Greetings,
As of the most recent Firedragon update (11.11.0) the about:preferences#design
page is blank if loaded directly or will simply display the first preference section loaded. As of now, these settings are inaccessible (found this when going to try and change default firedragon shortcuts which I believe were in this section, otherwise those settings are missing too).
garuda-inxi:
Kernel: 6.8.1-zen1-1-zen arch: x86_64 bits: 64 compiler: gcc v: 13.2.1
root=UUID=acc91bbd-51b8-4669-9368-f85ecd75b0a1 rw rootflags=subvol=@
resume=UUID=5bb1f004-d544-4ddf-bfac-8a1cf21296d8 loglevel=3 ibt=off
Desktop: KDE Plasma v: 6.0.2 tk: Qt v: N/A info: frameworks v: 6.0.0
Type: Laptop System: LENOVO product: ThinkPad W541 v: 1.0
Mobo: LENOVO model: ThinkPad W541 v: 1.0 serial: <superuser required>
BIOS: coreboot v: 4.20-410-g3e523b495c date: 06/17/2023
Info: model: Intel Core i7-4710MQ bits: 64 type: MT MCP arch: Haswell
L3: 6 MiB desc: 1x6 MiB
Speed (MHz): avg: 3122 high: 3500 min/max: 800/3500 scaling:
driver: intel_cpufreq governor: performance cores: 1: 3500 2: 2494 3: 2494
4: 3500 5: 3500 6: 3500 7: 2495 8: 3500 bogomips: 39910
Device-1: Intel 4th Gen Core Processor Integrated Graphics vendor: Lenovo
driver: i915 v: kernel arch: Gen-7.5 process: Intel 22nm built: 2013 ports:
active: eDP-1 empty: DP-1, DP-2, HDMI-A-1, HDMI-A-2, VGA-1 bus-ID: 00:02.0
chip-ID: 8086:0416 class-ID: 0300
Device-2: NVIDIA GK107GLM [Quadro K1100M] vendor: Lenovo driver: nvidia
v: 470.239.06 alternate: nouveau,nvidia_drm non-free: series: 470.xx+
status: legacy-active (EOL~2024-09-xx) arch: Kepler code: GKxxx
process: TSMC 28nm built: 2012-2018 pcie: gen: 1 speed: 2.5 GT/s lanes: 16
link-max: gen: 3 speed: 8 GT/s bus-ID: 01:00.0 chip-ID: 10de:0ff6
Device-3: Bison Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-12:4 chip-ID: 5986:026a
class-ID: 0e02
unloaded: nouveau alternate: fbdev,intel,nv,vesa dri: crocus
API: EGL v: 1.5 hw: drv: intel crocus drv: nvidia platforms: device: 0
drv: nvidia device: 1 drv: crocus device: 3 drv: swrast gbm: drv: crocus
surfaceless: drv: crocus wayland: drv: crocus x11: drv: crocus
inactive: device-2
API: OpenGL v: 4.6.0 compat-v: 4.5 vendor: intel mesa v: 24.0.3-arch1.1
glx-v: 1.4 direct-render: yes renderer: Mesa Intel HD Graphics 4600 (HSW
GT2) device-ID: 8086:0416 memory: 1.46 GiB unified: yes display-ID: :1.0
API: Vulkan v: 1.3.279 layers: 4 device: 0 type: integrated-gpu name: Intel
HD Graphics 4600 (HSW GT2) driver: mesa intel v: 24.0.3-arch1.1
device-ID: 8086:0416 surfaces: xcb,xlib,wayland device: 1
type: discrete-gpu name: Quadro K1100M driver: nvidia v: 470.239.06
device-ID: 10de:0ff6 surfaces: xcb,xlib,wayland device: 2 type: cpu
v: 24.0.3-arch1.1 (LLVM 17.0.6) device-ID: 10005:0000
vendor: Lenovo driver: snd_hda_intel v: kernel bus-ID: 00:03.0
Device-2: Intel 8 Series/C220 Series High Definition Audio
vendor: Lenovo 8 driver: snd_hda_intel v: kernel bus-ID: 00:1b.0
chip-ID: 8086:8c20 class-ID: 0403
Device-3: NVIDIA GK107 HDMI Audio vendor: Lenovo driver: snd_hda_intel
chip-ID: 10de:0e1b class-ID: 0403
API: ALSA v: k6.8.1-zen1-1-zen status: kernel-api tools: N/A
Server-1: PipeWire v: 1.0.4 status: active with: 1: pipewire-pulse
Device-1: Intel Ethernet I217-LM driver: N/A modules: e1000e port: 1040
bus-ID: 00:19.0 chip-ID: 8086:153a class-ID: 0200
Device-2: Intel Wireless 7260 driver: iwlwifi v: kernel pcie: gen: 1
speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 8086:08b2 class-ID: 0280
rev: 2.0 speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-11:3 chip-ID: 8087:07dc
rfk-block: hardware: no software: yes address: <filter> bt-v: 4.0 lmp-v: 6
Local Storage: total: 931.51 GiB used: 44.89 GiB (4.8%)
ID-1: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 870 EVO 1TB
tech: SSD serial: <filter> fw-rev: 3B6Q scheme: MBR
ID-1: / raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
used: 44.89 GiB (4.9%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
ID-2: /home raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
ID-3: /var/log raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
ID-4: /var/tmp raw-size: 914.37 GiB size: 914.37 GiB (100.00%)
ID-1: swap-1 type: zram size: 15.58 GiB used: 0 KiB (0.0%) priority: 100
ID-2: swap-2 type: partition size: 17.14 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/sda2 maj-min: 8:2
System Temperatures: cpu: 53.0 C mobo: N/A
Memory: total: 16 GiB available: 15.58 GiB used: 3.65 GiB (23.4%)
Processes: 262 Power: uptime: 39m states: freeze,standby,mem,disk
suspend: deep avail: s2idle,shallow wakeups: 0 hibernate: platform
avail: shutdown, reboot, suspend, test_resume image: 6.18 GiB
services: org_kde_powerdevil, power-profiles-daemon, upowerd Init: systemd
v: 255 default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1912 libs: 438 tools: octopi,paru pm: flatpak
pkgs: 0 Compilers: clang: 17.0.6 gcc: 13.2.1 Shell: garuda-inxi
default: Bash v: 5.2.26 running-in: kitty inxi: 3.3.33
Garuda (2.6.23-1):
System install date: 2023-12-07
Last full system update: 2024-03-20 ↻
