FireDragon pinned tabs repeatedly auto-resizing
I’ve searched for info about this issue and found nothing.
I tried pinning/unpinning several different sites and also a completely blank tab to see if it’s related to a certain URL and tried the same thing after using an extension to completely disable javascript in the browser and in all cases the behavior persisted.
Any suggestions on how to fix this? I mean, other than un-pinning my tabs.
Kernel: 6.11.6-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=f928425b-736b-4638-b376-0b6bca788ddb rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.2.3 tk: Qt v: N/A info: frameworks v: 6.7.0
Type: Laptop System: LENOVO product: 21FECTO1WW v: ThinkPad P16v Gen 1
Mobo: LENOVO model: 21FECTO1WW v: SDK0T76530 WIN
serial: <superuser required> part-nu: LENOVO_MT_21FE_BU_Think_FM_ThinkPad
P16v Gen 1 uuid: <superuser required> UEFI: LENOVO v: N3VET52W (1.52 )
date: 05/09/2024
ID-1: BAT0 charge: 89.1 Wh (99.1%) condition: 89.9/90.0 Wh (99.9%)
volts: 16.8 min: 15.5 model: Celxpert 5B11M90093 type: Li-poly
serial: <filter> status: not charging cycles: 3
Info: model: AMD Ryzen 7 PRO 7840HS w/ Radeon 780M Graphics bits: 64
microcode: 0xA704104
Speed (MHz): avg: 1098 min/max: 400/5137 boost: enabled scaling:
driver: amd-pstate-epp governor: powersave cores: 1: 1098 2: 1098 3: 1098
4: 1098 5: 1098 6: 1098 7: 1098 8: 1098 9: 1098 10: 1098 11: 1098 12: 1098
13: 1098 14: 1098 15: 1098 16: 1098 bogomips: 121384
Device-1: Advanced Micro Devices [AMD/ATI] Phoenix1 vendor: Lenovo
driver: amdgpu v: kernel arch: RDNA-3 code: Phoenix process: TSMC n4 (4nm)
built: 2023+ pcie: gen: 4 speed: 16 GT/s lanes: 16 ports: active: eDP-1
empty: DP-1, DP-2, DP-3, DP-4, DP-5, DP-6, HDMI-A-1, Writeback-1
bus-ID: c5:00.0 chip-ID: 1002:15bf class-ID: 0300 temp: 32.0 C
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-1:2 chip-ID: 174f:11a8
Monitor-1: eDP-1 res: 1745x1091 size: N/A modes: N/A
API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.2.6-arch1.1
glx-v: 1.4 direct-render: yes renderer: AMD Radeon 780M (radeonsi
gfx1103_r1 LLVM 18.1.8 DRM 3.59 6.11.6-zen1-1-zen) device-ID: 1002:15bf
memory: 1000 MiB unified: no display-ID: :1.0
API: Vulkan v: 1.3.295 layers: 9 device: 0 type: integrated-gpu name: AMD
Radeon 780M (RADV GFX1103_R1) driver: mesa radv v: 24.2.6-arch1.1
device-ID: 1002:15bf surfaces: xcb,xlib,wayland device: 1 type: cpu
v: 24.2.6-arch1.1 (LLVM 18.1.8) device-ID: 10005:0000
Device-1: Advanced Micro Devices [AMD/ATI] Rembrandt Radeon High Definition
Audio vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4
speed: 16 GT/s lanes: 16 bus-ID: c5:00.1 chip-ID: 1002:1640 class-ID: 0403
vendor: Lenovo driver: snd_pci_ps v: kernel alternate: snd_pci_acp3x,
snd_rn_pci_acp3x, snd_pci_acp5x, snd_pci_acp6x, snd_acp_pci,
snd_rpl_pci_acp6x, snd_sof_amd_renoir, snd_sof_amd_rembrandt,
snd_sof_amd_vangogh, snd_sof_amd_acp63 pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c5:00.5 chip-ID: 1022:15e2 class-ID: 0480
Device-3: Advanced Micro Devices [AMD] Family 17h/19h HD Audio
vendor: Lenovo driver: snd_hda_intel v: kernel pcie: gen: 4 speed: 16 GT/s
lanes: 16 bus-ID: c5:00.6 chip-ID: 1022:15e3 class-ID: 0403
API: ALSA v: k6.11.6-zen1-1-zen status: kernel-api with: aoss
Server-1: PipeWire v: 1.2.6 status: active with: 1: pipewire-pulse
Device-1: Qualcomm QCNFA765 Wireless Network Adapter vendor: Lenovo
driver: ath11k_pci v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1 link-max:
gen: 3 speed: 8 GT/s bus-ID: 02:00.0 chip-ID: 17cb:1103 class-ID: 0280
Device-1: USI driver: btusb v: 0.8 type: USB rev: 1.1 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 1-3:3 chip-ID: 10ab:9309 class-ID: e001
Local Storage: total: 1.86 TiB used: 146.13 GiB (7.7%)
ID-1: /dev/nvme0n1 maj-min: 259:6 vendor: Samsung
model: MZVL41T0HBLB-00BLL size: 953.87 GiB block-size: physical: 512 B
fw-rev: DL2QHXC7 temp: 34.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:0 vendor: Samsung
fw-rev: DL2QHXC7 temp: 32.9 C scheme: GPT
ID-1: / raw-size: 853.99 GiB size: 853.99 GiB (100.00%)
used: 29.01 GiB (3.4%) fs: btrfs dev: /dev/nvme1n1p5 maj-min: 259:5
used: 36.3 MiB (14.2%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:1
ID-3: /home raw-size: 853.99 GiB size: 853.99 GiB (100.00%)
ID-4: /var/log raw-size: 853.99 GiB size: 853.99 GiB (100.00%)
ID-5: /var/tmp raw-size: 853.99 GiB size: 853.99 GiB (100.00%)
ID-1: swap-1 type: zram size: 61.45 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 39.5 C mobo: N/A gpu: amdgpu temp: 33.0 C
Memory: total: 64 GiB available: 61.45 GiB used: 5.58 GiB (9.1%)
Processes: 377 Power: uptime: 27m states: freeze,mem,disk suspend: s2idle
image: 24.57 GiB services: org_kde_powerdevil, power-profiles-daemon,
upowerd Init: systemd v: 256 default: graphical tool: systemctl
Packages: 1937 pm: pacman pkgs: 1926 libs: 576 tools: octopi,paru
pm: flatpak pkgs: 11 Compilers: clang: 18.1.8 gcc: 14.2.1 Shell: garuda-inxi
default: Bash v: 5.2.37 running-in: konsole inxi: 3.3.36
System install date:     2024-11-03
Last full system update: 2024-11-09
Welcome to the Forums!
For troubleshooting, try the following and report results of each step.
