I just updated the laptop via garuda-update and rebooted.
Firedragon no longer has any functioning buttons. When I start firedragon from the command line no extra information is given.
Also I now have another problem not sure if it is related: systemd-modules-load.service failed to load.
EDIT: may have to do with profiles. Not sure why an update ruins a profile. But when I restore last snapshot firedragon throws an error about profile is for a newer version of firedragon.
root=UUID=fee12699-5d85-4ddb-bae0-daf333cf53d5 rw rootflags=subvol=@
loglevel=3 quiet ibt=off
Type: Laptop System: Micro-Star product: GL65 9SE v: REV:1.0
Mobo: Micro-Star model: MS-16U5 v: REV:1.0 serial: <superuser required>
UEFI: American Megatrends v: E16U5IMS.102 date: 03/17/2020
ID-1: BAT1 charge: 24.9 Wh (57.2%) condition: 43.5/51.6 Wh (84.4%)
volts: 11.0 min: 10.9 model: MSI BIF0_9 type: Li-ion serial: N/A
status: not charging
model-id: 0x9E (158) stepping: 0xA (10) microcode: 0xF4
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 800 min/max: 800/4500 scaling: driver: intel_pstate
8: 800 9: 800 10: 800 11: 800 12: 800 bogomips: 62399
Device-1: Intel CoffeeLake-H GT2 [UHD Graphics 630] vendor: Micro-Star MSI
ports: active: eDP-1 empty: none bus-ID: 00:02.0 chip-ID: 8086:3e9b
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile] vendor: Micro-Star MSI
driver: nvidia v: 535.113.01 alternate: nouveau,nvidia_drm non-free: 535.xx+
status: current (as of 2023-09) arch: Turing code: TUxxx
process: TSMC 12nm FF built: 2018-22 pcie: gen: 1 speed: 2.5 GT/s
lanes: 16 link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0
chip-ID: 10de:1f11 class-ID: 0300
compositor: kwin_x11 driver: X: loaded: modesetting unloaded: nvidia
dri: iris gpu: i915 display-ID: :0 screens: 1
Monitor-1: eDP-1 model: AU Optronics 0xd0ed built: 2019 res: 1920x1080
hz: 120 dpi: 142 gamma: 1.2 size: 344x193mm (13.54x7.6") diag: 394mm (15.5")
ratio: 16:9 modes: 1920x1080
drv: nvidia device: 1 drv: iris device: 2 drv: swrast surfaceless:
drv: nvidia x11: drv: iris inactive: gbm,wayland
GT2) device-ID: 8086:3e9b memory: 15.1 GiB unified: yes
API: Vulkan v: 1.3.269 layers: 8 device: 0 type: integrated-gpu name: Intel
UHD Graphics 630 (CFL GT2) driver: mesa intel v: 23.2.1-arch1.2
device-ID: 8086:3e9b surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: nvidia v: 535.113.01
device-ID: 10de:1f11 surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe
Device-2: NVIDIA TU106 High Definition Audio vendor: Micro-Star MSI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
vendor: Micro-Star MSI driver: r8168 v: 8.052.01-NAPI modules: r8169 pcie:
gen: 1 speed: 2.5 GT/s lanes: 1 port: 3000 bus-ID: 03:00.0
v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5
lmp-v: 10 status: discoverable: no pairing: no class-ID: 7c010c
Local Storage: total: 1.38 TiB used: 977.16 GiB (69.4%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN520
SDAPNUW-512G-1032 size: 476.94 GiB block-size: physical: 512 B
logical: 512 B speed: 15.8 Gb/s lanes: 2 tech: SSD serial: <filter>
fw-rev: 20140000 temp: 42.9 C scheme: GPT
model: WD10JPVX-60JC3T0 size: 931.51 GiB block-size: physical: 4096 B
fw-rev: 1A01 scheme: GPT
ID-1: / raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
used: 89.78 GiB (61.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 4.3 MiB (1.4%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-3: /home raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-4: /var/log raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-5: /var/tmp raw-size: 146.44 GiB size: 146.44 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.46 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 64.0 C pch: 48.0 C mobo: N/A
Processes: 411 Uptime: 4m wakeups: 24975 Memory: total: 16 GiB
available: 15.46 GiB used: 4.55 GiB (29.4%) Init: systemd v: 254
Packages: pm: pacman pkgs: 1764 libs: 509 tools: octopi,paru Shell: fish
v: 3.6.1 running-in: konsole inxi: 3.3.30
Garuda (2.6.17-1):
System install date: 2022-07-14
Last full system update: 2023-10-30
Failed units: systemd-modules-load.service
