In firedragon you can’t set widget.use-xdg-desktop-portal.file-picker to 2. Normally you set this so you can get the kde or local native system file picker. I don’t remember this being a issue a while ago but I could be wrong.
╰─ inxi -Faz --zv
Kernel: 6.12.9-cachyos arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
parameters: BOOT_IMAGE=(hd3,gpt2)/@nix-subsystem/boot/kernels/7qqvxv5l8syiwcby0sdaczf2cdgx0gpa-linux-6.12.9-bzImage
init=/nix/store/bv1dz7m6grf70j1hvs7139bdj6k30z4s-nixos-system-elite-garuda-garuda-nix-subsystem-25.05.20250108.bffc22e/init
acpi_call quiet psi=1 root=fstab splash loglevel=0
Desktop: KDE Plasma v: 6.2.5 tk: Qt v: N/A info: frameworks v: 6.9.0
wm: kwin_wayland with: krunner vt: 8 dm: LightDM v: 1.32.0
Distro: NixOS 25.05 (Warbler)
Type: Desktop Mobo: ASUSTeK model: PRIME X570-PRO v: Rev X.0x
UEFI: American Megatrends v: 5013 date: 03/22/2024
Info: model: AMD Ryzen 7 3700X bits: 64 type: MT MCP arch: Zen 2 gen: 3
L3: 32 MiB desc: 2x16 MiB
Speed (MHz): avg: 4319 high: 4325 min/max: 550/4426 boost: enabled
scaling: driver: amd-pstate-epp governor: performance cores: 1: 4324 2: 4320
3: 4288 4: 4323 5: 4325 6: 4325 7: 4325 8: 4325 9: 4299 10: 4324 11: 4325
12: 4324 13: 4318 14: 4323 15: 4324 16: 4324 bogomips: 115207
Message: Required tool lspci not installed. Check --recommends
compositor: kwin_wayland driver: N/A display-ID: 0 screens: 1
Screen-1: 0 s-res: 3440x1440 s-size: <missing: xdpyinfo>
Monitor-1: DP-1 res: 3440x1440 hz: 144 dpi: 109
size: 800x335mm (31.5x13.19") diag: 867mm (34.15") modes: N/A
Device-1: BurrBrown from Texas Instruments USB AUDIO CODEC
lanes: 1 mode: 1.1 bus-ID: 5-2:3 chip-ID: 08bb:29c0 class-ID: 0300
API: ALSA v: k6.12.9-cachyos status: kernel-api tools: N/A
tools: pw-cat,pw-cli,wpctl
Server-2: PulseAudio v: 17.0 status: off (using pipewire-pulse)
tools: pacat,pactl
IF-ID-1: 40905_ca-tr_wg state: unknown speed: N/A duplex: N/A mac: N/A
IF-ID-2: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
IF-ID-3: wlan0 state: down mac: <filter>
Info: services: iwd, NetworkManager, systemd-timesyncd
Device-1: N/A driver: btusb v: 0.8 type: USB rev: 2.0 speed: 12 Mb/s
lanes: 1 mode: 1.1 bus-ID: 3-6:3 chip-ID: 8087:07dc class-ID: e001
Report: hciconfig ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.0
lmp-v: 6 sub-v: e00 hci-v: 6 rev: e00 class-ID: 6c0104
Info: acl-mtu: 1021:5 sco-mtu: 96:6 link-policy: rswitch hold sniff
link-mode: peripheral accept service-classes: rendering, capturing, audio,
telephony
Local Storage: total: 4.68 TiB used: 3.03 TiB (64.8%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: HP model: SSD EX920 1TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 32A0T2IA temp: 42.9 C
ID-2: /dev/nvme1n1 maj-min: 259:7 vendor: Samsung model: SSD 980 PRO 2TB
lanes: 4 tech: SSD serial: <filter> fw-rev: 5B2QGXA7 temp: 44.9 C
ID-3: /dev/sda maj-min: 8:0 vendor: OCZ model: VERTEX3 size: 111.79 GiB
serial: <filter> fw-rev: 2.22 scheme: GPT
model: WD20EZAZ-00L9GB0 size: 1.82 TiB block-size: physical: 4096 B
fw-rev: 0A80 scheme: GPT
ID-1: / raw-size: 1.8 TiB size: 1.8 TiB (100.00%) used: 1.48 TiB (81.9%)
fs: btrfs dev: /dev/nvme1n1p2 maj-min: 259:9
Kernel: swappiness: 180 (default 60) cache-pressure: 100 (default) zswap: no
ID-1: swap-1 type: partition size: 17.07 GiB used: 0 KiB (0.0%)
priority: -2 dev: /dev/nvme1n1p3 maj-min: 259:10
ID-2: swap-2 type: zram size: 28.13 GiB used: 710.1 MiB (2.5%) priority: 5
System Temperatures: cpu: 44.0 C mobo: 39.0 C gpu: amdgpu temp: 49.0 C
mem: 68.0 C
Fan Speeds (rpm): N/A gpu: amdgpu fan: 624
Memory: total: 32 GiB available: 31.25 GiB used: 8.29 GiB (26.5%)
Processes: 464 Power: uptime: 5h 42m states: freeze,mem,disk suspend: deep
suspend, test_resume image: 12.48 GiB services: org_kde_powerdevil,
Packages: 4092 pm: nix-default pkgs: 53 pm: nix-sys pkgs: 3775 libs: 820
pm: nix-usr pkgs: 240 libs: 73 pm: flatpak pkgs: 24 Compilers: N/A
Shell: fish v: 3.7.1 default: Bash running-in: .kitty-wrapped inxi: 3.3.35
