FD has a + on the page window top left, how can I get rid of it. Sorry for the duh question before, I found the answer.
So that in the webpage window, when I push the + it says add panel. How do I just get rid of the +?
i have a issue there
if i open tabs the website isnt loading all elemets of the website.
Example
it took me 3 times to load garuda forum .
missing style
wrong categories places
even the member icons?profile picture arent loaded .
links from search went with white screen
startpage is loading the theme but the rest is missing
reload sign are greyed out
Did someone have the same issue?
Thanks @zoeruda
This could be related to a kernel bug that is affecting DNS. Test out the linux-mainline kernel to see if things improve. The mainline kernel fixes this issue if it is caused by DNS resolution failures on your system.
thx
yeah i am on the znver3 actually i will test the mainline kernel may this fix the firefox crash too loool .
wired those up and downs this year ![]()
ps. my other linux with arch kernel 6.16.4 and hypr works fine.
update: x11 session dont have this firedragon behavior worked nice on first startup.(same znver3 kernel)
