Firedragon, does it onnly come with the distro?
Is it dowloadable seperately, or does it onnly come with the distro?
There are multiple ways to obtain FireDragon on Linux. Windows and MacOSX builds are also available.
  • Archlinux builds can be obtained in a few ways:
    • Install it via the firedragon AUR package
    • Install it via the firedragon-bin AUR package if you do not wish to compile the package yourself
    • Or use the Chaotic-AUR repository to install and update it with Pacman (maintained by the FireDragon maintainer dr460nf1r3)
  • NixOS builds available at Chaotic-Nyx
    • Either install the flake and put firedragon as any other Nixpkgs package
    • Or run it directly via nix run github:chaotic-cx/nyx/nyxpkgs-unstable#firedragon
  • Flatpak builds can be fetched from FlatHub
  • AppImage builds are available via our GitLab releases
  • Binary tarballs can also be obtained via GitLab releases
  • Windows builds available via GitLab releases
  • MacOSX builds available via GitLab releases
  • The Catppuccin version simply uses -catppuccin following the standard Firedragon package name.
Cool.
It wants to download a file called stream.ts when I click it.
Cloudflare is probably intervening again. Which link? I just tested the links from GitLab (*.exe, *.dmg, *.AppImage, etc.), no issues.
The link above the post that says that.
All links work fine for me, and you seem to be the only one experiencing issues with Cloudflare. But that’s a different topic and has nothing to do with this thread. :wink:
