FireDragon: most websites fail with enhanced protection
I just did a full system update. Now, with FireDragon, many websites are failing to load and work unless Enhanced Protection is disabled for that website (using default privacy options).
Even this forum website fails to load unless I disable enhanced protection! It just shows the loading icons and loops forever. Is this a known issue?
Kernel: 6.12.13-1.1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
root=UUID=51ef4a7a-fb89-43c3-a466-7318e0363e7e rw rootflags=subvol=@
Desktop: KDE Plasma v: 6.3.0 tk: Qt v: N/A info: frameworks v: 6.11.0
Type: Laptop System: Acer product: Predator PH315-53 v: V2.04
Mobo: CML model: QX50_CMS v: V2.04 serial: <superuser required>
part-nu: 0000000000000000 uuid: <superuser required> UEFI: Insyde v: 2.04
date: 08/20/2021
ID-1: BAT1 charge: 41.7 Wh (100.0%) condition: 41.7/58.8 Wh (71.0%)
volts: 16.5 min: 15.4 model: SMP AP18E7M type: Li-ion serial: <filter>
status: not charging
Info: model: Intel Core i7-10750H bits: 64 type: MT MCP arch: Comet Lake
model-id: 0xA5 (165) stepping: 2 microcode: 0xFC
Speed (MHz): avg: 2439 min/max: 800/5000 scaling: driver: intel_pstate
governor: powersave cores: 1: 2439 2: 2439 3: 2439 4: 2439 5: 2439 6: 2439
7: 2439 8: 2439 9: 2439 10: 2439 11: 2439 12: 2439 bogomips: 62431
Device-1: Intel CometLake-H GT2 [UHD Graphics] vendor: Acer Incorporated ALI
ports: active: none off: eDP-1 empty: HDMI-A-2 bus-ID: 00:02.0
chip-ID: 8086:9bc4 class-ID: 0300
Device-2: NVIDIA TU106M [GeForce RTX 2060 Mobile]
vendor: Acer Incorporated ALI driver: nvidia v: 565.77
alternate: nouveau,nvidia_drm non-free: 550/565.xx+ status: current (as
of 2025-01; EOL~2026-12-xx) arch: Turing code: TUxxx process: TSMC 12nm FF
built: 2018-2022 pcie: gen: 1 speed: 2.5 GT/s lanes: 16 link-max: gen: 3
speed: 8 GT/s ports: active: none off: HDMI-A-1 empty: DP-1
bus-ID: 01:00.0 chip-ID: 10de:1f15 class-ID: 0300
Display: x11 server: X.Org v: 21.1.15 with: Xwayland v: 24.1.5
alternate: fbdev,intel,nv,vesa dri: iris gpu: i915,nvidia,nvidia-nvswitch
Monitor-1: HDMI-A-1 mapped: HDMI-1-0 note: disabled pos: primary
model: Samsung serial: <filter> built: 2016 res: mode: 1920x1080 hz: 60
scale: 100% (1) dpi: 40 gamma: 1.2 size: 1210x680mm (47.64x26.77")
diag: 1168mm (46") ratio: 16:9 modes: max: 1920x1080 min: 640x480
Monitor-2: eDP-1 note: disabled model: AU Optronics 0x82ed built: 2018
res: 1920x1080 dpi: 142 gamma: 1.2 size: 344x194mm (13.54x7.64")
drv: nvidia device: 1 drv: iris gbm: drv: iris surfaceless: drv: nvidia x11:
drv: iris inactive: wayland
API: OpenGL v: 4.6.0 compat-v: 4.6 vendor: intel mesa v: 24.3.4-arch1.1.1
device-ID: 8086:9bc4 memory: 7.54 GiB unified: yes
API: Vulkan v: 1.4.303 layers: 10 device: 0 type: integrated-gpu
name: Intel UHD Graphics (CML GT2) driver: N/A device-ID: 8086:9bc4
surfaces: xcb,xlib device: 1 type: discrete-gpu
name: NVIDIA GeForce RTX 2060 driver: N/A device-ID: 10de:1f15
surfaces: xcb,xlib device: 2 type: cpu name: llvmpipe (LLVM 19.1.7 256
Device-1: Intel Comet Lake PCH cAVS vendor: Acer Incorporated ALI
Device-2: NVIDIA TU106 High Definition Audio vendor: Acer Incorporated ALI
bus-ID: 01:00.1 chip-ID: 10de:10f9 class-ID: 0403
Device-3: Texas Instruments PCM2900B Audio CODEC
lanes: 1 mode: 1.1 bus-ID: 1-1.2:4 chip-ID: 08bb:29b0 class-ID: 0300
API: ALSA v: k6.12.13-1.1-lts status: kernel-api tools: N/A
Device-1: Intel Comet Lake PCH CNVi WiFi vendor: Rivet Networks Dual Band
Wi-Fi 6 Killer AX1650i 160MHz 2x2 driver: iwlwifi v: kernel
Device-2: Realtek Killer E2600 GbE vendor: Acer Incorporated ALI
bus-ID: 08:00.0 chip-ID: 10ec:2600 class-ID: 0200
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 1-14:5 chip-ID: 8087:0026
Local Storage: total: 3.19 TiB used: 2.07 TiB (64.7%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital model: PC SN730
SDBQNTY-512G-1014 size: 476.94 GiB block-size: physical: 512 B
fw-rev: 11101100 temp: 24.9 C scheme: GPT
ID-2: /dev/nvme1n1 maj-min: 259:2 vendor: Western Digital
model: WD Blue SN570 2TB size: 1.82 TiB block-size: physical: 512 B
fw-rev: 234200WD temp: 44.9 C scheme: GPT
ID-3: /dev/sda maj-min: 8:0 vendor: HGST (Hitachi) model: HTS721010A9E630
tech: HDD rpm: 7200 serial: <filter> fw-rev: A3J0 scheme: GPT
ID-1: / raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
used: 1007.06 GiB (56.8%) fs: btrfs dev: /dev/nvme1n1p3 maj-min: 259:5
ID-2: /boot/efi raw-size: 625 MiB size: 623.7 MiB (99.80%)
used: 584 KiB (0.1%) fs: vfat dev: /dev/nvme1n1p1 maj-min: 259:3
ID-3: /home raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
ID-4: /var/log raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
ID-5: /var/tmp raw-size: 1.73 TiB size: 1.73 TiB (100.00%)
ID-1: swap-1 type: partition size: 11.72 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p2 maj-min: 259:4
ID-2: swap-2 type: zram size: 15.45 GiB used: 256 KiB (0.0%) priority: 100
System Temperatures: cpu: 69.0 C pch: 65.0 C mobo: N/A
Memory: total: 16 GiB available: 15.45 GiB used: 8.9 GiB (57.6%)
Processes: 384 Power: uptime: 1h 36m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 6.13 GiB services: org_kde_powerdevil,
Packages: pm: pacman pkgs: 1769 libs: 469 tools: octopi,paru Compilers:
clang: 19.1.7 gcc: 14.2.1 alt: 13 Shell: garuda-inxi default: fish v: 3.7.1
Garuda (2.6.26-1.1):
System install date:     2024-07-17
Last full system update: 2025-02-17
I’m seeing that with the update, FireDragon is set to Strict; which disables ALL COOKIES.
Breaking all websites.
FireDragon should default to “Standard”. What does it show in about:config for firedragon.cfg.migration.contentBlockingCategoryStrict? Do you have a firedragon.overrides.cfg?
firedragon.cfg.migration.contentBlockingCategoryStrict is true
firedragon.overrides.cfg has nothing.
I am set to TRUE as well and I have no change in all the websites I use.
Hoping this addition can help stefan think of something better.
Since this is set to true, the migration should have definitely reset the “Enhanced Tracking Protection” to “Standard”.
To be sure: You didn’t set this to “Strict” manually?
No I never touched this, just ran a system update and saw all websites broken.
Ran several weeks worth of updates because I kept rolling back due to other NVIDIA problems.
