I have installed garuda dragonized it's very good unless fire dragon when it run my system stop immediately
can you post your inxi -Faz please
What is inxi -Faz
It is your system specs
Goto to garuda assistant under system specs
Copy to the forum?
You should read the template before you delete it. This saves unnecessary posts.
Edit your first post, please.
inxi -Faz
