, create a new Directory, Save as with HTML only there. If I open now the “Save as” again, it’s again “save complete”.
Next Webpage, Save as inside the first save, HTML-only, open “Save as” again and “complete” is the default.
I tried without the second “save as” for the same page, no change.
So other ideas?
Under “help” the version of Firefox is 119.0 and garuda-linux 1.0
Does one of you, who knows the Code a little better, is there a option of doing what I want (SAVE as with HTML-only the first time and next time HTML-only is the default till i change that)?
I realized why we are getting different behavior from this action: I was testing in a browser where there is an override on the hard-coded file picker settings Firedragon ships with. I tested with a KDE install where this setting is intact, and it has the behavior you have described (reverts back to “Web Page, complete” every time).
If you would like to override the hard-coded file picker, you can do so by setting up an override config file.
The KDE version seems to have a couple extra features (you can zoom in on the thumbnails for example), so you’ll have to decide for yourself if it is worth it or not to switch.
No change at all. The Picker is the same as before.
So I did:
deinstalled the firedragon, delete the config dir “~/.firedragon” completely.
Made a full update of all, restart.
Re-install firedragon. The “AUR” version breaks with an error, the “chatic-aur” installed fine. A had to select “firedragon kde integration” manually and installed it.
There is only one. If you mean firedagon.cfg?
IDK
Please, don’t sign your posts — every post has your profile information attached to it. Keep It Tidy. Thanks.
