Hi all,
It seems that the KeepassXC extension isn't "seeing" my KeepassXC data base from FireDragon. I installed the extension to Firefox and that works fine.
Browser integration enabled, I bring up the settings in the extension, press settings, then connected databases and I see the button "connect". Usually, pressing that brings me over to my local KeepassXC installed application that presents me with a dialog box asking to name the database connection. However in this case, using FireDragon, it does not.
Furthermore, when looking at the general preferences for the extension in FireDragon, I see this:
KeePassXC-Browser needs KeePassXC to retrieve credentials.
You can download the latest stable version from https://keepassxc.org/
You are running KeePassXC version: unknown
Latest available version of KeePassXC: 2.7.1
The extension doesn't know the version of KeePassXC that I'm running. It's like FireDragon can't access things outside of itself?
Any ideas?
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 5.18.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=d917ce5c-c792-40d3-8be3-e52a01540a49 rw [email protected]
quiet
cryptdevice=UUID=8769dc5d-dbe7-4926-a1ac-01b6ad19e53d:luks-8769dc5d-dbe7-4926-a1ac-01b6ad19e53d
root=/dev/mapper/luks-8769dc5d-dbe7-4926-a1ac-01b6ad19e53d quiet splash
resume=/dev/mapper/luks-37fc0db4-4262-4fef-87de-743f699a1848 loglevel=3
Type: Laptop System: Apple product: MacBookPro8,1 v: 1.0
serial: <superuser required> Chassis: type: 10 v: Mac-94245B3640C91C81
Mobo: Apple model: Mac-94245B3640C91C81 v: MacBookPro8,1
serial: <superuser required> UEFI: Apple v: 87.0.0.0.0 date: 06/13/2019
ID-1: BAT0 charge: 42.2 Wh (100.0%) condition: 42.2/62.9 Wh (67.1%)
volts: 12.0 min: 10.9 model: SMP bq20z451 type: Li-ion serial: N/A
status: full cycles: 1209
Info: model: Intel Core i5-2435M bits: 64 type: MT MCP arch: Sandy Bridge
family: 6 model-id: 0x2A (42) stepping: 7 microcode: 0x2F
L3: 3 MiB desc: 1x3 MiB
Speed (MHz): avg: 833 high: 940 min/max: 800/3000 scaling:
driver: intel_cpufreq governor: schedutil cores: 1: 940 2: 798 3: 798
4: 798 bogomips: 19156
Type: l1tf
vendor: Apple driver: i915 v: kernel ports: active: LVDS-1
empty: DP-1, DP-2, DP-3, HDMI-A-1, HDMI-A-2, HDMI-A-3, VGA-1
bus-ID: 00:02.0 chip-ID: 8086:0126 class-ID: 0300
Device-2: Apple FaceTime HD Camera type: USB driver: uvcvideo
bus-ID: 1-2:3 chip-ID: 05ac:8509 class-ID: 0e02 serial: <filter>
compositor: kwin_x11 driver: X: loaded: intel unloaded: modesetting
alternate: fbdev,vesa gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1280x800 s-dpi: 96 s-size: 338x211mm (13.31x8.31")
s-diag: 398mm (15.69")
Monitor-1: LVDS-1 mapped: LVDS1 model: Apple 0x9cc3 built: 2009
res: 1280x800 hz: 60 dpi: 112 gamma: 1.2 size: 290x180mm (11.42x7.09")
diag: 337mm (13.3") ratio: 16:10 modes: 1280x800
OpenGL: renderer: Mesa Intel HD Graphics 3000 (SNB GT2)
v: 3.3 Mesa 22.1.0 direct render: Yes
driver: snd_hda_intel v: kernel bus-ID: 00:1b.0 chip-ID: 8086:1c20
Sound Server-1: ALSA v: k5.18.1-zen1-1-zen running: yes
Device-1: Broadcom NetXtreme BCM57765 Gigabit Ethernet PCIe driver: tg3
v: kernel pcie: gen: 1 speed: 2.5 GT/s lanes: 1 port: N/A bus-ID: 02:00.0
chip-ID: 14e4:16b4 class-ID: 0200
IF: enp2s0f0 state: down mac: <filter>
Device-2: Broadcom BCM4331 802.11a/b/g/n driver: wl v: kernel
modules: bcma pcie: gen: 1 speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0
chip-ID: 14e4:4331 class-ID: 0280
Device-1: Apple Bluetooth Host Controller type: USB driver: btusb v: 0.8
bus-ID: 1-1.1.3:8 chip-ID: 05ac:821a class-ID: fe01
Local Storage: total: 465.76 GiB used: 37.12 GiB (8.0%)
ID-1: /dev/sda maj-min: 8:0 vendor: Crucial model: CT500MX500SSD1
size: 465.76 GiB block-size: physical: 4096 B logical: 512 B
speed: 6.0 Gb/s type: SSD serial: <filter> rev: 023 scheme: GPT
ID-1: / raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
used: 37.12 GiB (8.1%) fs: btrfs dev: /dev/dm-0 maj-min: 254:0
mapped: luks-8769dc5d-dbe7-4926-a1ac-01b6ad19e53d
used: 720 KiB (0.2%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-4: /var/log raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-5: /var/tmp raw-size: 456.66 GiB size: 456.66 GiB (100.00%)
ID-1: swap-1 type: zram size: 7.68 GiB used: 0 KiB (0.0%) priority: 100
mapped: luks-37fc0db4-4262-4fef-87de-743f699a1848
System Temperatures: cpu: 79.0 C mobo: 0.0 C
Processes: 247 Uptime: 1h 44m wakeups: 3 Memory: 7.68 GiB
used: 3.24 GiB (42.2%) Init: systemd v: 251 tool: systemctl Compilers:
gcc: 12.1.0 Packages: pacman: 1482 lib: 355 Shell: fish v: 3.4.1
default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.16
Garuda (2.6.3-2):
System install date: 2022-03-09
Last full system update: 2022-05-30
Failed units: nmb.service
