Just curious why Firedragon is three point versions behind. Firefox is at version 121.0 and Librewolf is at 120.0.1 while Firedragon is still at 119.0.
There is a reason for this which isnât the maintainerâs laziness taken from the AUR pageâs pinned comment:
Dear Community!
For many reasons we decided to stop maintainingFiredragon
using itsLibrewolf
> source as base.
Rest assured, we are now moving towardsFloorp
source, which offers different features/tweaks and uses Firefox ESR as its own source. This new package is currently in Alpha tests and looks promising.
Since there are many changes with Firefox 120, including some major revamp of Librewolf patches that Firedragon is leveraging, we decided to freeze this Firedragon version at119
âŚ
Ultimately v119 will be completely replaced by its new Floorp base.
Floorp source can be found here.
We hope you will also enjoy our next version!
Basically with v119, there have been some changes to how Librewolf handles stuff and Floorp was around during that time as well. We already looked into rebasing to Floorp since itâs awesome and we had to decide where to focus on. There is little point in spending precious time to get something up that will ultimately be replaced by a new thing shortly after. I guess there will be test builds soon
Thanks for the info.
Unfortunately the ESR / LTS release is a deal-breaker for me for more than one reason, not the least of which is those kinds of browsers do not work on / with my collegeâs websites & portals due to being outdated (e.g. certificates too old, for one, or just being outright blocked).
Itâs not forks I am against, I like Firedragon. And also concepts like Mercury & Thorium, but they move at a snailâs pace and might as well be based on ESR. Itâs just that for my needs, I need to be on recent releases.
Wish you the best of luck though. It ought to be interesting. Iâm sure Iâll check it out at some point.
Install Floorp and try it out on your websites, thatâs the only way to be 100% sure, as Floorp has a lot of customizations underneath, maybe they took care of your concerns already.
If you donât want to install Floorp, could you plz share your URLs and I will try on my end, you can PM me if you donât want to share URLs public.
Iâm asking all this cuz I am very much interested in knowing what could go wrong with such browser (ESRs, etc.) and what could go outright right that could surpass our old way of providing Firedragon.
In essence: feedbacks.
As I understand it, the main or most important reason that browsers like that get blocked is because for whatever reason (security I would guess), the websites look for versions at least X version, e.g. at least Firefox version 120 or at least Chrome version 120.
I also could not access the website even with vanilla Firefox ESR or vanilla Chrome ESR. They would all fail. I investigated with Firefox ESR (I prefer FF or FF forks) and at least one reason it failed is outdated security certificates. (I was on the latest FF ESR at the time.) That may be the case with Chrome ESR too but I didnât investigate that.
Plus, there is an extension / addon required by online classes of my college for exams and there is ONLY a Chrome extension. Vanilla Chrome at that. No other browser is supported.
Therefore, due to these issues accessing the site and the extension requirement, I just checked out a Windows laptop which had the latest version of Chrome installed to avoid the whole situation / headache.
While I appreciate the offer to test out the website, another reason I donât want to use a browser based on an ESR release that I did not mention is that I want access to the latest features and quick security fixes so being based on the ESR release makes me not want to use it.
What stops you from installing Google Chrome? Hmm?
Firefox uses a current certificate store, which is updated every release as far as I know and can tell, do you have evidence otherwise
Mozilla Root Store Policy â Mozilla
Very easy solution to that, spoof user agent!
Well, what might one of those ânewâ features be? Wanting something new because it says new is different from actually needing or even using new features whatsoever! If you do have a ânewâ feature that you must have, I would love to know and have a link to it on:
As for updates, ESR does not at all mean old or outdated, it means it has stability. It gets security updates exactly as often as stable does, without delay. Arguably, this actually enables it to be more secure than something on stable. Breaking changes are not applied as frequently, and thus there is less ânewâ attack surface, and more time for any bugs present in the new features to be cleaned up before backporting to ESR.
Also to echo @Bro, did you try Googleâs Chrome or just Chromium?
I far prefer Firefox, I have ever since it transitioned from being Netscape long ago. That being said, I usually keep Chrome and other browsers including terminal browsers installed just in case I run into issues using Firefox. Iâm not sure why this is such a deal breaker, itâs just the common sense belt and suspenders approach so that you never get caught with your pants down.
Honestly there wasnât a single change lately which I considered to be interested enough to run nightly.
What we gain are quicker updates, less maintenance burden and a lot of new features.
I completely divested from Google. I donât use any Google products.
Maybe it was the websiteâs certificate that was the problem but if thatâs the case then why did the latest release of Chrome on the Windows laptop work perfectly and not mention any certificate problems? (I donât have the laptop anymore. Theyâre required to be turned in at the end of the quarter.)
Spoofing the user agent breaks fingerprinting prevention as I understand it. Someone correct me if Iâm wrong.
Doesnât matter what they are. I just mean I like to try out / test out the latest features without bothering with alphas, betas, or nightlies and the like. This is the approach of Mull Browser which I use on LineageOS. Itâs a FF fork based on the latest stable release as opposed to an ESR.
I am aware what an ESR release is and its focus on stability.
Iâm not trying to be argumentative or combative, for the record. Just stating my thoughts and preferences.
The only Chrome browser is Google Chrome. Why does your statement confuse me?
If they provided assets without HTTPS it could complain, there could be a temporary issue with the site, there could be an issue with DNS, maybe the site is on an intranet and DNS over HTTPS failed or was misconfigured⌠Without testing, who knows!
I can neither confirm nor deny this, but I havenât ever heard such a thing before.
I canât provide a link at the moment because I donât remember where I read it (possibly on reddit, haha) but a lot of security-minded browsers enable RFP (resist fingerprinting). (Canvas) Fingerprinting is a method of identifying web users. Enabling RFP makes users harder to identify (kind of similar in point but not method, to a VPN). This includes spoofing the user agent. Therefore changing it from what it is configured by default (when RFP is enabled) makes the user / browser stand out and be more easily identified.
That is my understanding. Anyone feel free to correct anything I may have wrong.
I guess thatâs a fair point; wanting to avoid being fingerprinted, but youâre missing the forest for the trees here. Itâs not a matter of resisting fingerprinting everywhere, but a matter of making sites function. Everyone gets fingerprinted, and it is entirely unavoidable! Youâre just spoofing information to provide a âfake/ephemeralâ fingerprint. This is not comparable to a VPN, which only changes the IP your traffic appears to come from, and they should not be conflated.
If youâve ever played around on any of the sites that allow you to inspect your fingerprint, youâll notice that youâre actually very much more identifiable when you block things. I personally see it more valuable to blend in with the crowd than stick out. Being fingerprinted on a site which youâve already submitted to seemly serves not much purpose, so why worry about a realistic fingerprint? Isnât it meant to be a âone-off-fixâ that allows a site to function?
