Hello,
I am not being able to setup my fingerprint reader on Dell XPS 15 (7590).
So far I tried to follow many articles about fprint
(fprint - ArchWiki) and Fingerprint GUI
(Fingerprint GUI - ArchWiki) but without success.
When I try to fprintd-enroll
the output looks like this:
Impossible to enroll: GDBus.Error:net.reactivated.Fprint.Error.NoSuchDevice: No devices available
Also, when I enter already pre-installed app Fingerprint Password Settings
I get instant error in pop-up window:
Could not claim device.
Please cancel all other fpint sessions
and press retry.
I canceled all fprint
sessions and there are none running in the background.
Output of my lsusb
looks like this and there is my fingerprint reader which is supported by fprint
according to their docs:
Bus 004 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 003 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 002 Device 001: ID 1d6b:0003 Linux Foundation 3.0 root hub
Bus 001 Device 005: ID 27c6:5395 Shenzhen Goodix Technology Co.,Ltd. Fingerprint Reader
Bus 001 Device 002: ID 8087:0029 Intel Corp. AX200 Bluetooth
Bus 001 Device 004: ID 0c45:6723 Microdia Integrated_Webcam_HD
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
So, do you have any other recommendations? I would love to use my fingerprint on the login screen as well as an authentication to access some apps.
Kernel: 5.16.10-zen1-1-zen x86_64 bits: 64 compiler: gcc v: 11.2.0
root=UUID=6caa828b-1fe1-438c-b753-ec4d6173e158 rw rootflags=subvol=@
resume=UUID=55204ea6-05d6-4401-b78d-0fc6406bcba3 loglevel=3
Desktop: KDE Plasma 5.24.2 tk: Qt 5.15.2 info: latte-dock wm: kwin_x11
Type: Laptop System: Dell product: XPS 15 7590 v: N/A
Mobo: Dell model: 0T8KGX v: A00 serial: <superuser required> UEFI: Dell
v: 1.5.0 date: 12/25/2019
ID-1: BAT0 charge: 12.9 Wh (14.7%) condition: 87.7/97.0 Wh (90.5%)
volts: 10.6 min: 11.4 model: SMP DELL GPM0365 type: Li-ion serial: <filter>
status: Discharging
Device-1: hidpp_battery_4 model: Logitech Wireless Mouse MX Master 3
serial: <filter> charge: 50% (should be ignored) rechargeable: yes
status: Discharging
Info: model: Intel Core i9-9980HK bits: 64 type: MT MCP arch: Coffee Lake
family: 6 model-id: 0x9E (158) stepping: 0xD (13) microcode: 0xEC
L3: 16 MiB desc: 1x16 MiB
Speed (MHz): avg: 892 high: 901 min/max: 800/5000 scaling:
driver: intel_pstate governor: powersave cores: 1: 900 2: 900 3: 900 4: 900
5: 900 6: 900 7: 901 8: 900 9: 800 10: 872 11: 900 12: 900 13: 900
14: 900 15: 900 16: 900 bogomips: 76800
driver: i915 v: kernel ports: active: eDP-1 empty: DP-1,DP-2,DP-3
bus-ID: 00:02.0 chip-ID: 8086:3e9b class-ID: 0300
Device-2: NVIDIA TU117M [GeForce GTX 1650 Mobile / Max-Q]
vendor: Hewlett-Packard driver: nvidia v: 510.54
alternate: nouveau,nvidia_drm pcie: gen: 3 speed: 8 GT/s lanes: 16
bus-ID: 01:00.0 chip-ID: 10de:1f91 class-ID: 0302
Device-3: Microdia Integrated_Webcam_HD type: USB driver: uvcvideo
bus-ID: 1-12:4 chip-ID: 0c45:6723 class-ID: 0e02
loaded: modesetting,nvidia gpu: i915 display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1080 s-dpi: 96 s-size: 507x285mm (20.0x11.2")
s-diag: 582mm (22.9")
Monitor-1: eDP-1 model: Samsung built: 2019 res: 1920x1080 dpi: 142
gamma: 1.2 size: 344x194mm (13.5x7.6") diag: 395mm (15.5") ratio: 16:9
modes: 3840x2160
Sound Server-1: ALSA v: k5.16.10-zen1-1-zen running: yes
Sound Server-3: PipeWire v: 0.3.47 running: yes
Device-1: Intel Wi-Fi 6 AX200 vendor: Rivet Networks Killer™
driver: iwlwifi v: kernel pcie: gen: 2 speed: 5 GT/s lanes: 1
bus-ID: 3b:00.0 chip-ID: 8086:2723 class-ID: 0280
IF: wlp59s0 state: up mac: <filter>
bus-ID: 1-4:2 chip-ID: 8087:0029 class-ID: e001
Local Storage: total: 953.87 GiB used: 113.53 GiB (11.9%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: A-Data model: SX8200PNP
speed: 31.6 Gb/s lanes: 4 type: SSD serial: <filter> rev: 42AZS6AC
temp: 33.9 C scheme: GPT
ID-1: / raw-size: 920.9 GiB size: 256 GiB (27.80%) used: 113.53 GiB (44.3%)
ID-2: /boot/efi raw-size: 351 MiB size: 350.3 MiB (99.80%)
ID-3: /home raw-size: 920.9 GiB size: 256 GiB (27.80%)
used: 113.53 GiB (44.3%) fs: btrfs dev: /dev/nvme0n1p3 maj-min: 259:3
ID-4: /var/log raw-size: 920.9 GiB size: 256 GiB (27.80%)
ID-5: /var/tmp raw-size: 920.9 GiB size: 256 GiB (27.80%)
ID-1: swap-1 type: partition size: 32 GiB used: 0 KiB (0.0%) priority: -2
ID-2: swap-2 type: zram size: 15.26 GiB used: 458.2 MiB (2.9%)
System Temperatures: cpu: 51.0 C pch: 44.0 C mobo: N/A
Fan Speeds (RPM): cpu: 0 fan-2: 0
Processes: 437 Uptime: 21h 49m wakeups: 4458 Memory: 15.26 GiB
used: 7.66 GiB (50.2%) Init: systemd v: 250 tool: systemctl Compilers:
gcc: 11.2.0 clang: 13.0.1 Packages: 1537 pacman: 1522 lib: 335 snap: 15
Shell: fish v: 3.3.1 default: Bash v: 5.1.16 running-in: konsole
inxi: 3.3.13
Garuda (2.5.5-1):
System install date: 2022-02-23
Last full system update: 2022-02-24
