Hello, I recently installed Garuda on a new laptop and elected to remove Firedragon in favor of Firefox. The github cli login doesn't seem to work with Firefox so I attempted to reinstall Firedragon. Two issues:
- It doesn't appear to be the "stable" version (output below).
- I need to remove "Your browser is being managed by your organization." as I'd like to login with my Firefox account.
How do I correctly reinstall Firedragon-stable?
Output of "pacman -Qi firedragon firedragon-stable":
Version : 89.0.1-1
Description : Librewolf fork build using custom branding, settings & KDE patches by OpenSUSE
Architecture : x86_64
URL : https://gitlab.com/dr460nf1r3/settings/
Licenses : MPL GPL LGPL
Groups : None
Provides : None
Depends On : gtk3 libxt mime-types dbus-glib ffmpeg nss nspr ttf-font libpulse libwebp libvpx libjpeg zlib icu libevent libpipewire02 aom harfbuzz graphite dav1d kfiredragonhelper
Optional Deps : firejail-git: Sandboxing the browser using the included profiles
profile-sync-daemon: Load the browser profile into RAM [installed]
whoogle: Searching the web using a locally running Whoogle instance
searx: Searching the web using a locally running searX instance
networkmanager: Location detection via available WiFi networks [installed]
libnotify: Notification integration [installed]
pulseaudio: Audio support [installed]
speech-dispatcher: Text-to-Speech
hunspell-en_US: Spell checking, American English
libappindicator-gtk3: Global menu support for GTK apps [installed]
appmenu-gtk-module-git: Appmenu for GTK only
plasma5-applets-window-appmenu: Appmenu for Plasma only [installed]
Required By : None
Optional For : None
Conflicts With : firedragon-hg
Replaces : None
Installed Size : 193.77 MiB
Packager : Chaotic-AUR Wild Bear Node <[email protected]>
Build Date : Tue 22 Jun 2021 01:22:03 AM EDT
Install Date : Wed 23 Jun 2021 11:23:40 PM EDT
Install Reason : Explicitly installed
Install Script : Yes
Validated By : Signature
error: package 'firedragon-stable' was not found
Hint:
If you include terminal outputs in your post please use the proper output format in your post. Using "~" 3 times above and "~" 3 times below the text block will provide a readable, raw look.
