So my system already has the audio issue patched, but I'm still getting constant freezes in FireDragon making it basically unusable. I've also turned off hardware acceleration which didn't change anything. This issue just randomly appeared yesterday, no idea why.
Provided system information
Kernel: 5.16.0-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.1.0
root=UUID=37536d2b-56c7-4224-bd6a-a48d164c6ef7 rw rootflags=subvol=@
Type: Desktop Mobo: MEDION model: B560H6-EM v: 1.0
serial: <superuser required> UEFI: American Megatrends v: 560H6W0X.019
date: 07/12/2021
Info: model: 11th Gen Intel Core i5-11400 bits: 64 type: MT MCP
arch: Rocket Lake family: 6 model-id: 0xA7 (167) stepping: 1
microcode: 0x40
L1: 480 KiB desc: d-6x48 KiB; i-6x32 KiB L2: 3 MiB desc: 6x512 KiB
L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 4114 high: 4200 min/max: 800/4400 scaling:
driver: intel_pstate governor: performance cores: 1: 4025 2: 4137 3: 4200
4: 4091 5: 4146 6: 4128 7: 4143 8: 4141 9: 4200 10: 4089 11: 3907
12: 4167 bogomips: 62208
Device-1: NVIDIA GA106 [GeForce RTX 3060] vendor: ZOTAC driver: nvidia
v: 495.46 alternate: nouveau,nvidia_drm bus-ID: 01:00.0 chip-ID: 10de:2503
Device-2: SHENZHEN EMEET HD Webcam eMeet C960 type: USB
driver: hid-generic,snd-usb-audio,usbhid,uvcvideo bus-ID: 1-5:5
chip-ID: 328f:2013 class-ID: 0300 serial: <filter>
loaded: nvidia unloaded: modesetting alternate: fbdev,nouveau,nv,vesa
Screen-1: 0 s-res: 3840x1080 s-dpi: 90 s-size: 1084x301mm (42.7x11.9")
s-diag: 1125mm (44.3")
Monitor-1: DP-0 res: 1920x1080 dpi: 94 size: 521x293mm (20.5x11.5")
diag: 598mm (23.5")
Monitor-2: DP-2 res: 1920x1080 dpi: 90 size: 544x303mm (21.4x11.9")
diag: 623mm (24.5")
OpenGL: renderer: NVIDIA GeForce RTX 3060/PCIe/SSE2
v: 4.6.0 NVIDIA 495.46 direct render: Yes
Device-1: Intel Tiger Lake-H HD Audio vendor: MEDION AG
bus-ID: 00:1f.3 chip-ID: 8086:43c8 class-ID: 0403
Device-2: NVIDIA vendor: ZOTAC driver: snd_hda_intel v: kernel
Device-3: JMTek LLC. USB PnP Audio Device type: USB
driver: hid-generic,snd-usb-audio,usbhid bus-ID: 1-1:2 chip-ID: 0c76:161e
Device-4: SHENZHEN EMEET HD Webcam eMeet C960 type: USB
Sound Server-1: ALSA v: k5.16.0-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.43 running: yes
vendor: MEDION AG driver: r8169 v: kernel port: 3000 bus-ID: 03:00.0
bus-ID: 1-14:6 chip-ID: 8087:0026 class-ID: e001
Local Storage: total: 953.87 GiB used: 79.04 GiB (8.3%)
model: MZVL21T0HCLR-00B00 size: 953.87 GiB block-size: physical: 512 B
rev: GXA7301Q temp: 35.9 C scheme: GPT
used: 79.04 GiB (8.3%) fs: btrfs dev: /dev/nvme0n1p2 maj-min: 259:2
ID-1: swap-1 type: zram size: 15.5 GiB used: 3.57 GiB (23.1%)
System Temperatures: cpu: 75.0 C mobo: N/A gpu: nvidia temp: 46 C
Fan Speeds (RPM): N/A gpu: nvidia fan: 59%
Processes: 387 Uptime: 2h 51m wakeups: 0 Memory: 15.5 GiB
used: 12.21 GiB (78.8%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.1.0 clang: 13.0.0 Packages: pacman: 1836 lib: 535 Shell: fish
v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole inxi: 3.3.11
