$ garuda-inxi
Kernel: 5.16.13-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=c8982a18-bb6f-4ff7-9721-342b22111ce0 rw [email protected]
resume=UUID=708a711b-88d8-4d3b-8c31-1d7ddd168843 loglevel=3
Mobo: ASUSTeK model: PRIME Z690-P WIFI D4 v: Rev 1.xx
serial: <superuser required> UEFI: American Megatrends v: 0407
date: 09/13/2021
Info: model: 12th Gen Intel Core i5-12600K bits: 64 type: MST AMCP
arch: Alder Lake family: 6 model-id: 0x97 (151) stepping: 2 microcode: 0xD
Topology: cpus: 1x cores: 10 mt: 6 tpc: 2 st: 4 threads: 16 smt: enabled
cache: L1: 864 KiB desc: d-4x32 KiB, 6x48 KiB; i-6x32 KiB, 4x64 KiB
L2: 9.5 MiB desc: 6x1.2 MiB, 1x2 MiB L3: 20 MiB desc: 1x20 MiB
Speed (MHz): avg: 4437 high: 4900 min/max: 800/6300:3600 scaling:
driver: intel_pstate governor: performance cores: 1: 4554 2: 4842 3: 4473
4: 4832 5: 4708 6: 4893 7: 4662 8: 4626 9: 4577 10: 4686 11: 4848
12: 4900 13: 3600 14: 3600 15: 3603 16: 3600 bogomips: 117964
Device-1: NVIDIA GP106 [GeForce GTX 1060 3GB] vendor: ZOTAC driver: nvidia
v: 510.54 alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s
lanes: 16 bus-ID: 01:00.0 chip-ID: 10de:1c02 class-ID: 0300
loaded: nvidia gpu: nvidia display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 101 s-size: 483x272mm (19.0x10.7")
s-diag: 554mm (21.8")
Monitor-1: HDMI-0 res: 1920x1080 hz: 75 dpi: 102
size: 480x270mm (18.9x10.6") diag: 551mm (21.7")
OpenGL: renderer: NVIDIA GeForce GTX 1060 3GB/PCIe/SSE2
v: 4.6.0 NVIDIA 510.54 direct render: Yes
Device-1: Intel Alder Lake-S HD Audio vendor: ASUSTeK driver: snd_hda_intel
Device-2: NVIDIA GP106 High Definition Audio vendor: ZOTAC
bus-ID: 01:00.1 chip-ID: 10de:10f1 class-ID: 0403
Sound Server-1: ALSA v: k5.16.13-zen1-1-zen running: yes
pcie: gen: 2 speed: 5 GT/s lanes: 1 port: 4000 bus-ID: 05:00.0
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
v: 0.6 port: N/A bus-ID: 00:0e.0 chip-ID: 8086:467f rev: class-ID: 0104
Local Storage: total: 2.28 TiB used: 167.78 GiB (7.2%)
ID-1: /dev/sda maj-min: 8:0 model: N/A size: 447.13 GiB block-size:
physical: 512 B logical: 512 B speed: 6.0 Gb/s type: SSD serial: <filter>
rev: 8A0 scheme: GPT
ID-2: /dev/sdb maj-min: 8:16 vendor: Seagate model: ST1000DM003-1CH162
speed: 6.0 Gb/s type: HDD rpm: 7200 serial: <filter> rev: CC49
model: WD10JPCX-24UE4T0 size: 931.51 GiB block-size: physical: 4096 B
rev: 1A01 scheme: GPT
ID-4: /dev/sdd maj-min: 8:48 type: USB vendor: SanDisk model: USB 3.2Gen1
size: 28.64 GiB block-size: physical: 512 B logical: 512 B type: N/A
serial: <filter> rev: 1.00 scheme: GPT
ID-1: / raw-size: 429.54 GiB size: 429.54 GiB (100.00%)
used: 34.67 GiB (8.1%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
ID-2: /boot/efi raw-size: 513 MiB size: 512 MiB (99.80%)
used: 580 KiB (0.1%) fs: vfat dev: /dev/sda1 maj-min: 8:1
ID-3: /home raw-size: 764.84 GiB size: 764.84 GiB (100.00%)
used: 133.11 GiB (17.4%) fs: btrfs dev: /dev/sdb5 maj-min: 8:21
ID-4: /var/log raw-size: 429.54 GiB size: 429.54 GiB (100.00%)
ID-5: /var/tmp raw-size: 429.54 GiB size: 429.54 GiB (100.00%)
ID-1: swap-1 type: partition size: 17.09 GiB used: 0 KiB (0.0%)
ID-2: swap-2 type: zram size: 15.37 GiB used: 1.66 GiB (10.8%)
System Temperatures: cpu: 27.8 C mobo: N/A gpu: nvidia temp: 42 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 56%
Processes: 448 Uptime: 10m wakeups: 0 Memory: 15.37 GiB
used: 5.21 GiB (33.9%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 Packages: pacman: 1999 lib: 557 Shell: fish v: 3.3.1
running-in: konsole inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2021-12-10
Last full system update: 2022-03-09
This warning appears when I try to launch Firedragon right after KDE finishes loading. It only correctly opens if launched ~30 seconds after KDE loads.
