Hi there,
I use FireDragon as an altbrowser to ungoogled chromium, and it works great. The only annoying part is the Plasma KDE integration extension doesn't seem to work, and it's not clear to me how to fix that. The extension has a slash through it and when I click on it, the error message says "Failed to connect to the native host". My system is fully up-to-date as of 30 minutes ago. Here is the requested detail regarding my setup:
╭─[email protected] in ~
╰─λ garuda-inxi
Kernel: 5.18.8-262-tkg-bmq arch: x86_64 bits: 64 compiler: gcc v: 12.1.0
root=UUID=cd311ca9-2777-4d95-aa31-95c0dd25537f rw [email protected]
mitigations=off systemd.unified_cgroup_hierarchy=1 sysrq_always_enabled=1
nowatchdog
Desktop: KDE Plasma v: 5.25.2 tk: Qt v: 5.15.5 info: latte-dock
Type: Laptop System: Dell product: XPS 17 9720 v: N/A
Mobo: Dell model: 0W7GHH v: A00 serial: <superuser required> UEFI: Dell
v: 1.4.0 date: 03/08/2022
ID-1: BAT0 charge: 84.4 Wh (100.0%) condition: 84.4/95.1 Wh (88.7%)
volts: 13.2 min: 11.4 model: SMP DELL 01RR3YM type: Li-poly
serial: <filter> status: full
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse MX Master
Info: model: 12th Gen Intel Core i9-12900HK bits: 64 type: MST AMCP
arch: Alder Lake gen: core 12 built: 2021 process: Intel 7 (10nm ESF)
family: 6 model-id: 0x9A (154) stepping: 3 microcode: 0x41C
Topology: cpus: 1x cores: 14 mt: 6 tpc: 2 st: 8 threads: 20 smt: enabled
cache: L1: 1.2 MiB desc: d-8x32 KiB, 6x48 KiB; i-6x32 KiB, 8x64 KiB
L2: 11.5 MiB desc: 6x1.2 MiB, 2x2 MiB L3: 24 MiB desc: 1x24 MiB
Speed (MHz): avg: 1856 high: 4200 min/max: 400/5000:3800 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3752 2: 3569 3: 2911
4: 4200 5: 2281 6: 1500 7: 1022 8: 2943 9: 2681 10: 1009 11: 3371 12: 825
13: 811 14: 1178 15: 840 16: 948 17: 462 18: 918 19: 901 20: 1016
bogomips: 116846
Device-1: Intel Alder Lake-P Integrated Graphics vendor: Dell driver: i915
v: kernel arch: Gen12.2 process: Intel 10nm built: 2021-22+ ports:
active: none off: eDP-1 empty: DP-1, DP-2, DP-3, DP-4, DP-5, HDMI-A-1
bus-ID: 00:02.0 chip-ID: 8086:46a6 class-ID: 0300
Device-2: NVIDIA GA106M [GeForce RTX 3060 Mobile / Max-Q] vendor: Dell
driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm non-free: 515.xx+
status: current (as of 2022-06) arch: Ampere process: TSMC n7 (7nm)
built: 2020-22 pcie: gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4
speed: 16 GT/s lanes: 16 ports: active: none
empty: DP-6, DP-7, DP-8, DP-9 bus-ID: 01:00.0 chip-ID: 10de:2520
Device-3: NVIDIA GA104 [GeForce RTX 3060 Ti Lite Hash Rate]
vendor: eVga.com. driver: nvidia v: 515.48.07 alternate: nouveau,nvidia_drm
non-free: 515.xx+ status: current (as of 2022-06) arch: Ampere
process: TSMC n7 (7nm) built: 2020-22 pcie: gen: 3 speed: 8 GT/s lanes: 4
link-max: gen: 4 speed: 16 GT/s lanes: 16 ports: active: none
off: HDMI-A-2 empty: DP-10,DP-11,DP-12 bus-ID: a8:00.0 chip-ID: 10de:2489
Device-4: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-6:3 chip-ID: 0c45:6d1f class-ID: 0e02
gpu: i915,nvidia,nvidia-nvswitch display-ID: :0 screens: 1
s-diag: 1165mm (45.88")
Monitor-1: HDMI-A-2 mapped: HDMI-2-0 note: disabled pos: primary
model: HISENSE serial: <filter> built: 2020 res: 3840x2160 dpi: 59
gamma: 1.2 size: 1650x920mm (64.96x36.22") diag: 1889mm (74.4")
ratio: 16:9 modes: max: 3840x2160 min: 640x480
Monitor-2: eDP-1 note: disabled model: Sharp 0x1517 built: 2021
res: 3840x2160 dpi: 266 gamma: 1.2 size: 366x229mm (14.41x9.02")
diag: 432mm (17") ratio: 16:10 modes: 3840x2400
OpenGL: renderer: Mesa Intel Graphics (ADL GT2) v: 4.6 Mesa 22.1.2
direct render: Yes
Device-1: Intel Alder Lake PCH-P High Definition Audio vendor: Dell
alternate: snd_hda_intel,snd_sof_pci_intel_tgl bus-ID: 5-2:2
bus-ID: 00:1f.3 chip-ID: 2230:2002 chip-ID: 8086:51c8 class-ID: 0300
class-ID: 0401
Device-2: NVIDIA vendor: Dell driver: snd_hda_intel v: kernel pcie:
gen: 1 speed: 2.5 GT/s lanes: 8 link-max: gen: 4 speed: 16 GT/s lanes: 16
Device-3: NVIDIA GA104 High Definition Audio vendor: eVga.com.
link-max: gen: 4 speed: 16 GT/s lanes: 16 bus-ID: a8:00.1
Device-4: Plugable TBT3-UDV Dock Audio type: USB
Sound Server-1: ALSA v: k5.18.8-262-tkg-bmq running: yes
Device-2: Intel I210 Gigabit Network driver: igb v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 port: 4000 bus-ID: 76:00.0 chip-ID: 8086:1533
IF: enp118s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Device-3: ASIX AX88179 Gigabit Ethernet type: USB driver: ax88179_178a
bus-ID: 16-1:3 chip-ID: 0b95:1790 class-ID: ff00 serial: <filter>
IF: enp173s0u1 state: down mac: <filter>
IF-ID-1: virbr0 state: up speed: 10 Mbps duplex: unknown mac: <filter>
IF-ID-2: vnet0 state: unknown speed: 10 Mbps duplex: full mac: <filter>
Device-1: Intel type: USB driver: btusb v: 0.8 bus-ID: 1-10:5
chip-ID: 8087:0033 class-ID: e001
Local Storage: total: 3.64 TiB used: 1.53 TiB (42.0%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 32.9 C
ID-2: /dev/nvme1n1 maj-min: 259:3 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 type: SSD serial: <filter> rev: 5B2QGXA7 temp: 35.9 C
ID-1: / raw-size: 1.82 TiB size: 1.82 TiB (100.00%)
used: 338.38 GiB (18.2%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
used: 600 KiB (0.2%) fs: vfat dev: /dev/nvme0n1p1 maj-min: 259:1
ID-1: swap-1 type: zram size: 62.5 GiB used: 0 KiB (0.0%) priority: 100
System Temperatures: cpu: 49.0 C mobo: N/A
Processes: 455 Uptime: 16h 49m wakeups: 29 Memory: 62.5 GiB
used: 31.95 GiB (51.1%) Init: systemd v: 251 default: graphical
tool: systemctl Compilers: gcc: 12.1.0 clang: 13.0.1 Packages: pacman: 1925
lib: 549 Shell: fish v: 3.4.1 running-in: konsole inxi: 3.3.19
Garuda (2.6.4-2):
System install date: 2022-06-29
Last full system update: 2022-06-30 ↻
