I was wondering since floorp 12 is coming later this year if the firedragon flatpak might be set to the catppuccin theme. It’s a bit more subtle and might fit for more people out of the box. Since some don’t really know you can change themes. But merely a suggestion.
You’re asking to change the DEFAULT flatpack look or to provide a second FD flatpack that would be catppuccin theme?
I thought we already did the latter. I will check.
I haven’t checked to see if there was 2, but i meant to change the current dragonized one to catppuccin
The catppuccin version is only in chaotic-aur, not in flathub. Personally I prefer dragonized, but I wouldn’t care too much if the flathub version changed the theming. Using it on Fedora, where it’s a theming unicorn either way
It’s also offered as AppImage.
We discussed the possibility to drop it on the AppImageHub but I guess someone did it already and does not maintain it up to date.
ive only ever used the app image from the gitlab i never even thought to look at the hub haha but ive only ever used it when checking bugs
